Controller inside bag - the solution?
Postby cwah » Wed Jul 04, 2012 5:33 pm
Hello there,
I'm looking for stealthyness for my bike, and I know that many of us will recommend to put the controller outside the bag for cooling it, but it's really not stealthy. Can't see it being in any way stealthy even if I put it under the bag. And it's not waterproof either.
I found a cooling pad on Amazon:
http://www.amazon.co.uk/NEWLink-Laptop- ... 77&sr=8-14
Apparently, it's made of crystal that will absorb the heat of a laptop up to 5 hours (long enough for our ride), and allow the laptop to cool without Fan.
Reviews on Amazon are quite good, anyone here tried it? Maybe worth it to hide the controller?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Re: Controller inside bag - the solution?
Postby motomech » Thu Jul 05, 2012 5:28 pm
Can you get your controller inside a mesh pocket on a bag?
It's what I do on my builds and they are hardly noticeable.
On that one, instead of painting it black, it wrapped in speaker grill cloth.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby cwah » Fri Jul 06, 2012 1:26 am
Mesh pocket is good. I already have a pocket I can put the controller inside. I just have to change it to a mesh one.
But is it enough to cool the controller? And it's not waterproof I suppose?
cwah
Postby cwah » Mon Jul 30, 2012 3:30 am
Another interesting idea is to have a thermoelectric cooler:
http://www.ebay.co.uk/itm/TEC1-12706-Pe ... 3302wt_801
It can even be used in combination of the mesh bag, so you can use much much more power out of your pack :)
cwah
Postby Drunkskunk » Mon Jul 30, 2012 9:09 am
Thermal diodes like that are great. We used them in some specalized camera housings we built for the state.
The problem is that one side of the diode gets cold, the other side gets very hot. you need a big heatsink and lots of airflow to keep them cool. they also aren't the most efficent things in the world.
A better option is to redesign your bag with things like a mesh bottom, or mesh sides to let air flow through. My first bike had a small bag tailored to cover the controller, vut left the heatsink side exposed to the wind on the bottom side, and was vented so air could be channeled in and flow over the controller.
Drunkskunk
Postby DAND214 » Mon Jul 30, 2012 10:27 am
So if the controller isn't "WATERROOF" MAKE IT WATERPROOF.
Even the so called waterproof really aren't. Water resistant is more like the correct term.
So just seal it up and put it under your rack. While your at it you better waterproof the motor and battery if you are really going underwater or ride in the downpours.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby cwah » Mon Jul 30, 2012 7:03 pm
I was thinking that it was only generating cold :lol:
Ok, if it's only on one side, it doesn't have much value on the ebike. Except that it can also generate electricity from the heat! But not much I suppose.
Going to try to ventilate with mesh cover, should be much better :)
cwah
Postby shock » Sat Aug 04, 2012 9:52 pm
Really putting the controller in a bag is not a good solution. They run hot, and hot=inefficient. Ive tried various bags and nothing works even close to having the controller mounted where airflow goes over the fins proper. Its not really that hard to conceal if you're creative =^)
High Voltage
shock
Postby John in CR » Sun Aug 05, 2012 8:42 am
Size, some paint, and location can make a controller unnoticeable. If you're running UK legal power, then a good 6fet can deliver sufficient power and those are tiny. Your wires would be harder to hide.
You could also get creative with some kind of cover or shield that can hide the controller and the wiring near the controller that serves other useful purposes like channeling air flow over the controller as well as shielding it from the elements. eg a controller mounted in the triangle right at the headset could have a cover that makes it look like part of the bike and also scoops air in. In front of the head tube it could be made to look like a headlight. Hanging under the top tube it could go into a cylinder with open ends but still look like a water bottle. Along the seatpost and painted the same color as the bike can make it all but disappear.
Regarding waterproofing, it's more about making sure any water trying to follow the wiring has an uphill climb to get into the controller and making sure your all connectors are sealed.
John
John in CR
Postby cwah » Sun Aug 05, 2012 12:44 pm
I'm not really at legal speed, so my controller are all 12 FETs :)
It's quite a big controller and difficult to hide. For now I kept it on the bag and try not to drag too much current. I'm still thinking about what you guys saying and put the controller outside the bag. I may put it under the bag but I'm not sure yet.
Here's my bike:
You can see the controller and all the wires coming out of the rear bag of the bike :)
I tried initially to put the controller on the frame, as it has the same colour as my brompton, but it was way too noticeable. Everybody was asking about my electric bike :(
cwah
Postby neptronix » Sun Aug 05, 2012 2:19 pm
This won't work on your bike, but if you can get a triangle frame bike..
I ran my MAC Trek like this for a very long time. In the winter, i'd keep the bag closed.. in the summer, i'd crack the front open and let the air flow over the controller. This has worked very well for me.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Who is online
Users browsing this forum: Google [Bot], gwhy!, Hero_004, justarandomer, thewmatusmoloki and 13 guests
