Kabbage
I have just completed my second bike which is sort of going OK, but I've come across a weird intermittent problem that I would value some ideas about. I have one of the new ebikes.ca sensor/sensorless Infineon controllers with the little red flashing light on it (It flashes red at rest, and then goes out when you throttle on - flashes again when you stop...)
After I ride the bike for a while - and it varies between a minute or two and 15 minutes, the controller just turns off - never when riding under load, it's only ever done it when stopped. You stop for a minute, and the controller switches off, so when you go to pull away, it doesn't work any more. (weirdly, it seems to be when I get off the bike at home - it has never happened at stop lights, or intersections! - surely this must be just coincidence!).
I just turn it off, disconnect the power, reconnect the power and turn it back on and it works again just fine.
Any brilliant ideas?
Perhaps it is some controller issue with the connections - I am running a home-made button-throttle- so I will switch to a hall thumb-throttle and see if that makes any difference.
I am also using my new battery which I built from parts from evassemble. Perhaps the BMS is cutting out supply for some reason, or something. I will have to try a voltmeter jammed into the supply to ensure it's getting power to the controller the whole time. Perhaps it's the Anderson connection btw the battery and the controller? But I jiggled that around and it didn't seem to cut out at all.
All in all, very weird. Any more thoughts?
TIA - Kabbage
TIA - Kabbage
