DiamondBack, Cyclone 650watts and Dewalt A123 packs
Postby kfong » Mon Sep 08, 2008 10:12 am
4/20/2010 I've changed the original title to reflect the actual bike, the Motobecan has a thread of it's own.
I've been lurking here for 2 months and have decided on my ebike. Motobecan 08 Fantom or 09 700DS, cyclone 650watts and A123 cells. I have collected the A123 Cells, over 40 to date. Will order the Cyclone system and bike later this week. Just wanted to get some input on my choices, good or bad before I pull the trigger. I intend to use this as a mountain bike and a commuter bike. I want to keep it light for the trails. So the A123's are my first choice in batteries. I will probabaly be doing my own BMS system for the batteries. I can do any CNC work if needed to get the system working. Shooting for a decent mountain bike for the trails and having it as a useful commuter bike to boot!
Kin
http://www.embeddedtronics.com/
1st ebike (Diamond Back, 650w cylcone, 3 dewalt packs)
http://endless-sphere.com/forums/viewto ... f=3&t=6348
2nd ebike (Motobecane DS, 600w BMC torque, 10S8P Konions)
viewtopic.php?f=6&t=12654
Outback Mountainboard
viewtopic.php?f=12&t=11137
X-Treme Electric Scooter
Dewalt interface board
http://endless-sphere.com/forums/viewto ... 14&t=10986
My website http://www.embeddedtronics.com/
RC blog http://www.rcgroups.com/forums/member.php?u=23712
kfong
Re: Motobecan 08 Fantom or 09 700DS, cyclone 650watts and A123
Postby etard » Mon Sep 08, 2008 2:00 pm
You cant beat the price of those Motobecanes, I just picked one up for cheap!! Im doing a front hub wilderness energy (shoulda done more research) set up with sla. Since you do cnc, I would make my own rack and seatpost triangulated and notched in the frame so that the rack doesn't slide side to side. Unless you are going stealth, in which case are you gonna mount the battery in the frame? Let me know, I am toying with several setups.
etard
Postby D-Man » Tue Sep 09, 2008 12:37 am
Yeah, they get good reviews. You know how much the bike weighs before conversion etard?
Crystalyte 408 Go-Hub / 20 amp controller /Bontrager Hank 26x2.2 Slicks
Sla pack #1: BB BP 42v 12ah - 5440 miles on $118 total battery cost.(massive cell die-off) Removed from bike.
Sla pack #2: BB HR 48v - 9ah - 1100 miles on $120 - still going
Raleigh road bike - 1500 miles
D-Man
Postby kfong » Tue Sep 09, 2008 8:03 am
They are roughly around 34lbs I believe, not the lightest. The front fork is very heavy. So far I'm moving towards the Fantom. I think it's a better frame. I intend to put the batteries in the triangle part of the frame to keep the CG low, or even on the bottom tube. I will post updates as I move along. Never dealt with the company before and worried about damages in transit. The value for what you get looks good. Any one had any bad experiences with the company? I don't like the fact that they don't have a normal phone order desk. IBEX was another company for the value that I was looking at but they don't have much of a selection this time of year.
Kin
kfong
Postby andys » Tue Sep 09, 2008 9:25 am
A lot of folks have bought bikes from Bikes direct, and I have heard good feedback on that seller.
http://www.mtbr.com/cat/bikes/xc-suspen ... 26crx.aspx
andys
Postby kfong » Tue Sep 09, 2008 10:16 am
Thanks for the link, now on which bike to decide :roll: I just pulled the trigger on the cyclone 650watt setup from
http://www.cyclone-tw.com/order.htm. I ordered the regular kit. http://www.cyclone-usa.com/ did not carry the 650watt version. The reason I went this route was because I wanted an external controller. This gives me more choices on voltages and use of other controllers if needed. From what I gather 500watts and above is quite adequate. I did not go to the higher 1000watt version because I wanted to keep the weight down. More watts require more batteries, and I plane to do some pedalling :wink: Hopefully the delivery won't take forever.
Kin
kfong
Postby kfong » Wed Sep 10, 2008 7:40 am
I went to 3 different bike shops yesterday to see if I could find a better frame for what I want to do and to get a physical idea of how to mount the motor. What I didn't realize is the pivot points on rear suspension bikes might pose a problem with the Cyclone setup. I might need to move the motor to a different area. I've seen some put them forward on the bottom bar, but they end up with a different setup all together, that I'm not familar with. This new configuration has it turning the main sprocket, but it seems to loose out on gear selection. Has anyone been successful with a ebike conversion of the 700DS or Fantom. I need to verify that this can be done before I move on. I still would prefer to use these two bike choices since they seem to be a good value. I tried to do a search on this forum but I don't seem to have any luck finding such bikes being converted. What looks more doable is to have a fixed rear suspension and a seat post with a spring. This isn't my ideal setup.
Kin
kfong
Postby dnmun » Wed Sep 10, 2008 10:03 pm
i think they even have a picture on the cyclone website showing how the mountain bikes with rear suspension is a no-no for the cyclone. there was cyclone kit that just sold on ebay for $280. i thought that was cheap for 500W, but if you go to 48V will you get the full 1000W? the 1000W motor is different and much bigger too. or is this a cyclone clone?http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=380059930781&ssPageName=STRK:MEWA:IT&ih=025
dnmun
1 GW
1 GW
Postby kfong » Wed Sep 10, 2008 10:40 pm
I ordered mine from here, http://www.cyclone-tw.com/order.htm It is the 650watt version. I'll post pictures of it when it arrives. They have a 1000watt version as well, but that motor is bigger than I want. If there is space, I don't see why it won't work on a full suspension. I'm hoping someone has done this. I don't want to speed a $1000 on a bike and find out it's not possible. The drawback of ordering the bike online is I don't have a way to verify the install. Seeing that it would not work on many of the full suspension bikes at the shops I visited has put a damper on things. Both Motobecane bikes have rear suspension lockout which may solve the problem.
Kin
kfong
Postby JB_EB » Wed Sep 10, 2008 11:03 pm
Kin,
I based my e-bike on a Cyclone 360W motor and a full-suspension MTB from this site:
http://www.learsport.com.au/view_produc ... ct=BW3240V
The BW3240 has the pivot point in front of the bottom bracket so the chain length does not change as the rear suspension compresses. I replaced the original Kenda knobbly tires with Specialised Armadillo tyres to reduce running resistance and also to get the required clearance for the Cyclone motor.
While you may not be able to buy this specific bike, you will probably find a similar rear suspension setup if you keep searching.
FYI, I also bought a Shimano Nexus premium 8-speed hub gear and had that spoked into the rear wheel. In my opinion, this gives the ideal e-bike setup. The smaller motor is quite efficient and doesn't need huge batteries. The 8-speed hub gear gives a huge range so the small motor is adequate for both steep hills and faster flat sections. The hub gear can also be changed when the bike is stopped.
Originally, I had a 24V, 10AH LiCo battery that fitted in a slid-in mount in the centre of the frame (inside the semi-circular section). I am now working on a new battery mount for a 26V, 11.5AH a123 battery pack. I am tending towards a saddle-bag style double box with half the batteries on each side of the frame just in front of the seat post.
I found Cyclone Taiwan very helpful and easy to deal with.
BTW, if your setup includes the Cyclone pedals with the built-in freewheel, try to get them to send you the special tool to dismantle the freewheel. My first freewheel only lasted a year. However, when I bought a replacement, I also bought the removing tool and can now regularly dismantle, clean and repack the freewheel with good quality car wheel-bearing grease.
JohnB
26" Learsport BW3240 Dual Suspension MTB, Shimano Nexus 8-sp Hub gear, Cyclone 360W chain-drive, a123 8s5p battery.
JB_EB
Postby kfong » Thu Sep 11, 2008 7:19 am
Hi John,
Thanks for the reply, your bike is very similar to the Motobecan 700DS. I sent a message to the company to have them measure the distance needed to mount the motor. This gives me hope. I really want a full suspension setup and not a seat post on a spring. I wish I had ordered the tools, are they standard? I figure I could pick them up locally. Can you post a picture of your setup, might be useful for others following this thread. I plan to put the batteries in the frame, the Fantom has more room in this area, and the motor mount section looks the same. Could you explain more about stopping the bike to change the hub gear, can't this be done while in motion?
Kin
kfong
Postby kfong » Thu Sep 11, 2008 2:08 pm
Not sure how I should take this. This is the reply from the tech support people from Motobecane. I would of expected a more detail response, like the actual distance measured?
Kin
Will not work, just pedal it.
TH
Can you verify if the fantom has the spacing I need to put an electric motor. See pictures. I need 82mm of space.
Regards,
Kin
kfong
Postby JB_EB » Fri Sep 12, 2008 7:01 am
Hi Kin,
Re the Freewheel remover. Have a look at this link to the Cyclone Taiwan site.
Just to the left of the Cycle Computer, there are a few tools, including the remover in the middle. It is a special tool needed to remove the freewheel bearing.
Re changing gears with the Hub Gear - As you know, a deraileur gear needs to be moving so the chain can climb up or down the cogs. This means that if you have to stop suddenly in a high gear, it is hard to start off again. With the Hub gear, you can change gears whether the bike is moving or stopped.
I'll try to post some pics of the bike later. I had to remove the old battery mount as the LiCo battery died. Currently I have a temporary setup with the new a123 battery pack in the backpack strapped to the rack.
JohnB
JB_EB
Postby kfong » Fri Sep 12, 2008 11:30 am
Hi John,
I didn't realize it until I reread your post that you bought an internal gear setup that resides in the hub. This sounds like a good solution. I was looking at the Divinci hub earlier but read it has friction losses, so I’m going back to gears. I'm not that knowledgeable about bikes, but I’m learning fast. I came across this bike forum from a link in the Rcgroups forum and was surprised at the current state of ebikes. I now have to have one and it gives me a great reason to get back into mountain biking. I’ve always hated the hill climbs but loved everything else about the sport.
Yes, please post pictures of your setup. It will help.
Kin
kfong
Postby kfong » Fri Sep 12, 2008 11:40 am
More terse answers from bikesdirect tech support. Not very friendly it seems. Must not be an ebike enthusiast :| You would think they would be more helpful if it would mean a sale, and it would open up more of a market for their bikes. Perhaps he was more concered about the warranty issues?
Kin
It is not shorter it is a matter of chain growth on a DS frame and there is a cross member that will interfere with mounting it. You would also void the warranty. JUST PEDAL!
TH
Why is the distance smaller than 82mm?
Regards,
Kin
kfong
Next
Who is online
Users browsing this forum: No registered users and 3 guests
