Lyen controller not working at 37V
Re: Lyen controller not working at 37V
Postby cwah » Mon May 21, 2012 2:45 pm
Thanks guys, I'm going to try to remove the R12 resistor and use 1:Comm GND when programming.
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby cwah » Mon May 21, 2012 5:08 pm
This little resistor is sooo small:
How do I desolder that? There isn't even solder on the other side of the board. I may just burn it???
cwah
Postby NeilP » Tue May 22, 2012 12:47 am
You are not supposed to be removing that one, that is R12 itself, you are supposed to be looking for annextfa one on the back of the board, a normal one , possibly in a piece of heat shrink sleeving.
Take that off and you will likely have to send it back again
Show us a pic of back of board
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby cwah » Tue May 22, 2012 2:55 am
Thanks Neil. Lyen contacted me and told me it was the little one with brown red red. I've only found this one:
On the front I haven't found anything that look like this:
Hope it's going to be the right one this time.
cwah
Postby cwah » Tue May 22, 2012 3:02 am
Ok, has been confirmed by Lyen. Going to remove it :)
cwah
Postby NeilP » Tue May 22, 2012 4:08 pm
If you are going to be workng with this sort of stuff, and are not familiar with colour codes on normal resistors, or the number codes on the SMD resistors
try this little freeware app...Windows only
http://www.schematica.com/resistor_colo ... sistor.htm
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Tue May 22, 2012 5:45 pm
I downloaded the program, will use it if I have to desolder other stuff in the future.
It's working at 37V now, so nice :)
Thanks all and Neil and also Lyen for his advice :)
cwah
Postby NeilP » Tue May 22, 2012 10:38 pm
That is good to hear
But one question
Why after buying a high voltage controller have you decided to run at such a low voltage?
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Wed May 23, 2012 1:23 am
Good question!
Why I purchased my controller, I wasn't really sure of the performance my my conhismotor mini hub. But I wanted to reach 30mph. So in case if my 74V set up is not enough to reach 30mph, I can still increase the voltage without having to change the whole set up.
Now, most of the time I won't rum at 37V, I'll use it only for long distance journey in which low speed amd high efficiency is required.
This choice isn't that random lol
cwah
Postby NeilP » Wed May 23, 2012 2:10 pm
yes, makes sense, but even from 74 volt, you col dhave stil gon up to 24S and 100 volt with the standard controller. just needed the R12 mod, and only then if you needed the regen
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Wed May 23, 2012 5:23 pm
Yeah, but I wasn't sure about the voltage I would need. Better to have something adaptable rather than having to change the whole system. I found that the weight was identical to a normal controller, so I preferred to get a higher voltage one for safety :lol:
cwah
Postby NeilP » Thu May 24, 2012 1:59 am
Yes, se your point, but less current with the high voltage ones, so less acceleration :(
180mm disks
100V 20Ah LiPo
NeilP
Postby Jeremy Harris » Thu May 24, 2012 2:28 am
Using a high voltage controller for a lower voltage application also means less efficiency. There is a fairly linear relationship between FET on resistance and maximum voltage, such that 100 V capable FETs will have around double the on resistance (and hence double the losses at a given current) than 50 V capable FETs.
It's for this reason that I changed the FETs in my boat controller (that works at around 20 V max) to IRLB3034 FETs (40 V maximum. These have only 38% of the loss that the 100 V max IRFB4110 FETs commonly used in ~80 V controllers, and only 15% of the loss of the 150 V max IRFB4115 FETs frquently used in 100 V + capable controllers.
If you want best efficiency, then go for a controller fitted with FETs that match your operating voltage range, don't go for a controller with an unnecessarily high voltage spec.
Jeremy Harris
Postby NeilP » Thu May 24, 2012 7:50 am
Ah yes, forgotten about that.
Is this the same controller that you have the 400W for 12mph thread going about or is this a different bike? This could account for a few more watts lost. OK, probably not the full amount, but a little bit here and there, all soon adds up
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Thu May 24, 2012 10:06 am
Yes, it is the same controller. Actually I wanted to be able to transform my 74V8AH battery to 37V16AH for maximum distance when required. But I didn't know that higher voltage controller would be less efficient...
Hopefully, I know that I can always increase the speed and voltage If I want/need to!
cwah
Next
Who is online
Users browsing this forum: No registered users and 16 guests
