******* Here is a current picture of the bike********
I am long time lurker on the board, gathering info and looking for inspiration. Now its time for me to share with the rest of community.
I had originally planed to cut out the top tube and add a battery tray (bonded carbon fiber) to a downhill mountain bike frame.
I now realize that I may not be OK on strength but more importantly the geometry will be incorrect. For an EV bike a longer wheel base and longer “chain stay” length is needed to prevent wheelies. In addition I have switch to A123 pouch cells from 18650′s due to availability of pre-built packs and reliability. I will use batteries, motors and controllers from my friend Paul at EM3EV.
Here are my design priorities
1: easy to make and assemble
2: proper heavy duty frame for “freeride” type of riding with weight of batteries and motors.
3: a low risk EV drivetrain. Reliable is more important than fast for now
4: excellent hill climbing ability on and off-road.
5: Flexible for different motor-controller-battery combinations
Its an unusual frame construction but serves my design priorities. I have been designing many sheet metal parts for my racecar project and I have come to value the cost effectiveness of sheet metal parts. There are severe constraints on which shapes can be cut and folded and it is a huge challenge to develop a light weight and strong structure, but it can be done. I am using a mix of CNC machined aluminum parts (many of the parts are common to reduce cost) and the laser cut folded chrome-moly sheet.
The current design is sized to hold two 50v 20AH A123 battery packs (2000 watt-hours!). This should give me 80-100 km of flat ground use or 30-40 km of steep hills. Of course smaller batteries could be used.
I will add more photos from the test fit this weekend later today.
