ecat
- Joined
- Apr 8, 2009
- Messages
- 88
I came across a nice headlight that I thought I would share. I bought one on ebay from zsjladyshop, item #261101473285 for about $20.00 Tested it out with a 12 V battery and it is bright, I believe 1200 lumens, and has a good beam, not to concentrated, not too diffuse. Looks to be decent quality for the price. Not sure of long term durability, if I have any problems I will report back. The only thing it is missing is an on/off switch, so I will look for a bar mounted switch, any good finds out there? Notice that it can be run directly off pack voltage.
Here are the specs from the ad:
Brand new and high quality
This auction is for 1 pc Sliver spotlight
Ultra bright 3-LED waterproof spotlight
New version using top brand CREE leds
LED life span over 50000 hours
5W each LED of total 15W output,1200 Lumens
53mm (2.10") diameter x 85mm (3.3") in length
The diameter of the handlebar mount is 25mm
Working voltage is 12V-80VDC
Anodized sliver aluminum alloy light body
Wire length is about 23 inches
Red wire positive & white wire negative
Univsersal fit for bicycles, motorcycles, cars, trucks, boat.
Available color:White\Red\Blue\Yellow, Please leave notes in PayPal(Not email/Message) when making the payment to indicate the colors you want.
Package included:
1x 15W 12V 1200LM CREE LED Light
Package included:
