numberonekiwi
Hi to all the members this is my first post and first ebike kit
It is the xlyte 408 hub motor with
Motor Kit Details:
Engine Type: Internally geared, brushless rear wheel 300Watt-hub motor.
Removable Battery Pack: 36-Volt/9AH Light Weight Ni-Mh batteries
Controller: 20 Amp Immediate Start
Charger: 36-Volt/2-Amp, Fan Cooled Smart Charger
Charge Time: Up to 3-hours
Throttle: Twist-Grip variable speed
Max Speed: 30-35kmph/26" wheel
Cruising Speed: 28kmph
Max Range: 35km
Weight: 9kg additional to bike
Wheel Must be: 26 to 28-Inch, 36 spokes
Frame Must be: 21-Inch or larger
not to sure about the batteries would of prefered 48 v but this is a start I think the controller is only 36 v as well so may need to purchase a second controller at some stage
I am hoping to have this kit in the next few days so that I can test it out cant wait
I do however need some advise on how to fully weather proof this kit as I will be riding in all weather ( we can get up to 50mm rain /hr )but the obvious thing to do is silicon grease around all protrusions to motor controller etc
this is going to be fitted to a 26" 32mm wide rear rim already spoked
Would I get far greater power/torque etc from running 48v ( replacing controoler and ordering two lipo pacs 24v 12ah )
Motor Kit Details:
Max Range: 35km
