Ypedal said:
fully agree, a clamping solution is the best way to go.
the failure on neilP's axle looks like the thin stainless was cutting into the softer metal of the axle near the frame..
No, not at all.
The stainless torque plates were...I think 7mm thick so twice the thickness of the commercial ones. the failure occurred well away from the torque plate. Torque plate was on outside of frame drop outs and there was a spacer between inside of dropout and end of axle.
The failure was a good 10mm away from the edge of the torque plate.
Looks like this thread has gone totally the wrong way, I was obviously not exact enough when I wrote it the first post...The intention of putting this post was for you all to see the title, see the link on the first post and then go to the linked post and make comments there.
Moved from other thread:
Here is another idea to throw into the mix that I have not see mentioned before. It has been on my mind for a while and I am wondering if this is part of the cause of the problem
I know it is a bit heretical to say it as it seems to go against what every one it is trying to do...but..here goes
ARE we clamping our torque arms too tight?
I am thinking that with the axle clamped very tight, all the shock going from acceleration to cruise and braking is all being transmitted to the axle.
Would we not be better to have a shock absorber collar between axle flats and the torque plate/ clamping mechanism...You et what I mean..a shock drive/cush drive type collar that takes some of the initial shock when torque reverses.
Am thinking something like a bushing that you see in a vehicle chassis at the pivot points of leaf spring suspension. OK, so they are round section...need to find a square section type, and make the axle the same size as the internal diameter of the bushing centre
What I should have said was please go to the linked post and make coments there about my thoughts...but since we are all posting here now...I shall copy that part of the post here.
What I was thinking was that we are clamping the axle TOO TIGHT and not giving it any flex, so all the shock is being transferred to the axle
this sort of think in square section. Ok the one pictured here is a vibration mount, not designed for rotating loads..but it would be a matter of seeing if there is anything out there
http://www.avproductsinc.com/bushing/mounts.html
