Help needed for chainring
Postby Idontwanttopedal » Tue Jun 12, 2012 1:44 am
Hi dose any one know where I can get or get made a 63t or there abouts 104 BCD chainring. Any help thank yous
Idontwanttopedal
Re: Help needed for chainring
Postby Chalo » Tue Jun 12, 2012 2:15 am
60t chainrings are reasonably available (but not cheap). I have seen a rare few commercial 61 and 62 tooth rings around, too. Bigger than that, and you have to think about having one made to order-- which is a very expensive proposition.
Here's a 65t ring for $134: http://www.hostelshoppe.com/cgi-bin/readitem.pl?Accessory=1155076891
And here's a 60t ring for $38: http://www.hostelshoppe.com/cgi-bin/readitem.pl?Accessory=1016049820
Can you be more specific about what you have in mind for such a large ring? There may be other solutions that are less expensive and more accessible.
Chalo
Chalo
Postby Idontwanttopedal » Tue Jun 12, 2012 4:06 am
Thank you
Idontwanttopedal
Postby Idontwanttopedal » Tue Jun 12, 2012 4:11 am
On that site they are 130. I want to pedal with my 1200 cyclone and the crank freewheel I got uses a 104bcd not a 130 if there a way to use a 130bcd. At mow I'm using a 48t but crank turns at about 112 rpm with that
Idontwanttopedal
Postby dogman » Tue Jun 12, 2012 5:48 am
Might be the thing to do, to find a chainring, and then buy the crank with the bcd it needs. Be aware that on many MTB's a really big crank will rub the frame. Some simply will not take bigger than 48T. Get an 11t freewheel if you don't already.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby Drunkskunk » Tue Jun 12, 2012 12:28 pm
Idontwanttopedal wrote:On that site they are 130. I want to pedal with my 1200 cyclone and the crank freewheel I got uses a 104bcd not a 130 if there a way to use a 130bcd. At mow I'm using a 48t but crank turns at about 112 rpm with that
You're going to be just about out of luck getting a 60+ ring in 104bcd. You'll need an adaptor plate. I've seen 130 to 104 before, but can't remember where. although you can make one fairly easily. a 6" saw blade, a hole saw, a drill, and some patience is all you need to make an adaptor plate.
Whats youre rear count when you're at 112 cadance? if its a 13 on the rear, going to a 52 front wouuld drop you to 100, and going to a 52 front with 11 rear would give you 87
Drunkskunk
Postby Idontwanttopedal » Tue Jun 12, 2012 3:01 pm
The cyclone drives the crank then from crank to from a 44t to a 20t on I auto hub. Rear gearing ok just need slow crank down so I can do more that just sit there. No matter how big I got it want hit frame.
Idontwanttopedal
Postby Chalo » Tue Jun 12, 2012 3:10 pm
Drunkskunk wrote:
Idontwanttopedal wrote:You're going to be just about out of luck getting a 60+ ring in 104bcd. You'll need an adaptor plate. I've seen 130 to 104 before, but can't remember where. although you can make one fairly easily. a 6" saw blade, a hole saw, a drill, and some patience is all you need to make an adaptor plate.
Using an adapter plate would allow offsetting the big ring a bit to the outside, which might make the difference between interfering with the frame or not.
It may be impossible to get decent chainline in any but the outmost rear sprockets, once a 60t ring is mounted outboard enough to clear the frame.
Chalo
Chalo
Postby Idontwanttopedal » Tue Jun 12, 2012 4:05 pm
Seen one on here he got a 64t made but the sit he used is down see if I can get one made that way I will just unbolt the 48t and the fit 64t add new chain
Idontwanttopedal
Postby Idontwanttopedal » Tue Jun 12, 2012 4:07 pm
Idontwanttopedal
Postby StudEbiker » Tue Jun 12, 2012 5:33 pm
There's a download on this page that will print a template for any size ring in any BCD you like. It's fairly labor intensive though, but the good news is all you need is a drill and a file to do it. :D
http://fleettrikes.com/tth8.htm
TidalForce S-750-(build #2) w/9C rear w/EV Components Headway 36v 10ah LiFePo4 pack: http://endless-sphere.com/forums/viewtopic.php?f=6&t=15443&hilit=+headway+rack+pack
Bike-E (Build #3, mostly done)- 400W Kollmorgen mid-drive: http://endless-sphere.com/forums/viewtopic.php?f=28&t=25980#p375646
My Bike E Facebook group: http://www.facebook.com/groups/165756106813440/
"Facts do not cease to exist because they are ignored" - Aldous Huxley
StudEbiker
Postby chisixer6 » Tue Jun 12, 2012 6:16 pm
Well, if you settle for 60 teeth for $40, here is where I get mine. This guy is very good, i get all my frame building stuff from him..I think he is near San francisco.
http://www.gaerlan.com/bikeparts/parts/crank/crank.html
Jerry
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Postby Chalo » Wed Jun 13, 2012 1:18 am
Idontwanttopedal wrote:Seen one on here he got a 64t made but the sit he used is down see if I can get one made that way I will just unbolt the 48t and the fit 64t add new chain
I think you might have missed that it is highly unlikely to be that simple. If you do a simple ring swap, the bigger ring is almost sure to drag on the frame. You can probably reckon this by laying a straightedge against your existing ring. You need to be clear for almost 1-1/2" outside the radius of the 48t ring. Remember that the bigger ring is not only larger in diameter, but more flexible too.
Having a custom ring made is almost always a lot more expensive than buying a stock item (and I mean a lot more expensive than the $130-something dollar ring I posted a link to). It will be much cheaper to find an existing ring in the size you want, then buy a new crank to fit the ring, and probably a longer bottom bracket to bring the ring clear of the frame.
Chalo
Chalo
Postby Idontwanttopedal » Wed Jun 13, 2012 3:06 pm
I have a extra wide bb crank which widened pedals to miss back off motor and moves chainring out and it was set up so the inner tWo chainrings are in line to rear and outter is in line for motor.
Idontwanttopedal
Postby Chalo » Thu Jun 14, 2012 2:11 am
Idontwanttopedal wrote:I have a extra wide bb crank which widened pedals to miss back off motor and moves chainring out and it was set up so the inner tWo chainrings are in line to rear and outter is in line for motor.
Sounds like the clearance issue may not be a problem. Chainline is something to stay aware of.
Is the big sprocket for being driven by the motor, or for driving the bike's wheel?
Chalo
Chalo
Who is online
Users browsing this forum: Google [Bot], kudos, Ribiero, Torque Bikes and 15 guests
