Brushless Geared hubmotors: BIG list & details
Re: Brushless Geared hubmotors: definitive list & details
Postby Knuckles » Sat Jun 28, 2008 5:37 pm
Funny. I use a $15 temp probe to measure my NiMH bat pack chargers.
These sell in the supermarket and target too. Easy to install.
But it get's even goofy'r. Replacement gears are like real cheap.
So thus continues the evolution of the EV revolution.
Party On!
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby deVries » Mon Jul 14, 2008 4:27 pm
andys wrote:Doug at EV tech engineered and designed the geared hub motor over a period of many years. Too bad he didn't patent it, as now the manufacturers have sold his design to others who put their names on them. I have his hub on the rear of a bike and it is an 8 pound torque monster. One thing not mentioned much about these motors, is that they are very efficient. Quite a bit more so the the Crystalite ones. I can go 35 miles on a 48 volt 15AH Lifepo4 at an average speed of 20 MPH on a 20 inch bike.
http://www.texaselectricbikes.com/catal ... p-163.html
Hello Andy,
When I checked your link for the motor it states the motor is 12-lbs, which is 4-lbs more weight than your Puma motor. I think "Knoxie" from youtube BMS/Puma fame also mentions this lower weight too.
Why is their current motor at the above link 4-lbs heavier than yours or Knoxie's???
Thanks!
Does this motor have more torque than what the Heinzman (53 Nm rating) motor does?
deVries
Postby voicecoils » Thu Sep 11, 2008 7:06 am
Bafang PMGR no load test:
48v 8a power supply and ecrazyman older pic based 72v 28a 1000w controller used.
stand alone Cycle Analyst reports:
39.3 Km/hr
51 Volts
37 watts unloaded (.73 A)
voicecoils
Postby docnjoj » Thu Sep 11, 2008 8:33 am
I concur! At 42 volts nominal (48 fresh off the charger) I get about 0.9 amps with infineon and wheel with tire 20". Alot better that 12 amps with the old Crystalyte 36-72 20 amp. Never could get the motor to run well with that controller, and I tried all the combos several times. It seems unsuitable with this geared motor! Infineon works great.
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby lfairban » Thu Sep 11, 2008 8:31 pm
Miles wrote:Tongxin
You didn't give a link. I believe the Tongxin motor was branded the "Nano".
http://www.nano-motor.co.uk/nanomotor.php
Thou technically it is not "geared", it has rollers that make it lighter and quieter, but the same basic idea.
I put all the information on bike kits that I have been collecting in three tables; front, front/rear, and chain/sprocket:
http://home.columbus.rr.com/lfairban/Pa ... 0Kits.html
Check out my Ebike Kit guide at Electrically Enhanced bikes. http://eebikes.net/kits.html
lfairban
Postby Wile E. Coyote » Thu Sep 11, 2008 11:43 pm
Nice work on the table. Don't forget about the BMC kits form EV Tech. I'm very happy with the motor I purchased from them.
Wile E. Coyote (velous-electrifacatious)
K2 Easy Street / Rear BMC V2T / 30A Infineon Controller / 66V A123 20s3p
Wile E. Coyote
1 W
1 W
Postby docnjoj » Fri Sep 12, 2008 7:35 am
lfairban wrote:
Miles wrote:Tongxin
I'm not sure the Tongxin should be on the list. Mine lasted 4.5 miles and melted down! Brett White stopped carrying them after numerous problems with controllers and heat.
otherDoc
docnjoj
Postby lfairban » Fri Sep 12, 2008 9:46 pm
Darn! That is the motor on my wife's Schwinn. She just got it back from the shop.
I have seen two threads on other forums about this motor:
http://www.pedelecs.co.uk/forum/electri ... -kits.html
http://www.bikeforums.net/archive/index ... 32372.html
lfairban
Postby docnjoj » Sat Sep 13, 2008 8:49 am
Maybe U will have better luck, or maybe they changed the design.??
otherDoc
docnjoj
Postby andys » Sun Sep 14, 2008 12:08 pm
Hello Andy,
He is giving the weight for the complete assembled rear wheel when he says 12 pounds. The same wheel and spokes with a Crystalyte 4000 series hub weights about 22 pounds for a comparison.
andys
Postby zibbby » Sun Sep 14, 2008 2:20 pm
This is Bafang rear 136mm dropout. Model # SWXH . It is design to work with 6spd freewheel and 160mm disk brake.
I will use that with 26" wheel and 48V.
(184.13 KiB) Downloaded 294 times
zibbby
Postby Freddyflatfoot » Tue Sep 16, 2008 9:50 pm
I've been using a Bafang rear notor with 7 speed freewheel for quite a while now. Currently have it setup in a 20" wheel, and running it at 36v with the std 15A controller, and 36v/10AHr Ping battery. Good combo and works really well.
Not sure on the width, but can 'squeeze' it into the 135mm dropout, probably closer to 140mm tho'......
http://s281.photobucket.com/albums/kk20 ... CF0074.jpg
http://s281.photobucket.com/albums/kk20 ... s-0073.jpg
My only issue with the Bafang, that is a PITA, is the motor wires exiting the same side as the gears. Would much rather prefer them exiting on the other side! But then that causes other issues, as the whole motor assembly comes out as one piece, leaving the casing attached to the wheel.
I actually have another case that is laced to a 26" wheel. So swap them around occasionally, but I think I prefer the torque of the 20" wheel.
Rob
Current setup, 250 watt/24 volt chain drive setup on Jamis MTB, 24 volt, 10 AHr Yesa LiFePO4 pack. 15A controller. (increased to 20A, currently dismantled) (motor sold)
Home built recumbent trike, 350 watt, brushless, geared, hub motor, 36v/10AHr 'Duct Tape' LiFePo4
Freddyflatfoot
Postby docnjoj » Wed Sep 17, 2008 7:26 am
Roger that, Freddie! I use a weak 42 volts and 20" wheel and could use a little more torque off the line. Ping batt is in the cards!
otherDoc
docnjoj
Postby Freddyflatfoot » Wed Sep 17, 2008 10:31 am
At this stage, I'm happy to stick to the stock controller, to keep the Ping battery happy at 1.5C max discharge.
I would consider another controller only if I get another battery that would handle a higher 'C' rate, so either a larger capacity battery, or a more expensive battery!
But then, I *should* get my moneys worth out of this one first!
Rob
Freddyflatfoot
Postby dogman » Thu Oct 16, 2008 7:16 am
There is a new gear motor on ebay now, listed as a 1200 watt motor. Made by AOTEMA , same manufacturer as the WE motors. No idea who the vendor is, but this motor does not show on the WE site I looked at, so I assume no customer service from WE.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby voicecoils » Wed Oct 22, 2008 2:43 am
dogman wrote:There is a new gear motor on ebay now, listed as a 1200 watt motor. Made by AOTEMA , same manufacturer as the WE motors. No idea who the vendor is, but this motor does not show on the WE site I looked at, so I assume no customer service from WE.
Link? I couldn't find it...
Cheers!
EDIT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320309855183
voicecoils
Postby pithy » Sun Nov 09, 2008 2:42 am
It says that it's internally geared and that it can do regen. Aren't geared motors incapable of doing regen?
pithy
Postby voicecoils » Sun Nov 09, 2008 4:12 am
pithy wrote:It says that it's internally geared and that it can do regen. Aren't geared motors incapable of doing regen?
If they freewheel = no regen
If they don't freewheel = regen possible
Both types exist.
voicecoils
Postby pithy » Sun Nov 09, 2008 7:16 pm
i thought that all geared motors would freewheel, but i've never looked into that before. what other geared motors don't freewheel? (just curious)
pithy
Postby voicecoils » Sun Nov 09, 2008 9:03 pm
pithy wrote:i thought that all geared motors would freewheel, but i've never looked into that before. what other geared motors don't freewheel? (just curious)
P2b, from this thread for example: viewtopic.php?f=3&t=4892#p72613
Think about it. Why would a geared motor NEED to freewheel?
Brushless geared motors are just that. Brushless motors which spin faster then the hub does. They're geared with mechanical reduction, mostly between 4:1 and 10:1.
Using a freewheel mechanism lets the hub spin freely without spinning the motor. Doing so makes regen and riding backwards impossible. If you don't have a freewheel, the motor will always be turning if the bike is moving whether forward or backwards and whether or not the motor is being powered.
Cheers.
voicecoils
Postby John in CR » Sun Nov 09, 2008 9:26 pm
I'd make sure they use the wording "planetary gears". I've already run into a few instances of those in the orient saying gears when they're talking about the freewheel sprocket. To them a non-geared motor would be those that can't accommodate a chain for pedaling.
It would seem that a geared hub without freewheel would be difficult to pedal unpowered. I'll find out soon enough, because I have some kits for testing in route that include planetary geared hubs, regen, auto sensing LED lights, as well as the option while riding of variable pedal assist or immediate start. If it proves to be of good quality and is everything I'm told, then it should be an economical contender, but that remains to be seen.
John
John in CR
Postby cycle9 » Thu Nov 13, 2008 11:29 pm
Great thread. I thought I'd update this in relation to the BMC motors (we are a relatively new dealer of those, but have contributed ideas to BMC for a new high-torque version for the cargo/sports utility bike market that is coming soon).
I'm going to write this up and make it into a table on our website, since it is confusing due to all the different names people use, and the new versions coming available.
Right now, there are 4 BMC bike motors available and/or soon-to-be (these are the 4 that BMC has made us aware of, I cannot guarantee that there aren't other versions around, but I suspect I would have heard about them if there were).
1. The original. Labeled "250W" on the sticker, official BMC part number 14110-1. Despite the label, BMC claims this is their "400 watt" motor. We call it the V1 (version 1). 5:1 gear drive. At 36V, this one will top out unloaded at 25mph, but with a rider, more like 22-23 mph while pedaling (using the BMC "25A" controller). Max power it can safely accept is around 48V/20A. It is very similar to the eZee motor. It uses the nylon gears. Despite some bad rap for these controllers, we've so far had good experience with them, having put two through fairly extensive use and abuse. BMC claims they upgraded the FET's a while back. They are very waterproof (everything is potted). Their main problem is that they can only do 36V at 22A (despite the 25A label, I have never seen above 22A). I will soon test one with 48V, but I hear rumors that it will fry them.
2. The new "600W". The latest, which has just appeared in the past few weeks, is their higher-speed geared motor. Official part number 14110-2. We call it the V2-S (version 2 speed). The windings are heavier and can accept substantially more power than V1. Spoke holes are bigger, to readily accept 12 or 13 gauge spokes. In our experience, this produces less torque than the V1 at identical power levels. That observation was confirmed by BMC, since they have wound this for speed over torque. But, since it can be used at higher amps and/or volts, then if paired with the appropriate battery and controller, it will still produce plenty of torque, more than V1, when run at higher power. Top unloaded speed at 36V is around 30 mph. At 48V this will be more like 40mph. Practical speed with rider at 36V (and > 30A controller) is upper 20's. The very first batch of these we got had weak clutches, but a batch is on their way with stronger clutches. The motor still uses nylon gears, for noise reasons. BMC apparently tried metal gears and it was too noisy. We are building them up in Sun Rhyno lite wheels in a 1X pattern with a spoke twist at the cross, for strength. I am using one on my Yuba Mundo, and have carried up to about 150 lbs of cargo in addition to my 200 lb rider weight. So far, the wheel hasn't budged.
3. The newer high-torque "600W". Not available yet, but very soon (possibly by early December, if all goes well). We requested this from BMC for our customers who have heavy bikes or big hills to climb. It uses the same internals as the V2-S, but is wound for a bit more torque - 35% according to BMC. The official BMC part number is the 14110-2T. We call it V2-T for short. It will be a bit slower than the V2-S, probably much more like the V1 speed-wise. But with the bigger, beefier windings, it will be able to accept a lot more power for climbing than the V1. I can post more about them as soon as we have them in hand. The first limited batch is already spoken for between ourselves and another dealer. We will be building these up in very heavy duty wheels for the sports-utility bike crowd, using butted Wheelsmith spokes designed for Downhill mountain bikes, and Sun Mammoth rims, also designed for downhillers.
4. The fabled "1000W". I do not have one of these - supposedly a few are now in testing. This will be an ultra high speed motor, non-geared. Rumors from BMC of it being around 40 mph at 36V, unloaded. That would make it very similar to the Forsen (high speed, low torque, but the BMC will be lighter weight). I do not have the part number, but could guess it is something like 14110-3... We'll refer to these as V3 motors.
All of the above use the same, relatively compact BMC outer case that can fit a 7 speed freewheel and 6-bolt disc brake. The V2 series are just a tad heavier, due to the extra copper. Nylon gears are a potential wear item, but are replaceable.
I hope that helps clear up some of the confusion about the various BMC motors floating around. There are a lot of different names for these from different vendors, which does not help. BMC themselves only use the model numbers, which are a bit too obtuse for most of us to remember.. (at least people of advanced age like myself). At the risk of just introducing more confusion, we are trying to keep it simple with the V1, V2, V3 numbering scheme.
Morgan
Cycle9.com
http://www.cycle9.com
Intentionality fuels the master's journey. Every master is a master of vision.
- George Leonard, "Mastery"
cycle9
Postby marks » Wed Dec 03, 2008 11:38 pm
Does anyone know which make this one is?
http://www.electricbikes.co.nz/content/view/22/65/
I'm in Aus, and I suppose I could order it from NZ, but as I can't seem to pick which brand/make it is, I am struggling to find it. I know it's 285w instead of 200w!
marks
1 W
1 W
Postby gedemeisterdk » Thu Dec 04, 2008 9:16 am
“Does anyone know which make this one is?
I'm in Aus, and I suppose I could order it from NZ, but as I can't seem to pick which brand/make it is, I am struggling to find it. I know it's 285w instead of 200w! “
at 24 volt i don´t see any real legal problem...
the same kit is sold here in the EU, rated at "250" watt:
http://www.alienbikes.co.uk/index.htm
gedemeisterdk
Postby marks » Thu Dec 04, 2008 9:18 pm
I'd love that little one in a rear hub hence my question of does anyone know the brand/wholesaler?
marks
1 W
1 W
PreviousNext
Who is online
Users browsing this forum: biohazardman, icecube57, Samd, Sancho's Horse and 13 guests
