fatbikebuilder
- Joined
- May 24, 2014
- Messages
- 54
Here is a Mongoose Beast with a 5305 hub and overclocked lyen 18 fet controller. limno2 10 ah[youtube]cM8ACwGPk04[/youtube]
Jason27 said:That's controller box behind the wheel is a bad idea. It going to get wet and possibly stop working.
mlt34 said:Jason27 said:That's controller box behind the wheel is a bad idea. It going to get wet and possibly stop working.
The location of the controller isn't a problem per se, but the orientation is. The wires should exit down so water runs off of them and not down into the controller. Wires exiting up means the controller will fill with water over time.
Russell said:But most importantly the controller should be painted purple...or green...or maybe yellow.
-R
