IMPORTANT ANNOUNCEMENT! NEWLY DEVELOPED BMC MOTORS!!!
Re: IMPORTANT ANNOUNCEMENT! NEWLY DEVELOPED BMC MOTORS!!!
Postby solarbbq2003 » Tue Oct 07, 2008 7:37 am
another thing of interest from the graph, they design the motor rpm for use on 36v, so in this test the rpm is 420rpm max no load at 48v, this motor was sent as a 320rpm motor. Max efficiency is 77% so they are loosing maybe 7% due to the gears, the motor alone without gears, efficiency would be around 84 or 85%. No load torque was a bit over 40Nm, not too shabby.
solarbbq2003
Postby solarbbq2003 » Tue Oct 07, 2008 7:39 am
sorry I meant stall torque ( along bottom axis) was a bit over 40Nm.
solarbbq2003
Postby hi-powercycles » Fri Oct 10, 2008 8:58 pm
Hello to everybody!
I have personally tested and also read all applicable Dyno sheets pertaining to the 400W, and 600W motors.
The 400W geared motor at its peak efficiency (about 78%) outputs 300-420 Watts. Above 420 Watts output, efficiency starts to slowly decline. At 36V and 16 Amps, 19 Newton-Meters of torque are present.
The 600W geared motor at its peak efficiency (about 76%) outputs 650-950 Watts. At this particular dyno testing, we terminated at 950 Watts output, while still in its peak efficiency range. Recently, I tested the motor at 1500W input and still got 1120W output power.... This motor in my opinion is underrated from the factory. On 48v and 26 Amps, 23 Newton- Meters of torque are present. Motor RPMS at peak efficiency are almost 50% higher than the 400W motor!
For those interested in hill climbing torque, the 600W motor is the clear champion because it can handle higher current loads much better than the 400W motor. The 600W motor with the Crystalyte 40A or the new BMC 35A controller would both be killer choices.
I also have preliminary test data on the new 1000W motor. Peak efficiency is about 84%. There are no gears on this one, so we will see how it stacks up against the 400W and 600W geared motors! Motor RPMs at peak efficiency are almost 50% higher than the 600W motor!
I will be conducting more tests early next week, including DIRECT head to head comparisons:
BMC 600W Thunderbolt vs. C-lyte 5304 vs. BMC 1000W (pre production test unit)
Should be fun!
P.S. NONE of these motors are made in the BMC India factory.
hi-powercycles
Postby Tom » Fri Oct 10, 2008 11:20 pm
I thought the 1000W motor was the third one you described in the original post, i.e. "when you crave the torque to conquer any hill imaginable, then the new BMC striker is your ticket to the top!" If the 1000W has no gears I'd think the 600W would be better choice for hills?
Tom
Postby hi-powercycles » Fri Oct 10, 2008 11:34 pm
Hi Tom,
It turns out at the moment, the striker is not available as of right now. I am looking into getting the thunderbolt re-wound for more torque and lower speed. I guess I will have to modify the initial post so that I don't confuse anybody. Thanks for your input
hi-powercycles
Postby Tom » Sat Oct 11, 2008 12:11 am
Thanks for clarifying. Is the "striker" just a custom build for you or will it be available from other BMC dealers? How long until we can expect it to be available?
Tom
Postby Microbatman » Sat Oct 11, 2008 9:39 pm
The Thunderbolt sounds like a game changer.
Any pics of the proto-type?
When do you expect the Thunderbolt to be ready?
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Postby John in CR » Sat Oct 11, 2008 10:43 pm
These new BMC motors may very well be fine motors, but my question is when is the unfettered and unsubstantiated advertising going to stop. I mean there are other motors that are more efficient and other motors with proven track records, and most motors are more reasonably priced, so what's the 4 pages of excitement about? I'm sorry but if you have a manufacturer with a track record that is lacking, then at best there's an appropriate place to hype new models that you want to sell months ahead of time, which isn't here. Instead put some actual motors in reputable members hands and let's hear about some real world results instead of this blatant advertising blitz.
John
John in CR
Postby Tom » Sat Oct 11, 2008 11:47 pm
Hey John, personally I'm glad to hear about the new motors since they are what I've been hoping/waiting for, going on 2 years. Non-geared hubs don't work for my application. As far advertising, as long as it's contained to a single thread I don't see it as a big deal. The more information on new and upcoming models the better. I pre-ordered mine last week from a BMC dealer and he told me they should have them within a week. So they are here now, or will be shortly.
Tom
Postby shinyballs » Sun Oct 12, 2008 1:55 am
To you over excited readers.... don't get your hopes up.
Simply put, without any proof of existence and commercially availability -
consider this so called "motor" post VAPORWARE :lol:
shinyballs
Postby hi-powercycles » Sun Oct 12, 2008 7:36 pm
Tom,
Sorry If I haven't been clear. The motors have already been for sale on our website: http://www.hi-powercycles.com/product.s ... oductId=23. We have already sold out of our first lot. You can look at the pictures of the actual motor on the website. I have had this motor on my personal bike for about 10 days now... We have more motors possibly coming in this week. Like I said earlier these "Thunderbot" motors weigh in at 8.9 lbs dry! (motor only)
Here are some pictures of the Thunderbolt on our website: http://hi-powercycles.com/images/122351 ... 74845.jpeg.
hi-powercycles
Postby TPA » Sun Oct 12, 2008 8:15 pm
:shock: :shock: PRICE :shock: :shock:
My Ebike is built with a hub motor purchased from www.ebikes.ca
It has performed flawlessly since it was installed. I cannot
recommend the professional folks there enough.
TPA
Postby hi-powercycles » Sun Oct 12, 2008 8:25 pm
Price will be $899 for 600W thunderbolt with standard 36/48v 25A controller, Twist grip throttle, anodized steel torque arm, and On/Off switch with inline (30A or 40A) fuse in a weatherproof case. Right now, pricing for limited quantities of Modified Thunderbolt with Crystalyte 24-72V 40A controller is $1249.
hi-powercycles
Postby pwbset » Sun Oct 12, 2008 8:29 pm
TPA wrote::shock: :shock: PRICE :shock: :shock:
Yeah... saw that too. I'm sure these are nice and all, but I'd rather do a custom 5305/72v40a with 4+ah of LiMn and a cycle analyst for about the same cost.
(ebike.ca prices)
$515 - Rear 5305
$18 - 5-spd freewheel
$155 - 72v20a pedal first controller (solder shunt to 40a)
$15 - twist throttle
$125 - Cycle Analyst
$360 - 72v4.4ah Lithium
$50 - shipping
$1,238 Total to you door...
EDIT: For what it's worth I'm not knocking hi-powercycles pricing models... I'm just a comparison nut and a bargain hunter... and most importantly.. broke. :mrgreen:
pwbset
Postby hi-powercycles » Sun Oct 12, 2008 8:53 pm
Hey, that sounds like a great deal! For us, we purposely chose not to sell the Crystalyte 23 lb X5 motor because it undermines our motto of high performance and light weight... If weight is not a big concern, x5's are great!
hi-powercycles
Postby Tom » Sun Oct 12, 2008 11:24 pm
delete
Tom
Postby solarbbq2003 » Mon Oct 13, 2008 9:42 pm
how about some torque graphs/pics of internals? my sources are saying these come from india factory so will have to disagree with you there, doesn't really matter as long as they are as good a quality as the chinese factory motors ( which are top notch)
solarbbq2003
Postby hi-powercycles » Wed Oct 15, 2008 1:57 am
Hello everybody,
I actually have some more really good news! I got the first 1000W test motor in! We are calling it "Black Lightning." The motor itself is a nice classy black finish. The shocker here is that the motor only weighs in at 10.3 LBS!!!! Yes, that is not a misprint, The motor fully spoked in a 26" rim with rim tape weighs in a total of 11 lbs, 14 oz. Top speed should be more than 40 MPH at 48V. We are targeting the crystalyte X5 with this one. The actual size of the motor is the same as the 400 and 600W motors... However, this motor is not geared.
I took the motor for a quick spin tonight... It was a fast motor, and also extremely quiet. I will check the speeds I get with a 16 cell Lifepo4 pack and the new BMC 35A controller (with paralleled IRFB 4110 FETs).
hi-powercycles
Postby hi-powercycles » Wed Oct 15, 2008 2:06 am
Here is a pic of the 1000W motor!
hi-powercycles
Postby GGoodrum » Wed Oct 15, 2008 9:10 am
Well, if it is not geared, I'd be very surprised if this would come close to matching the torque of a 5304. Maybe a 4 series. The whole advantage of using a BMC-type motor has been having the torque advantage of the gearing. The problem up to this point has been that when you try to get similar performance to an x5 out of these, the nylon gears couldn't hack it. The metal-on-metal gears handle the power a bit better, but are noisy and waer quickly. The new composite gears, and the higher power version (600W...), sound like big improvements, indeed, but this 1000W looks like nothing more than yet another smallish hubmotor. I'd be a little careful with laying on the superlatives, at least until you've tried it.
GGoodrum
Re: Black Lightning 1000W - Freewheels?
Postby Jerome Daoust » Wed Oct 15, 2008 4:42 pm
Can the "Black Lightning" 1000 W motor freewheel (no drag when motor is not under power) ?
Jerome Daoust
Postby pwbset » Wed Oct 15, 2008 4:51 pm
Jerome Daoust wrote:Can the "Black Lightning" 1000 W motor freewheel (no drag when motor is not under power) ?
:shock: What a minute?! What are you doing here Jerome!? You still paragliding constantly? I used to moderate the paragliding forum under "paraparker" until I smashed my ankle all to hell a couple summers ago. Haven't flown since unfortunately, but will get back into some day as money and nerves allow. Anyway... welcome the world of ebiking! It's also tiny (in the US) just like paragliding!
Awesome. :D
PS - What are you thinking of for your ebike build?
pwbset
Postby Mathurin » Wed Oct 15, 2008 10:39 pm
GGoodrum wrote:I'd be a little careful with laying on the superlatives, at least until you've tried it.
QFT, especially since it's fair to expect motors to pass at least 5X rated power in the field. Like the "250w" bmc, or the "750w" X5, etc.
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
Mathurin
Postby recumbent » Wed Oct 15, 2008 10:49 pm
hi-powercycles wrote: the motor only weighs in at 10.3 LBS! Top speed should be more than 40 MPH at 48V. We are targeting the crystalyte X5 with this one.
Only 10 lbs, must have about 1/3 less copper inside than a 400 series Clyte motor. My (15 LB) 406 motor, powered at 48 volts, tops out at 30 mph.
Ebike in use:
LWB Recumbent bike, Sram i-9 internal gears.
Power supply: 58V, 16 amp/hr, lipo batteries.
max speed: 50 km/h (30 mph),
max range: 40 km's, incl stop&go few times, minimal pedaling.
recumbent
Postby Jerome Daoust » Wed Oct 15, 2008 11:08 pm
pwbset wrote: :shock: What a minute?! What are you doing here Jerome!? You still paragliding constantly? I used to moderate the paragliding forum under "paraparker" until I smashed my ankle all to hell a couple summers ago. Haven't flown since unfortunately, but will get back into some day as money and nerves allow. Anyway... welcome the world of ebiking! It's also tiny (in the US) just like paragliding!
Awesome. :D
Hi Parker, It's great to find you here. :D
Yes, I still paraglide every Saturday, but I had to find something to fill my Sundays, so that's where the ebike come in. I guess I like non-mainstream activities. I have an eZee Quando, and now want more speed, suspension, range. My bike web page.
I almost bought an Optibike, but judged it too expensive for just riding it once a week, not stealthy enough for the paths I ride (noise does not bother me but would draw unwanted attention) and its transport weight too high (can't take the batteries out). Now considering a setup from Hi-Power Cycles. I have been doing my homework with respect to comparing ebikes: Best electric bike decision matrix (open with Microsoft Excel). My current project.
Jerome Daoust
PreviousNext
Users browsing this forum: gestalt, hotrod, MadRhino, pxgator, schmidty_81 and 17 guests
