125V 80mph e-recumbent by Paul McDonald
sk8norcal
San Jose, CA
someone on here?
file.php
[youtube]lTqkdGgRbPU[/youtube]
That is a neat build, and a very good example of the advantages of a fairing and a low profile bike.
Accelerating pretty quick to 80 Mph with power under 10KW is an outstanding combination of performance and efficiency.
well I am just coming around on the idea of recumbent bikes, I didn't really like them, but the build changed my perspective cos the kinda look like Forumla 1 for e bikes. that 80mph is completely insane. Any body have info on the bike specs and details
124 volts, maxing at 10,000 watts into a single rear hub motor? What am I missing? How is this possible?
With the Cromotor etc, 10kw is no biggie, with THAT hub motor, it's pushing it a little. but 80 is still impressive (and scary)
Definitely has the right idea; minimize frontal area however possible.
Wonder what his wh/mi stats are at more normal road speeds?
10000watts/80mph = 125wh/mi
At 20mph?
(80/20)^3*p = 10000
p = 10000/((80/20)^3) = 156 watts
156watts/20mph = 7.8 wh/mi.
Not bad, I want that recumbent, lol.
My recumbent is pushing 330 watts at 20 mph. It's definitely not a racer, though better than those 'semi-recumbents'. (*wonders* does this recumbent have a suspension? *Watches* Front suspension but no rear suspension.)
Look like the front suspension would consist of the knee pads and helmet :lol:
Congrat!
Thanks for the video.
Definitively possible as well.. i'm doing 70mph on a DH bike with big fat 24 x 2.5" wide offroad tire with about the same power on a 5303.. at 125V too..
Add better aerodynamic, tires and bigger motor and i have no doubt he did that 80mph.
Doc
in the comments,
This is a recombent made by Lightning. And the model is Phantom.
From the factory it weight is 30 lbs... converted to electric 88 lbs.
With 100 volts of lipo batteries this bike will see 65 mph.
The motor is a Crystalyte HS 3540.
- a heavy duty new machined axle was made for this motor.
-10 gage phase wires
-Thurmal sensor
-cooling vent slots in side covers with air scoops
fairing by zzipper
A question for those with recumbent experience...If you start to get a wobble, how do you react and change your CG enough to nip it in the bud before the harmonic oscillation has a chance to become catastrophic? I've had hints of wobbles on some of my bikes when I get too low and forward in a tuck, and my immediate reaction has been to raise up, which moves the CG up and rearward enough to immediately end the wobble. I guess I picked it up from Sir Anthony Hopkins playing Burt Monro, but all I know is that it works. Is there any way to do similar on a recumbent?
That's my biggest reservation about building a really fast ebike, because I know I can easily get a hubmotored ebike well above 120mph with some attention to aero, and the 22" wheel I have ready to go. I did 103mph with a 19.2" wheel and voltage sagging to 101V, so far faster is only a matter of aero and working up the nerve to do it. I wish I had a runway to use.
dnmun said:
what controller is he using for the 10kW?
A great 18 fets 4110 with caps upgrade can do that easy. Mine was able to peak 13kW( reading and 20kW ( amp x volt min)) and to sustain 9-10kW.
Doc
Doc
It would blow as soon as you hit the throttle. He was 125V fresh off the charger, so 30s. Even if voltage wasn't an issue, the max power run through a controller varies greatly with motor it is pushing and the phase/battery current limit ratio. Speed winds typically come with low inductance and resistance and require beefier controllers along with lower phase/batt current limit ratios.
John in CR said:
Doc
yes probaly it woudl blow at 125V with the 4110 as well.. on my setup i was using 28s A123 and a 5302 ! on a 20" wheel. i saw sustained power of 11.5kW during most of the acceleration.
the 18 fet with 4115 would blow for sure...
Doc
I love these recumbent builds primarily for the aerodynamics and secondarily the comfort for longer rides. Although I would imagine going fast without rear suspension could be hard on the spine and this one is a little too low to the ground for riding in traffic. I bet that is amazing fun to ride. :shock:
spinningmagnets said:
Did anyone notice the venting holes of the motor? comments please
Hubmotor Ventilation, Johns new approach, 3 pages
http://endless-sphere.com/forums/viewtopic.php?f=2&t=39773
Air cooling my X5 (40 pages)
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=9791
Best waterproofing for inside a hub
http://endless-sphere.com/forums/viewtopic.php?f=30&t=36786
Thank you spinningmagnets i actually wondering if with this scoops the motor continues to work..
Dum i miss the mountain paths so much. This weekend i will try to cool the motor with ethanol !
I have the same frame - lightning stealth/phantom. I put a 26" wheel on the front though. 35mph feels like nothing, and even with no fairing, efficiency is loads better than an upright. The problem is I need rear suspension too. I'm dismantling that ebike build because of it.
10kw at 80mph isn't all that great. Terry hershner is a bit under that with his upright aero modded zero s. A human powered streamliner is only needing 450watts at that speed.
For that speed run, I was running 125 volts 15 Ah LiPo batteries.
For the controller, Lyen 18 FET 4115 MOSFET
The motor was mounted in a 24" rim w/hookworm 24x 2.50 tire on the rear.
Temps on the motor stayed within perimeters.
However, on 3rd run down runway, the controller did blow smoke. :(
Next attempt will be :
HS 3548 Crystalyte motor … of course the motor will be properly ventilated with scoops.
Lyen 24 FET 4115 MOSFET controller
145 volts 15 Ah LiPo batteries
On paper, I should be able to exceed 100 mph with my recumbent bike frame's drag coefficient.
I'm using 0.07 CdA in the EBIKE Simulator.
It's a shame, they don't rate bicycles tires for 100 mph. I'm still looking.
I think I'll also be looking for a longer runway. I'm at the Cottonwood AZ airport.
Perhaps, Flagstaff Airport, less air molecules to run into at that elevation ( 7,000).
Paul MacDonald
i want a recumbent now, any negatives to one? Only thing i see is <5mph stability, and most have vbrakes
I think they are great for long commutes on open roads, or traveling. Not so hot for inner city stop n go / sidewalk cut-through, potholes, etc. The other main downsides is they take up more space to store or park at racks, possibly less visible in traffic, back sweat in the summer, not as good on poor pavement (can't unweight the bike). Not able to apply as much power to the pedals.
Overall, I like them, but it's not my everyday choice for an ebike setup.
Veloman, you forgot to mention, "Not so good in strong crosswinds."
However, on a beautiful day with smooth asphalt beneath you, there is nothing like opening the throttle all the way.
It's a spiritual experience … when space and time seems to warps all around you. :roll:
Paul MacDonald
