MadRhino wrote:I would find more natural to have variable regen on the brake lever.
Jeremy Harris wrote:some Kelly controllers have just this, a separate 0 to 5 V input for controlling regen. This can be hooked up to another throttle on the left grip or a brake lever modded to give a linear voltage output.
Jeremy Harris wrote:MadRhino wrote:I would find more natural to have variable regen on the brake lever.
I seem to remember someone here trying that, with a DIY linear Hall brake lever.
edamame wrote:One thing the throttle reminded me of was an electric R/C car I have that slows down really fast if you reverse the throttle. Could be a clue or a place to start to figure it out.
csm wrote:Jeremy Harris wrote:some Kelly controllers have just this, a separate 0 to 5 V input for controlling regen. This can be hooked up to another throttle on the left grip or a brake lever modded to give a linear voltage output.
Please post an example model name/number. Link?
I just want to confirm you are speaking about variable progress, multi-step variation regen control?
csm wrote:edamame wrote:One thing the throttle reminded me of was an electric R/C car I have that slows down really fast if you reverse the throttle. Could be a clue or a place to start to figure it out.
Which brand/model electric R/C car? Link? Was the reverse a single speed or variable speed reverse?
edamame wrote:The reverse function of my Losi Mini T is variable speed.
csm wrote:Jeremy Harris wrote:MadRhino wrote:I would find more natural to have variable regen on the brake lever.
If you find the applicable threads to this project/discussion, please post links for us to refer to.
Hyena wrote:You can have "2 speed" regen of sorts using throttle off regen, which gives you light braking when you let go of the throttle and it then brakes even harder when you activate the brake switch. I've noticed the throttle off regen cuts out sooner than the regen button though, so it'll pull you up until about 15km/hr then stop braking, but then if you hit the button it'll continue to brake down to about 5km/hr.
On a related note I've also observed that while the regen braking force is only fairly mild when you throttle off but pulls up noticably harder when you hit the switch, it doesn't actually put any more current back into the battery. So alot of that potentially recoverable energy is wasted - dumped as heat into the windings. I'm sure it's done to protect the battery/BMS as most commercial batteries can't take a 2C charge, but it'd be a nice option to have for those of us with lipo. Though granted, regen is more useful for slowing down than actually recouping power.
Throttle off regen is kinda cool when you get used to it, as long as you put it on a switch so you can disable it when you want to cruise. It's like cruising around in 1st gear on an ICE bike with compression braking.
I find it particularly useful on the street when you're accelerating and braking alot, I cover a great deal of my commute without touching the mechanical brakes. And as John said you anticipate corners coming up and when to back off so it pulls you up in time. To the point where I nearly crashed the other day when I had it disabled and came into a corner fairly hot in my usual manner and let off the throttle, only to keep belting towards it. It's not like cruise control maintain the speed but when you're used to the bike instantly decelerating the second you let off, you can get into strife if you're going fast and it takes you a second to realise and then another second for your brain to over ride and reach for the brakes the 'old fashioned way'
csm wrote:Which brand/model electric R/C car? Link? Was the reverse a single speed or variable speed reverse?
Hyena wrote:Modded 9C with modded 12 fet infineon and 18S lipo - 5kw peak.
csm wrote:Hyena wrote:Modded 9C with modded 12 fet infineon and 18S lipo - 5kw peak.
"Modded 9C with modded 12 fet infineon"??
I see infineon is probably the controller. what is modded 9C??
"18S lipo - 5kw peak"?
18 cell lithium (LiFePO4??) ? are you running any parallel cells? you using a BMS? I presume 18 cells at 4.19 volts in series for optimum voltage of about 75 volts? 6 amp hour cells?
Users browsing this forum: j3tch1u, mlt34, Spicerack, triggeraa and 11 guests
