What's a good e bike headlight?
Re: What's a good e bike headlight?
Post by wturber » Dec 05, 2017 8:16 pm
Here's the 5 3/4" Wisamic "DayMaker" Knockoff for Harleys. I mounted some boards to my basket, drilled some holes in the light's heatsink, and then bolted it into place with some L brackets. I used washers to get just the right aiming tilt to keep the light's aimpoint below the horizon. The light on top has it's own battery. I keep it on the bike as a backup headlight, for possible use as a detachable flashlight, and as a front facing flasher for use during the day only.
It throws a shaped beam with a sharp horizon line and lights a fairly wide path. The beam pattern isn't as uniform as I'd like, but it definitely lights the road well at night and seems pretty visible during the day. I could run the high beam during the day if I wanted even more visibility.
"Commuter - DC Booster"
7 x 36v 4.3ah 10s 2P battery packs - Wangdd22 1500W 30A DC Boost Converter delivers 54v and about 1175 watts peak
https://endless-sphere.com/forums/viewt ... =2&t=90369
