Doctorbass said:
Oh.. and no real need to install SB50 too big connector they look ugly on the swing arm ! the Anderson PP45 or PP30 do the job well with 10 gauge at up to 300A burst
Doc
I find it incomprehensible to believe that a connector rated at 45A continuous is acceptable in enduring the continuous phase currents you guys force into these big hub motors let alone 300A bursts!!! The surface area of PP45 contacts is a small radial edge - tiny - even if it is silver plated. Compared with an gold plated 8mm bullet connector which to my eye looks like a much better proposition for compact high current connectors. I wonder what sort of wattage loss due to high resistance joints you guys are experiencing with undersized connectors.....by acceptance through denial/ignorance/trend rather than with the benefit of an informed decision through testing.
Just because the plastic casing of a PP45 doesn't melt at 300A bursts, doesn't mean it should be considered acceptable if its a mini heater..
