RoadWrinkle said:124 volts,....How is this possible?
Did anyone notice the venting holes of the motor? comments please
This is a recombent made by Lightning. And the model is Phantom.
From the factory it weight is 30 lbs... converted to electric 88 lbs.
With 100 volts of lipo batteries this bike will see 65 mph.
The motor is a Crystalyte HS 3540.
- a heavy duty new machined axle was made for this motor.
-10 gage phase wires
-Thurmal sensor
-cooling vent slots in side covers with air scoops
dnmun said:what controller is he using for the 10kW?
Doctorbass said:dnmun said:what controller is he using for the 10kW?
A great 18 fets 4110 with caps upgrade can do that easy. Mine was able to peak 13kW( reading and 20kW ( amp x volt min)) and to sustain 9-10kW.
Doc
John in CR said:Doctorbass said:dnmun said:what controller is he using for the 10kW?
Doc
It would blow as soon as you hit the throttle. He was 125V fresh off the charger, so 30s. Even if voltage wasn't an issue, the max power run through a controller varies greatly with motor it is pushing and the phase/battery current limit ratio. Speed winds typically come with low inductance and resistance and require beefier controllers along with lower phase/batt current limit ratios.
spinningmagnets said:Did anyone notice the venting holes of the motor? comments please
Hubmotor Ventilation, Johns new approach, 3 pages
http://endless-sphere.com/forums/viewtopic.php?f=2&t=39773
Air cooling my X5 (40 pages)
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=9791
Best waterproofing for inside a hub
http://endless-sphere.com/forums/viewtopic.php?f=30&t=36786
1KW said:i want a recumbent now, any negatives to one? Only thing i see is <5mph stability, and most have vbrakes
