What's a good e bike headlight?
alpharalpha
Post by alpharalpha » Jul 07, 2014 11:42 am
I want one bright enough to see the ground ahead of me clearly, would a 12w led do that? I see them on eBay all the time for like $10. No room on my handlebars due to front bag so am thinking could mount it on the front of my lowrider rack, it would be closer to the ground that way too. Are there any particular ones that are preferable? I've never used led before, last I used was a halogen cateye back in the day. The pic isn't my exact rack but basically the same, it's that curved part that goes over the tire that I'm thinking of hooking the light to.
wesnewell
Re: What's a good e bike headlight?
Post by wesnewell » Jul 07, 2014 12:28 pm
Any of the Cree XML T6 lights should work ok.
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
Tench
Post by Tench » Jul 07, 2014 12:35 pm
These are quite good too and can run straight from your main pack.
http://www.ebay.co.uk/itm/12V-85V-Unive ... 2c813e5b99
Project one https://endless-sphere.com/forums/viewto ... ilit=tench
Project Two https://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
bionx 1954
Post by bionx 1954 » Jul 07, 2014 12:53 pm
I have the same as Tench It is excellent, super bright, comes with aluminium clamp that is very easy to mount in different locations, and as mentioned it is 12-85 v. I got mine shipped free and less than 15.00 us.
wesnewell
Post by wesnewell » Jul 07, 2014 1:25 pm
You guys talked me into trying this. Won't work on my 24s pack, but I've got an extra 4s pack I can use with it.
trav
Post by trav » Jul 07, 2014 10:09 pm
I bought this, and it is absolutely brighter than any small light that I have ever seen. It comes with the batteries and the charger, too. Not a bad deal, IMO. Also, you can buy a lens that can widen the field of view for the beam, so that's pretty cool.
http://www.amazon.com/SecurityIng%C2%AE ... e+led+bike
USA Southwest Michigan bike noob.
For safety, always ask yourself this: what's the worst that could happen?
d8veh
Post by d8veh » Jul 08, 2014 4:51 am
I have all the lights mentioned above. They're all bright enough for riding on unlit roads and trails. I was surprised at how good the ones are that run from the bike's battery. It's great not to have to worry about charging separate batteries all the time. You have to add some silicone sealant to make them waterproof because the DC/DC converter is loose in the back of the light where water can get in. The Cree T6 X-ML ones with their own battery pack are waterproof.
alpharalpha
Post by alpharalpha » Jul 08, 2014 7:21 am
bionx 1954 wrote:I have the same as Tench It is excellent, super bright, comes with aluminium clamp that is very easy to mount in different locations, and as mentioned it is 12-85 v. I got mine shipped free and less than 15.00 us.
I don't have any usable space on my handlebars due to a front bag so that's why I'm thinking of mounting it on the lowrider front rack to this part
Maybe I could just add some hose etc to take up the extra space clamping it to that small tube but am considering this one
as I could just bolt it to that tube, again it might make it too weak, if so I could use a clamp to tighten it.
Which one do you think I'll have the most success with attaching to that small front rack bar?
crea2k
Post by crea2k » Jul 08, 2014 9:13 am
Anything with a Cre XML t6 is generally going to be stupidly bright, the beam pattern depends on the reflector though, some have completely dire reflectors which do virtually nothing and you just get a big square beam pattern which is basically just the light coming from the LED. Decent reflectors spread the light evenly across the road, but without trying them or seeing a review its pot luck. Iv got a torch that's got 4x cree xml's in and it was about £175 and is brighter than a lot of car headlights, but its got a really good led driver and reflectors etc which make a lot of difference.
wesnewell
Post by wesnewell » Jul 08, 2014 1:10 pm
A $5 cree xml t6 zoomable flashlight works great. It's more than bright enough. If I run mine on the high setting it's good for 300' or more. The only problem is it will drain an 18650 cell in ~1 hour on high. On medium, it will last ~3 hours.
Ussyamoto
Post by Ussyamoto » Jul 09, 2014 4:32 pm
I run a SecurityIng® Super Bright 3 X CREE XM-L T6 3600Lm with a 12v to 9v converter. Works great, ridiculously bright.
crea2k
Post by crea2k » Jul 11, 2014 3:32 am
There is this one, thats quite good as it runs off the DC outlet from the cycle analyst or your controller if it has one :
http://www.bmsbattery.com/led-bike-ligh ... p-set.html
Tench
Post by Tench » Jul 14, 2014 11:38 am
crea2k wrote:There is this one, thats quite good as it runs off the DC outlet from the cycle analyst or your controller if it has one :
The DC output socket on a CA passes full pack voltage, that light is designed for the 8.4v pack that comes with it, it does not have a built in DC dropper so would not handle the output voltage from the CA without damage to itself and maybe the CA too.
izeman
Post by izeman » Jul 14, 2014 2:50 pm
could ANYONE tell me what this stupid flash mode is for? it's good for nothing. i don't get it ;)
cal3thousand
Post by cal3thousand » Jul 14, 2014 3:00 pm
izeman wrote:could ANYONE tell me what this stupid flash mode is for? it's good for nothing. i don't get it ;)
For instigating seizure mode on unsuspecting passerbys :mrgreen: ?
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Ykick
Post by Ykick » Jul 14, 2014 3:07 pm
Tried 2qty of these recently and pleasantly impressed for $5-$6 shipped - http://www.ebay.com/itm/251506622006?ss ... 1439.l2649
Required a ferrel (I used portion of 4mm bullet housing) over the pinch bolt and grommet for wire entry but all-in-all not a bad beam and runs on 10-100VDC.
- Frank Sinatra
alsmith
Post by alsmith » Jul 16, 2014 10:21 am
Anything with a Cree T6 or the newer U2 emitter. The U2 is newer and a bit more efficient but the light frequency means it doesn't look much (if any) brighter than the T6 in use.
Modbikemax
Post by Modbikemax » Jul 16, 2014 11:44 am
I just bought one of these
http://www.ebay.com.au/itm/231204828453 ... 1439.l2649
It is light weight, ideal for bicycles, and has a nice retro look and the light is pretty good too and works up to 80volts all for $7.19 delivered.
The finish is a bit tinny but what do you want for $7. :?
crea2k
Post by crea2k » Jul 16, 2014 11:49 am
You could always put a voltage regulator between the CA and the light.
mclark999
Post by mclark999 » Jul 16, 2014 2:11 pm
I've used a solid very bright light and a bright flashing light to keep people from walking out in front of me on San Francisco streets. The flashing light keeps cars from cutting in front of me. It's a great safety feature when used with a strong headlight. I turn the flashing headlight off when I'm on the bike trail, but it's a lifesaver on city streets.
Sikk Bikes cruiser with 66cc China girl
Trek FX 7.2 with Bafang BBS02 750W 20A
Trek 5500 with human power
Giant Trance with human power
alsmith
Post by alsmith » Jul 16, 2014 5:52 pm
If that's what you want there are plenty of cheap dedicated led lights that have multiple flash patterns- like the back lights but with a white lens. Flash isn't really needed on a headlight and even gets in the way as you cycle though different brightness. I've got one fitted in addition to a headlight.
I'd like high, low, off only for the main light, fortunately the led headlights I now have OFF-LOW-MID-HIGH-OFF, no flash UNLESS you specifically want it (it uses a different [longer] button press).
cal3thousand
Post by cal3thousand » Jul 16, 2014 6:26 pm
One of my favorite LED lights (that was stolen :x ) has a dedicated flash button. So instead of cycling through the modes, a single click puts you in flash and another click puts you back on the previous beam strength.
jerrydubois3
Post by jerrydubois3 » Jul 16, 2014 10:19 pm
Check out this cool mount. It comes in a double sided version as well. www.johnsoncharger.com
Phasor....108 Volt 100 AMP Cromotor
Raptor........108 Volt 100 Amp CroMotor
Greyborg....84 Volt 60 Amp HPC 3500 Watt
izeman
Post by izeman » Jul 17, 2014 3:31 am
cool mount. one just should not read the faq part about 'watts and mah'. oh man. 'a typical phone needs 5w for a full charge'. they should know better the difference between watt and watthours.
alpharalpha
Post by alpharalpha » Jul 17, 2014 11:18 am
My lowrider front racks were made for suspension forks and when I put them on my rigid steel fork they press into my brakes; might be able to mod it to fit but if not the bolts on the mounts come out a bit for the rack to attach to and I could put a light on each one of those. Do you think them being cree leds matters a lot because I've found a good selection of lights that will run right off the pack and attach to my setup but while most are between 2-12watts only a few are cree t6 xm-l.
