wesnewell wrote:Up the voltage and cut back on the amps. VA=W. 48*50=2400W. 72*34=2448W. 84x30=2520W. More torque, more speed, less amperage.
parajared wrote:Up the voltage and cut back on the amps. VA=W. 48*50=2400W. 72*34=2448W. 84x30=2520W. More torque, more speed, less amperage
I don't really want to. I have eight 6s batteries that fit perfectly in my triangle so that only means 6s 40ah; 12s 20ah; or 24s 10ah. I could do a 24s setup, but that would mean I would need a new controller.
If you got the wires hot enough to get soft and melty, then you need to do a full harness replacement including the hall wires. After melting it becomes brittle and the risk of failurefrom cracked insulation is high, and hanging a lead tin and copper bundle off the end of it like a fishing weight will help speed the process. Before getting so hot, yes, the lazy mod helps
dnmun wrote:this is so old, this where jeremy educated me about hall sensors, here i am doing the same thing all these years later.
Lol, for some reason wesnewell disappeared...liveforphysics wrote:Phase current is all the motor sees. The phase current will be the same.wesnewell wrote:Up the voltage and cut back on the amps. VA=W. 48*50=2400W. 72*34=2448W. 84x30=2520W. More torque, more speed, less amperage.
parajared wrote:I think I know what Wes is talking about. You can dump 100,000 watts down a tiny wire and not overheat it if you keep the amps low (say 100,000v 1amp) but if you have low volts, high amps, all sorts of stuff gets hot (speed controller, phase wires, motor coils ect..).
Upping voltage would also yield the benefit of higher top speed, but watts are watts, the motor will handle wattage the same and can still run into trouble if you put too many watts into it.
In other words, if I want to go up hills at 2500watts the motor will act exactly the same, but I could run 28 amps instead of 52; all I need do is wire my batteries in series instead of parallel so that I am running at 90v instead of 48.
Well... that and buy a whole new speed controller
Users browsing this forum: Bike_on, ecologymagnet, ElectroMoto, Google [Bot], OCMike, Rassy, richmpdx, sabongi, upward and 19 guests
