best deals on ebay or whereever
Re: best deals on ebay or whereever
Postby KevXR » Sun Jul 15, 2012 9:55 am
Looking at the conversion kits on eBay, the price difference between a 250w - 24v and 1000w - 48v is only $60. What are the reasons for buying a lower powered electric hub?
Weight of the motor?
Battery requirements?
Let's say the current battery budge is for 36v battery pack. Will I be sorry buying a 48v system and running it under powered? Can a 1000w system be run on lower power and stretched out like a 500w motor?
I am looking at building two low cost systems that are the opposite.
1. Commuter - can go 15 to 18mph for 20 miles round trip. Some moderate hills. What is the minimum that doesn't make peddaling seem better.
2. Trail bike - can boost up 2 miles of steep hills, then tuned off and not used. Think booster rocket. Lighter is better.
Thank you. Kevin
KevXR
1 W
1 W
Postby ian.mich » Sun Jul 15, 2012 12:10 pm
KevXR wrote:Looking at the conversion kits on eBay, the price difference between a 250w - 24v and 1000w - 48v is only $60. What are the reasons for buying a lower powered electric hub?
Thank you. Kevin
1. 9 hardcase 4s lipos for 44v 15ah, that should be $210 plus parallel board, parallel bullet harness and charger, 100v 45a controller (i can ship that to you for $100 with warranty), mini hub motor http://www.ebay.ca/itm/36v-350w-26-Rear ... 3378ed9969
2. geared motor and a few lipos, and the 100v 45a controller
http://www.AtypicalEV.com
Avalanche 3.0
Front and back Weinmann DH39s in 12G,
Motor laced using custom Sapim 12G with linseed oil
24s3p 5ah hardcase LiPo in a FalconEV frame bag, 8A bulk charge
Batt medics
18x4110 controller at 60A
DD hub with 12g inside and 10g outside
Doc's torque arms
ian.mich
Postby wesnewell » Sun Jul 15, 2012 12:19 pm
IMO, either ignorance, or to stay in compliance with ignorant laws.
A motor can be run at any voltage as long as the controller will handle it. Increased battery for more voltage will also produce a longer range if operated at same speed.
A 48V controller won't work with a 36V battery, because the default LVC of a 48V battery is ~42V. OTOH, a 36V controller will normally work with a 48V battery, but would allow you to over discharge the battery as its LVC will be set to 30.5V.
1. Any kit with ~500wh of battery.
2. Geared hub With 3lb rc lipo pack.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Who is online
Users browsing this forum: GSteg, justlooking, OCMike and 11 guests
