JEB
On a trike using 16 inch front wheels, there is not much rubber, and at air pressure almost no shock absorption with that size tire. My thought is to take a 20 inch wheel rim, remove the spokes, lower air pressure in 16" tire, insert into 20" rim with contact cement, or epoxy, inflate 16"tire only enough to have some flexibility to absorb road irregularities- suspension? + there is more rubber on the road, being motor driven increased rolling resistance should not be noticed.
Any thoughts?
Any thoughts?
