electr0n wrote:That is cool. I've been thinking about doing something similar. So you've got 75v at 1.14 amps there? 85 watts for $200 nice. Our power just went out two days ago. It doesn't happen very often but it'd be nice to have some alternative backup like solar panels. I had my nearly 1 kilowatt hour worth of batteries sitting here fully charged wishing I had an inverter to run.
I'd really like to try building a mini wood gasifier to run a small generator. That would be much cheaper than solar panels and not limited by the lack of sun.
SamRam wrote:electr0n wrote:That is cool. I've been thinking about doing something similar. So you've got 75v at 1.14 amps there? 85 watts for $200 nice. Our power just went out two days ago. It doesn't happen very often but it'd be nice to have some alternative backup like solar panels. I had my nearly 1 kilowatt hour worth of batteries sitting here fully charged wishing I had an inverter to run.
I was thinking of building a generator exersize bike for th old a123 cells I have from my last pack
It's 12v now, runs a good 2000W inverter, for power outage bike charge emergency.
Solar is good![]()
Get an inverter my friend! True sine is the best.
Lebowski wrote:why doesn't someone build a proper boost converter ? One where you can set the load it should show to the solar
panel such that the panel operates in its most efficient range...
For bulk battery charging, maximizing the charge current is all that counts. A buck-boost MPPT converter can do that over a wide range of voltages, but If the PV output voltage is greater than the battery voltage then it is more simply done just using current feedback into a PWM buck converter. Such a buck converter is basically the old PWM circuit with the addition of a small coil and diode, adding maybe $1 to the parts cost. The specs say input 12-40 volts batteries 12-24 volts but I'd be surprised if the input voltage could be less than the output voltage.ddk wrote:nXt is a terribly mis-speced mppt controller that may or may not be what it's supposed to be
dak664 wrote:Weight 760 grams, shipping weight 40 pounds! What's up with that?
LOL- I dunno !
-but I bought three, expecting delivery in mid Feb
in this, uhm, interesting caseamberwolf wrote:dak664 wrote:Weight 760 grams, shipping weight 40 pounds! What's up with that?
Common way for amazoners and ebayers to make extra money, especially with cheap items. Some of them will give you the real cost/etc when you call them on it, and some say bugger-off.
amberwolf wrote:Well that's a pretty good deal then.
dak664 wrote:For bulk battery charging, maximizing the charge current is all that counts. A buck-boost MPPT converter can do that over a wide range of voltages, but If the PV output voltage is greater than the battery voltage then it is more simply done just using current feedback into a PWM buck converter. Such a buck converter is basically the old PWM circuit with the addition of a small coil and diode, adding maybe $1 to the parts cost. The specs say input 12-40 volts batteries 12-24 volts but I'd be surprised if the input voltage could be less than the output voltage.ddk wrote:nXt is a terribly mis-speced mppt controller that may or may not be what it's supposed to be
Users browsing this forum: dan974, Kabbage, stevetooke, Supertux1 and 13 guests
