Packcycle 2.5 (watercooling mods in progress)
Re: Packcycle 2.5 (watercooling mods in progress)
Postby Link » Mon May 18, 2009 9:14 am
tostino wrote:Don't expect those fans to last, or even work at that voltage. I burned out a fan running it at 16v, it blew it's controller instantly on connection. I have a very nice 92mm fan for my comp that blows a little over 130cfm. It's called a tornado. Running one or two of those at 14v or so would be insane for airflow.
*shrug*
Eh. I got a pack of four, so I can afford to screw up one or two. The couple of fans I have lying around worked on 24V, so...yeah.
OTOH, an 80mm Tornado fan moves 84CFM, which is over triple what one of the fans I have move. $15, though...which is more than quadruple what one of my fans cost, too. :? LOL @ 55.2 dBA. Isn't that almost normal talking volume?
Hmm...I'll consider it if the fans I have don't work out.
Anyway, I gave up on the copper. The radius of the bends are just too tight for me to do without a jig, and, amusingly, I don't have any tools handy that would cut out an actual shape from a block of wood to make a jig. :roll: So, off to Home Depot to find some caulking, I guess...
To take my mind of my annoyance, I put this together.
Works pretty alright, it seems. Need some more nichrome to make an oven, though. The ones in my house wouldn't handle a 24"x24" sheet, I think, nor do I believe the owner of those ovens would be very pleased to find me attempting to cook plastic in them.
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Link
1.21 GW
1.21 GW
Postby Link » Wed May 20, 2009 11:05 am
Sweet...all that's left to do now is test for leaks and seal up any there.
GEE aren't I good in tight spaces with a caulking gun...
Oh, silicone...you adhere to metal pretty well, are waterproof, good for up to 400°F, and can me made into fake...yeah, is there anything you can't do?
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
Postby docnjoj » Thu May 21, 2009 9:16 am
Yeah Link! Conduct heat! :) Sorry but I couldn't resist!
otherDoc
Wife has gotten a trike to keep the ER visits down. Most recent one was pretty bad! New trike is here! Sun USX/9C on a Ping 36 volt. ! I am the proud rider of a Steintrikes Mad Max full suspension trike with a 9C motor. Now running on 6 Fatpacks at 54 volts and 8 ah!
She does fine on the limited 200 European watt jumper! So far! Don't tell her! Um....uh oh! She now has full power and the will to use it!
docnjoj
Postby Link » Thu May 21, 2009 10:23 am
docnjoj wrote:Yeah Link! Conduct heat! :)
O RLY?
:wink:
Anyway...I do believe that the only thing I have left to do to the hub itself at this point is replace the crappy old phase wires with some new 12 (or was it 10?) AWG teflon ones I ordered way back when. Then I have to go through that godawful mess in my garage to find those two sensorless modules, because, at this point, I couldn't use the halls even if I wanted to. KNEW I should have taped at least one of them to the controller it was going in. >_<
Then vacuuform a new, temporary case for the S-Go's battery so I can stick it in a backpack and use it on this, because I'm still waiting on those batteries. :roll:
Oh, and a little more irony for you: You see the pattern the tubes are in now? They give the exact same flow pattern as the tight-radius bends. At the point I realized that, however, I was just like, ...No. Ignore the copper. It's not worth the frustration. If this starts leaking or something I can always redo it. Until then, a cat is fine, too.
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
Postby Link » Sat May 23, 2009 11:55 pm
So, yeah, friggin' wonderful...turns out that, probably due to bad luck, the controller I was gonna use for this thing is fuxxored.
Added in one of the sensorless modules I got from Keywin way back, and now I don't get any voltage at the phases. Throttle connector works, throttle works, aren't any internal shorts that I can detect...bleh...:? I'd say I simply failed miserably at soldering, only I don't know if the controller actually worked BEFORE I did this. :roll:
After I spent all that time upgrading the wiring to heftier-gauge teflon, too. :(
Oh, and, due to recent developments regarding me building a new PC, I'm using the Thermaltake pump for it's intended purpose (holy crap :shock:) and using this:
http://www.northerntool.com/webapp/wcs/ ... m_vc=C5503
...on the bike. Main reason being I sincerely doubt I'll be getting much water through the hub on that pump's 5PSI or whatever it was, and the spindle the impeller rests on was already cracked once; I'd question its continued integrity were I to use it on a bike.
I'll be waiting on that, though. I also ordered a fair length of nichrome wire with which to build that plastic heating oven, and with all the money I've been spending lately I'd rather put the actual water cooling part of this off until, say, my friggin' batteries are restocked. :x Word to the wise: Do NOT order that size of Zippy from HobbyKing if they're not in stock and you want them within a reasonable timeframe.
Still need to find a suitable DC/DC for all this...
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
Postby Drunkskunk » Sun May 24, 2009 2:43 pm
Link wrote:Do NOT order that size of Zippy from HobbyKing if they're not in stock and you want them within a reasonable timeframe....
been there, done that..Still haven't got the T shirt.
ordered 4 in febuary, got them in like 2 days. they worked great, so ordered 4 more, but they were out of stock. Finaly got them in may.
build#2: Kona Stinky. Crystalyte 408/4012, 74 volts LiPo. 7240 Clyte 4110 controller.
build#3: Skunkwurkz. 9 Cont rear 9x7, Built from left over and trashed parts. $204 total cost.
build#4: hybrid gas electric. 1910ish frame, 350watt geared front motor, 66cc gas frame mounted motor. Long term project
Build#5: ????. 6X10 motor, I'm looking for a suitable frame for this.
Drunkskunk
Postby swbluto » Wed May 27, 2009 9:04 pm
Link wrote:Sweet...all that's left to do now is test for leaks and seal up any there.
Wait... isn't the tubing supposed to be copper? And wouldn't it be better if the "copper tube" were nearly as wide as the inside and held flat against the circumference to maximize contact area?(The cross section of the tube would be highly elliptical or roundly rectangular)
DO NOT BUY FROM ELECTRICSCOOTERPARTS . COM! They are DAMN THIEVES! They will happily take your money, not send you the product, and then claim because you didn't mention something within 15 days (Hello, mail can sometimes take longer than 15 days), they've lost all records and thus they can't help you out.
Check out the latest version of the FREE e-bike/e-scooter( or anything that uses a single brushless or brushed motor) simulator.
swbluto
Postby Link » Thu May 28, 2009 12:12 am
swbluto wrote:Wait... isn't the tubing supposed to be copper? And wouldn't it be better if the "copper tube" were nearly as wide as the inside and held flat against the circumference to maximize contact area?(The cross section of the tube would be highly elliptical or roundly rectangular)
In an ideal world, yes.
In the one I live in where the only things I have to do this with are basic hand tools, this is as good as it gets.
Figuring that the 1GPH pump can move around 250W continuous for every degree Celcius that the radiators can convect to air, I think I should still be pretty okay with the steel transferring the heat to the water through the core. Hardly ideal, but still...far, FAR better than what an unmodified, sealed hub could do.
Said pump shipped today, BTW.
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
Postby Link » Thu Jun 04, 2009 7:38 pm
inb4linktakesforevertodostuff
So the Shur-Flo arrived yesterday, and I set up a little experiment to see how well my money was spent this afternoon.
For the Shur-Flo, I figure I got my $50 worth. It's pretty solid and took just under 40 seconds to fill that measuring cup/bowl/thing to the 8 cup (1/2 gal) mark. So it doesn't really live up to the 1GPM spec (though I think a fair bit of resistance to flow on the intake side could be dragging it down slightly), I tested it at about 45GPM, and that's with a length of the really small tubing I have going into the axle on the 406 on the exit.. That translates to around 160W per degree dissipated by the radiators. Not too shabby, considering that I'm putting in a WAG that they'll be able to drop 10°C or more. If they can't, I'll probably look into a dual-120mm radiator and some 120CFM+ fans to put on it.
The Thermaltake, however, seems to be so overspecced it's not funny. According to the manufacturer's data, it can move 500lph. I'm assuming that's probably with the 3/8" OD fittings and about 1" of tube on either side, because it took 2:02 to get to the same 1/2gal mark. 15GPH translates to about 57lph. :| I'll measure it again when I actually get the cooling loop set up, but I'm not sure the long intake on the Thermaltake was having THAT much effect, since the water level in the bowl I was using to feed it was a few inches above the pump. Plus, while the Shur-Flo's was 3/8" ID while the Thermaltake's was 1/4" ID, the Shur-Flo's was about double the length.
I'll probably sell the Thermaltake for whatever I can get out of it ($25-30 maybe...) and replace it with a Swiftech at some point, because I'm not sure that's gonna be all that much better than even the relatively small, stock cooler that came with the CPU without a pretty large radiator, and I'm going to be relying on the (finned) reservoir to do the cooling.
Interestingly, the Shur-Flo is surprisingly quiet. About as quiet as the Thermaltake is before all the air gets out of it. I was expecting to possibly have to acoustically enclose it somehow, but it's likely less noisy than the motor's going to be at low speed. Has a sorta soft, engine'y sound to it, too, as it IS a diaphragm pump. Kind of a plus, I guess.
Still waiting on the batteries. Some new ones by Turnigy specced the same as the ones I ordered showed up, so I might cancel my order and get some of those instead.
Need to get some of those ceramic toroidial isolators I got from Orvac a long time ago. I can wire the nichrome around them for the oven.
Link
1.21 GW
1.21 GW
Postby GringoInChina » Fri Jun 05, 2009 5:35 am
Link,
I'm jealous of your 'vacuum former'! Years ago when I was building custom PC's I was pining for one of those things to make duct-work for the CPU cooling.
One of the things you may want to put in your water cooling circuit (you prolly already thought about it anyway) is a little 'surge tank', mounted up high, above the motor height and above the pump. It prolly should be vented to atmospheric (and you could use that to fill the system too). With a little air space in it to help purge the air. Maybe have the radiator dump into that and then use another tube coming from the bottom to feed the pump (which you're probably planning on placing low somewhere).
Are your windings as dark as they look in the pictures (very warm motor)?
Mark
Chinese 'Cargo' E-bike.
60v 10ah SLA (rewired w/dual 8ga cable).
Star & Moon? 350w motor 4cond. x 15 turns(rewired w/10ga and Halls equipped w/.1uf caps).
Star & Moon? 60v 20a controller (soldered shunt, 14ga stranded/solder built-up traces and 2 200v 330uf external caps on main power cables).
22" wheels.
GringoInChina
Postby liveforphysics » Fri Jun 05, 2009 7:35 am
Link- A properly designed pump for a closed loop cooling system would have no ability to pump against a head. In otherwords, in a closed loop (zero gravity head), that thermaltake pump could have entirely different performance.
This is tough for me to tell you, because I see a lot of work in your project, but you should know before spending more effort and resources on something. I work as an engineer to design cooling systems (and power generation) for datacenter devices. I specialize in the physics of thermodynamics and fluid dynamics. I can tell you this setup is going to be of no benifit to cooling the motor. Energy can only flow when it has a temp difference. The temp difference needed to be transfering any signifigant energy through that amount of insulation from the windings to the water would be so great that the magents would be de-gaussed, and the windings toasted before the cooling would begin to help.
Get some 1/8" copper ref tubing. Don't try to do criss-cross nonsense. Don't try to do a bunch of tight bends either. Roll the copper around the outside edges. Just 2 passes on each side will do. Then grind your slot big enough to let that tubeing can pass through the axel slot. Grind a slot of each side if you must. Epoxy the loops to the inside of the stator with thermal epoxy. I always use artic silver for my projects, but it's kinda pricey for large jobs, so cheaper stuff would be better suit this project. You can also make your own. Mix aluminum and/or copper dust into long cure-time epoxy until you can't physically get anymore into it, and it turns into play-dough. Pack it in tightly around the tubes to get as good of contact as possible with the inside of the stator.
A low flowrate setup like that will need to operate off a high temp difference to be transfering a useful amount of energy. That means no vinal.
If you follow those instructions, you will have functional water cooling.
Best Wishes,
-Luke
The road of excess leads to the palace of wisdom
Experience is a hard teacher. First comes the test, then the lesson.
Best Lithium battery testing highlight video EVER!!!! :)
http://www.youtube.com/watch?v=dree0rTr1HM
liveforphysics
Postby Link » Fri Jun 05, 2009 3:34 pm
GringoInChina wrote:One of the things you may want to put in your water cooling circuit (you prolly already thought about it anyway) is a little 'surge tank', mounted up high, above the motor height and above the pump. It prolly should be vented to atmospheric (and you could use that to fill the system too). With a little air space in it to help purge the air. Maybe have the radiator dump into that and then use another tube coming from the bottom to feed the pump (which you're probably planning on placing low somewhere).
Yeah, it'll probably just be a section of tube on a T-fitting in-line with the loop in a handy place where I can fill it when the need arises.
Dunno. It's secondhand. But I hear some of the C'lyte's windings are just dark. These seem to be sort of bonded with what's probably a thermal epoxy, so I wouldn't be surprised if that's why they look sort of black-ish.
liveforphysics wrote:Link- A properly designed pump for a closed loop cooling system would have no ability to pump against a head. In otherwords, in a closed loop (zero gravity head), that thermaltake pump could have entirely different performance.
True! Which is why I didn't eBay the Thermaltake on the spot. However, there IS the resistance to flow introduced by the tubing itself, which is determined by the inside diameter, length, and how rough it is inside. I tried getting as close to that as I could with my setup via having the water enter and exit at the same gravitational potential, but, thinking back, the longer section of tube really should have been on the exit, not the entrance. Probably test it again like that, just to see how much of an effect that had...
liveforphysics wrote:This is tough for me to tell you, because I see a lot of work in your project, but you should know before spending more effort and resources on something. I work as an engineer to design cooling systems (and power generation) for datacenter devices. I specialize in the physics of thermodynamics and fluid dynamics. I can tell you this setup is going to be of no benifit to cooling the motor. Energy can only flow when it has a temp difference. The temp difference needed to be transfering any signifigant energy through that amount of insulation from the windings to the water would be so great that the magents would be de-gaussed, and the windings toasted before the cooling would begin to help.
Lul, too late. It was effectively done when the silicone dried.
I'm not expecting it to go through the vinyl tubes. I'm expecting it to go through the metal stator and for the water to take care of it from there. Maybe I should have posted a pic of how it would look between the spokes of the stator...
liveforphysics wrote:Get some 1/8" copper ref tubing. Don't try to do criss-cross nonsense. Don't try to do a bunch of tight bends either. Roll the copper around the outside edges. Just 2 passes on each side will do. Then grind your slot big enough to let that tubeing can pass through the axel slot. Grind a slot of each side if you must. Epoxy the loops to the inside of the stator with thermal epoxy. I always use artic silver for my projects, but it's kinda pricey for large jobs, so cheaper stuff would be better suit this project. You can also make your own. Mix aluminum and/or copper dust into long cure-time epoxy until you can't physically get anymore into it, and it turns into play-dough. Pack it in tightly around the tubes to get as good of contact as possible with the inside of the stator.
I'm still considering doing that, actually. The middle bit of the stator should be fine, since it's contacting the water directly, but heat from the outer edges of the stator (where the windings loop into the next slot; near the side covers) will have to go through about double the iron to be removed from the motor.
It wouldn't be too hard at all, since I'd just leave the middle assembly in place and splice in the copper loops, but I'm curious to see just how much a difference it could have. When I test it, I'll probably have six or more different thermistors on it to map out how much temperature difference there is between the side the water enters on, the side it exits on, the windings for either side, the median point between them, and the axle. Plus I'll probably monitor the temperature of the water going into the hub, coming out of the hub, going into the radiators, and going out of the radiators.
If I figure I'd benefit enough from adding a few passes of copper (which probably won't take much to convince me of), I'll do it. If there's not really very much temperature difference between the middle of the stator and the left and right halves, then...uh...I'll still probably do it anyway, just so the copper tubing I have left won't feel like a total waste. :P
liveforphysics wrote:A low flowrate setup like that will need to operate off a high temp difference to be transfering a useful amount of energy. That means no vinal.
*shrugs*
I figure if these motors can live totally enclosed with how much power SOME people here are putting through them :roll:, mine should be okay with even crappy water cooling.
Also: More stupid ideas are popping into my head. How much would it cost to get a die that would stamp out stator laminations for a motor, ya figure?
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
Postby John in CR » Fri Jun 05, 2009 4:14 pm
Link,
Just to make sure that I understand your rig, the water flows into what was originally the open air spaces between the spokes using the plates to create the sealed spaces, right? Then all that silicone is just to prevent the water from leaking everywhere else, and the plastic tubing is just to transport the water to the radiator after it has been heated by direct contact with the aluminum "spokes" holding the laminations of the stator in place? If that's the way it works, then I think you're on to something effective and relatively easy given limited tooling. I think Luke was looking at it that you were trying to transfer heat from the stator through the vinyl tubing to get the the water, but the way I think you have it, you have a lot of surface area contact of the water directly to the aluminum. I think that way is much better than the way I've been trying to figure out winding metal tubing around in there and trying to bond that tubing to the stator.
It should help you run much cooler during long duration higher amperage, but keep in mind that heat transfer takes time, so the windings will still heat up significantly with short high amp bursts, however, you definitely should be able to move that heat out much better than a sealed hub over the long haul. ie Short burst performance won't improve much, but a significantly higher continuous amperage should be possible than an unmodified motor. That is assuming you have water in direct contact with the aluminum inside, and sufficient radiator to effectively cool the warm water. :?:
John
John in CR
Postby Link » Fri Jun 05, 2009 7:25 pm
Yeah, the middle of the hub is pretty much totally flooded.
Also, more testing.
With the radiators in place and the intake shortened to a little over a foot, the Shur-Flow manages very slightly lower (like a two-second difference) than the 45GPH it did before.
The Thermaltake did MUCH better than before when unrestricted on either side, matching the Shur-Flo's 45GPH. Still nowhere near advertised spec, but much better than before. With the radiators in place, it didn't fare so well, taking about 1:15 to fill the bowl (24GPH).
Then I tested the radiators. In series (didn't test them in parallel) and at 75°F ambient with the cheap 27CFM fans, they manage to drop about 5°F when the water entering them was 120°F. That's a 2.8°C difference, or just over 310W constant heat removal. Hardly spectacular, but that'll go up as the temperature of the water entering the radiators rises and, given how warm the air coming out of the radiators was, I'm guessing they could definitely benefit from better fans. I'm debating whether to buy a better quality, dual-120mm radiator and a pair of 120CFM fans, or just keeping these and getting a pair of 87CFM Tornados. Seems kind of a waste to put fans like that on such cheap radiators, though, so I'm leaning toward the dual-120.
I got paid and those Turnigy batts are still in stock. I'm going to contact HobbyKing and see if I can't get my order cancelled so I can buy four of them.
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
Postby Link » Sat Jun 06, 2009 5:27 am
Sweet, HK got my order cancelled in like two hours, and I've got four 22.2V 5Ah packs on the way (but not really, since I have to wait for the liposack to be restocked :roll:). Along with a Swiftech MCR-220 dual-120mm radiator and two 120CFM Delta fans.
There goes my whole paycheck. :(
ಠ_ಠ
Do you wumbo?
Link
1.21 GW
1.21 GW
PreviousNext
Who is online
Users browsing this forum: John in CR and 5 guests
