System (U, Motor, Controller) Efficiency
Re: System (U, Motor, Controller) Efficiency
Postby jag » Sun Apr 26, 2009 9:38 pm
1. Efficiency (Watts/mile)
18w/km = 28W/mile
2. Speed (mph | kph)
40-50km/h
3. Gradient (%)
Some small hills up and down the river valley.
4. Pedaling effort (none, light, heavy, extreme)
medium
5. Bike Type (roadster, MTB, trike, others)
Mtb with city slicks.
6. Motor Model
Nine Continent 2809
7. Controller Model
Crystallyte 30A pedal first
8. Battery (Voltage/Capacity)
72V 8Ah NiCd
Martin
jag
Postby Reid Welch » Mon Apr 27, 2009 12:10 pm
1. efficiency: 19 to 20 Wh/mile
2. speed: 20mph
3. gradient: flat
4. pedaling: none
5. bike: steel chinese cruiser 52T front, 16T rear
6. motor: 26" eZee, Bontrager Big Hanks slicks front and rear, 10PSI and 20 PSI, respectively.
7. controller: standard supplied eZee 20A.
8. Battery: 36V/20Ah Ping
9. Cycle Analyst presently set for 13A max to save start-up current. Cruises at about 9A @20mph,
riding style: full upright, leaning backwards, pulling against the long (reversed stem) handlebars.
10. Riding style: wasteful, WOT from starts.
11. Suspicion that planetary geared motors are a bit lossier at cruising speeds than direct drive,
and less lossy at start ups and when lugged.
12. Freewheels great. I will pedal more as I get my bicycle legs again.
13. Fixed gearing about ideal for pedal assisting up to about 23mph.
14. C.A. could be set for 20mph max (or whatever), at which point there is no electric consumption (no aid from motor).
15. Unloaded speed of the eZee with this pack is about 28mph; so I have that option of e-assist up to that speed if I spin like mad. So I have it set for "30mph", to always have some help from the eZee if I happen to feel like spinning pedals.
16. Bike has only 110 miles on it at present and the motor is partially oil filled with ATF.
I hope for =a bit= greater motor efficiency with break-in, with possibly less oil in the fill; less oil churning at the ring gear,
and, of course, reduced power consumption when I add pedal assist.
17. At present am having most fun just going pure electric, but that will change and Wh/mile will decrease in proportion as I grow less lazy-legged.
Reid Welch
Postby fabiograssi » Mon Jul 20, 2009 8:50 am
Sorry about the noob question, but I saw in this topic some setups we have 72v controllers with 48 or 36 volts battery packs. Is that possible? The controller don't cut off the power because of the low voltage? Need some mod? Or the users that mentioned 72v controllers are, in fact, the 36~72 volts controllers (the ones that accept more than one fixed voltage input)???
fabiograssi
Postby aaronski » Sat Jul 25, 2009 3:17 pm
On Road:
1. efficiency: 15 wh/mi
2. speed: 16mph average
3. gradient: 5% up down constant
4. pedaling: medium
Off Road
1. efficiency: 35 wh/mi
2. speed: 7mph average
3. gradient: 10% up down constant
4. pedaling: light
5. LOTS of starts and stops due to riding with DOG. no coasting downhill either, can't go over 7 mph at all.(her top speed)
General:
5. bike: 22#alu full suspension mtb
6. motor: 26" BMC, Specialized Armadillo, 60 PSI
7. controller: standard supplied BMC 30 A
8. Battery: 48v 10ah from Cycle9.com
Broken bike and electric bits everywhere. Some times it's a bike and I ride it.
Have:bmc 9c, bafang, lifepo4,lipo, konions, infineon ctrlrs
Smoked:bmc,9c,bafang, lifepo4,lipo, infineons
Konions appear to be bulletproof...
aaronski
Postby alan » Mon Sep 07, 2009 7:22 pm
22 mile round trip commute 4-5 days/week
1. Efficiency: ~14 WH/mile (battery always strong at end, but assume 7/8ths used per display showing 1 of 8 battery bars).
2. Speed: 18-22 mph (I maintain speed the whole way).
3. Gradient: mostly flat, except for half dozen over/under passes
4. Pedaling effort: full power starts and climbs, regen decelerates, medium pedaling mostly
5. Bike Type: Univega Alpena chrome-molly front suspension/hardtail MTB with Michelin City 1.75"x26" tires/fenders
6. Motor Model: Bionx 350 PL
7. Controller Model: Bionx 350 PL
8. Battery 36V, 9.8AH
9. Bike+rider weight: ~225 lb
alan
Postby wildnrg » Sun Sep 20, 2009 9:59 am
9w/km (14.4w/mile)
45km/h flat, 25km/h 2% up, 61 km/h 2% down.
3. Gradient (%)
Max % Untested
Light
Dual suspension MTB
6. Motor Model
Headline (Cyclone) 500w
7. Controller Model
24A internal
24V 20AH
wildnrg
Postby gerlewis » Fri Dec 18, 2009 10:30 am
You guys quoting your speed via a bike-speedo, have you calibrated it for your wheel circumference? As I found mine was over reading out of the box. I was getting 48kph when in actual fact 44 is the true speed after calibration. Which was annoying as I thought I was doing 30mph.
Ger
gerlewis
Postby patrickza » Fri Dec 18, 2009 5:32 pm
My results after 1000 miles
11wh/km (18wh/mile)
30km/h
3. Gradient (%)
Fairly major hills, steep enough that I don't freewheel going down as it's too fast for comfort.
Light
Dual suspension MTB
6. Motor Model
Crystalyte x5305
7. Controller Model
Crystalyte 72v48A
72V 10AH
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Postby LI-ghtcycle » Thu Feb 04, 2010 10:58 am
Ok, here's my best run thus far:
1) 42 miles
2) Average speed 13MPH (lots of hills, some stretching over 2 miles)
3) Gradient 3-7%
4) Moderate Pedaling
5) Hardtail (Rigid Frame Mid/Late 90's Nishiki w/ Marzocchi Fork) Mountain Bike turned "Dirtable" street bike
6) Amped Bikes Geared (rear wheel) Motor Kit
7) Amped Bikes 15/22Amp controller
8) Dewalt A123 battery pack (28V packs, 2s4p) 53Volt 9.2AH
This is with about 70% pedaling only, I have found I can use the motor to get up to speed and carry it just pedaling, and minor hills I usually just pedal, but my battery is mainly my "get home happy" device, meaning I get a good work-out, sweat a bit but still can walk when I get home! :lol:
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Postby skeetab5780 » Fri Feb 05, 2010 11:43 am
that's slightly scary....that's exactly my best run also....same mileage, stats, hills and pedaling.
except i use a 48v 10ah lifepo4
5 out of 4 people have trouble with fractions
X5404/Tidalforce/Lyen 12-fet/20S LIPO
skeetab5780
Postby ajtest » Sun Feb 28, 2010 11:35 am
All this efficiency talk raises a number of questions I was interested in when a lecturer friend and I set a university project aimed at designing a small device that would capture the data from a Cycle Analyst and a small GPS unit, storing everything on an SD card.
The students have done a great job so far and the hardware just sits on the bike and writes a file with data being written once a second.
The question is what to do with the data? Currently it can be displayed on Google Earth but what would people suggest for the visual display? How about a trace that changes colour from say blue for low power use to red? How would you want to represent the speed-or would you want to do this on its own separate display.
As the height changes are known (both from GE itself as well as from the GPS data) perhaps we might want some way of indicating how much effort the cyclist was putting in along the route.
Just a few thoughts, if you have any suggestions I'll forward them to the student responsible for writing the data display side of the project so the community gets what it wants.
Andrew
ajtest
Postby dozentrio » Sat May 01, 2010 12:21 am
1. Efficiency 25 watts/km 40 watts/mile
2. Speed (mph | kph) 50 kph 32 mph
3. Gradient (%) flat
4. Pedaling effort (none, light, heavy, extreme) none to light
5. Bike Type (roadster, MTB, trike, others) Full Susp MTB
6. Motor Model Unite/Currie my1018z
7. Controller Model ecrazyman 800w 48V brushed
8. Battery (Voltage/Capacity) 44.4V 10Ah EC Power Lipo (5C or so)
My Turnigy 80-100 bike (40V 120A)
http://www.youtube.com/watch?v=GGc1hF5evVE
dozentrio
Postby John in CR » Sat Jul 10, 2010 5:39 pm
1a. Efficiency- Highway- WOT 50-59mph=55wh/mi (80-94=34wh/km)*
1b. Efficiency- Highway- 40mph=42wh/mi (65kph=26wh/km)*
1c. Efficiency- Typical stop and go 35-40mph cruise=50wh/mi (55-65kph=31wh/km)*
2. Weight- 365lbs/165kg**
3. Pedal effort- 6-8 strokes at start 50% of the time (the single speed gearing can't keep up)
4. Bike- Custom from used MTB+steel tubing, soft front/hardtail. 60" wheelbase, 26" motorcycle seat height. 24" bike 1.75" front, 19.5" dia motorcycle 3" street knobby on back. Both inflated to 32psi.
5. Motor/controller- 1200W rated motorcycle hubmotor and matched 60V30A 15fet Infineon controller running at 74V nominal (20s Konion LiMN), and shunt modified to 50A.
* - Actual is slightly higher, because measurements taken from energy going into the battery from the charger, not out of battery to controller like a Cycle Analyst would give. Typical riding is jackrabbit style, and more hills than the slight rolling grade of the highway tests, which were non-stop except the first mile from the house. The variance in the WOT speed of the highway was the range of speed caused by varying grades. The highway tests were with a slightly tucked position, and upright position slows WOT speeds 2-3mph.
**Much of the typical efficiency in everyday use includes significant extra loads from this bike+me weight. eg 150lbs of kids and books on school days, groceries, hardware, etc.
John in CR
Postby kentlim26 » Thu Jul 22, 2010 12:05 pm
hi everyone
my motor from Conhismotor of 1000watts, controller 1000watt also, is supply by conhismotor,
just in going 3months time i have done 1700km. this kit is alot many times better in anyway
compare with cyclone. Everything in + shipping USD250 .. 3days i got my this baby ! thinking
for cyclone kit, think for hub motor is much Superior in anyway.
1.speed i got it on top speed is 59.8km/h, on full throttle it can easily achieved 51km/h
2.gradient, a little slop, mild
3. peddling - nothing , nil.
4. moutain bike black one , http://www.flickr.com/photos/kentlim26
5. Wh/km is 10.3229 ~ 15.46 watts.
"several of my test and measure per watts/ km = is often seen 9 to 11.77wh"
6. i can see my turnigy meter the peak watts is only 1533watts
7. it can also take very little watts per km. ONLY 6.65watts for 1km for 18-20km/h
8. im using a lower quality lifepo4 battery, from vpower. this battery can only do 1 or 2c.
"this vpower battery is not for cyclone motors, which can draw 50amper or 2200watts.
it kills all the 1 or 2c battery.
9. the worest slop i ever seen my top speed drop to 35km/h.
28/july/2010
a recent test.a 98% hard full throttle 49km- 52km/h , wh/ km is 15.4+
80% throttle, speed 38km/h - 42km/h, wh/ km is 12.88watts. peak watts is still same
1500+watts. no changed
04/08/2010
i run until my battery flat.. vpower 48v 20hr gives only 710.3watts and range is 95.22km.
this can easily more efficient then cyclone max range. cyclone 900watts draws too much
current, even i do very less throttle, it just cannot improve range from 60Km. last ride it
got from Cyclone 900watts kit only 55km.
17/08/2010.
amper peak watts hit 32.96. total watts hit 1614. that is so much higher from the cells
38140s. bMSbattery 48v 12hr.
cheers
kentlim
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Postby minde28383 » Wed Oct 13, 2010 2:53 pm
kentlim26 wrote:hi everyone
28/july/2010
04/08/2010
17/08/2010.
cheers
kentlim
Hi kentlim26,
your results are the ones I would like to see from my setup: "9C", "ping 48V 15ah", "25Amps stock controller". Usually my trips speed varies 20-30km/h and I constantly see ~18Wh/km. I do sometimes peddle.
How did you manage this "speed 38km/h - 42km/h, wh/ km is 12.88watts"? What's your weight; do you go flats or sometime down hill?
current setup: Giant NRS, 2806, ping 48V 15Ah, stock Infineon
former setup: Trek 4300, 9C, ping 48V 15Ah, Infineon 25A, ~18Wh/km, max speed 45 km
minde28383
Postby aaronski » Wed Oct 13, 2010 6:15 pm
here's some interesting stats: 9c 20" wheel, 10 ah lifepo batt. 12 fet Lyen controller. commute is 7 miles.
average with controller set to 24A is 3.1 AH per ride
Average with controller set to 70a is 5.7 AH per ride
average speed is the same. 17 MPH.
aaronski
Postby DAS100 » Wed Oct 13, 2010 7:07 pm
This is my first post, and I’m glad I could contribute. I recently completed building my first electric bike, and last Saturday went on a 45 mile trip with it. The bike has a Cycle Analyst and I confirmed the speed and mileage the CA displayed using a GPS. The following information is based on the 45.37 mile trip I took.
Facts about the trip:
The trip started in North Phoenix. I rode to the middle of downtown Phoenix, then to downtown Scottsdale, and then back to the location I started from (using a different path). I used Bike Paths as much as possible. There was a moderate amount of stopping and starting for street signals & signs, traffic etc.
1. Efficiency 22.6 wh/mi
2. Speed: I cruised generally at 15-18 mph, occasionally slower 7-12 mph (~7% of the time) when going over rough terrain, or sight seeing. (I did a speed run, and reached a top speed of 27.2 mph on flat terrain). CA indicated an average speed of 12.1 mph for the entire trip (CA does not include the time when the bike isn’t moving, but does include anytime the bike is moving, (even if walking it across a crosswalk).
3. Gradient: Flat
4. Pedaling: None
5. Bike: Inexpensive Mongoose XCom 700cc Men’s Bike with thorn resistant tubes, and tire sealant. Total Weight of Bike, Equipment, and Rider is 335 lbs.
6. Motor: 9C 2807 (ebike.ca)
7. Controller: Infineon Controller 25Amps (ebike.ca)
8. Battery: 48 volt 20 Amp V2.5 Ping Battery
Total Amperage drawn from the battery during the trip was 19.95 amps. I stopped at about 35 miles and charged the battery with a 5amp charger for 55 minutes, just to make sure I had enough juice to make it home.
Cruising on level smooth ground at 16-18 mph (no stops) and no pedeling, I’m averaging about 17-19wh/mile.
Hope this helps.
DAS100
Postby kentlim26 » Wed Oct 13, 2010 8:59 pm
hi minde28383,
I pedal almost nothing, max is 5%. my this throttle is 3/4 Plus ( but will not hit full throttle), the speed will run easily 42km/h. Im weight only 65kg ~ 68kg. Most of road is very flat, if there is slop, the slop will be less then 10degree, >200meters. PSI air pressure on tyre is 50 ( i think this helps too ) most of my time, i am taking 12+ watts/ km. 9C magnet size i heard is 28mm, for this CHM motor is 32mm. I think it makes a different. I have open up hub motor once to repair the hall sensor, so at the same time i also measure the magnet size.
The most interesting discovery for this efficiency, i had also compare with cammy_CC 48v 500watts kit. I plug in my Turnigy meter and do a testing for full throttle is 40km/h max, but it will takes 15.44watts/ km at least. said to be a small motor, should be taking lesser in watts/ km but it didn't. i also wondering what is the watts/ km for 36v 200watts kit ? im living in singapore, land is almost 75% - 80% flat.
cheers
kentlim
kentlim26
Postby pcarlson79 » Sun Nov 28, 2010 7:45 pm
Hi Well I have 2 eBikes. One for everyday work commuting, must be silent and reliable, and a FUN bike :)
Work Commuter:
1. Efficiency: 19-21 watts/km
2. Speed: 31kph coast up to 40kph peddling
3. Gradient: very small hills
4. Pedaling effort: Moderate
5. Bike Type: Giant Mountain bike, hard tail, steel front forks with no suspension. 21speed
6. Golden motor 36v 500w
7. Controller: Kelly KBS72121 (24v-72v 50A controller)
8. Battery: Ping 36v 30Ah. Gives about 70Km range
FUN eBike:
1. Efficiency: 28-35 watts/km
2. Speed: 55kph coast up to 75kph peddling
3. Gradient: ANYTHING
4. Pedaling effort: None, peddles spin too fast
5. Bike Type: Dual suspension mountain bike 5 speed rear de-reullaeur (spelling?)
6. Cyclone 1200w 3 chainring kit. Draws 1800watts constantly
7. Controller: Standard Cyclone 1200w controller
8. Battery: Conhismotor 48v 25Ah. Gives about 40Km range at full throttle
pcarlson79
Postby Cold-E-Commuter » Sat Dec 11, 2010 12:03 am
Here is the spreadsheet I have created. Hope this is helpfull. Let me know what you think.
Ride Log.xls
(3.2 MiB) Downloaded 230 times
You will need to unhide rows and columns as needed.
Trek 3700 MTB
NC2806 in 26" Front Hub on Rockshox XC32TC fork w/ Avid BB7 disc brake
Infineon 12xIRFB4110 mosfet controller
Ebikes.ca SS Dual Torque Arm and CA/DP Large Screen Unit
CA Data Logger w/ GPS
Schwalbe Marathon Green Guard tires 26x1.5 at 70 psi
Cold-E-Commuter
Postby Cold-E-Commuter » Mon Dec 13, 2010 9:54 pm
Speadsheet downloaded 8 times! No comments? Wow, is it that bad?
Trek 3700 MTB
Cold-E-Commuter
Postby edcastrovalley » Tue Dec 21, 2010 12:57 am
Cold-E-Commuter wrote:Speadsheet downloaded 8 times! No comments? Wow, is it that bad?
Actually this is a really nice spreadsheet. It's a good snapshot of winter riding with lots of information here. I especially like the cost per mile column. You would have to go 100 miles to rack up 2 cents in electric costs. I'm curious as how you are measuring your charger kwh to get charger efficiency.
edcastrovalley
Postby Cold-E-Commuter » Fri Dec 24, 2010 12:35 am
I am measuring the charger in two ways. I have it plugged into a Kill-O-Watt from the wall and a Watts-Up going into the battery. That is where the info comes from. A bit intensive to keep all the data updated after each ride, but worth it to me.
Trek 3700 MTB
Cold-E-Commuter
Postby Cold-E-Commuter » Tue Jan 04, 2011 8:58 pm
Wow, now 25 downloads but only one comment. I hope this wasn't a waste of time for everyone.
Trek 3700 MTB
Cold-E-Commuter
Postby Cold-E-Commuter » Tue Jan 11, 2011 1:02 am
edcastrovalley, I have recently reviewed a post viewtopic.php?f=14&t=14934 and think that my calculations for charger efficiency are wrong. Doctorbass brings forth the "PF" indicated factor and this charger appears to be only 35 or 36 % according to the PF on the Kill-O-Watt. I have been calculating it based upon Kw used (via Kill-O-Watt) compared to input into the battery (via Watt's Up). For example, line 50 of the spread sheet shows .69 Kw used (or 690 watts) and 547.2 watts input into the battery. Yes this appears to be 79% but I am sure there is more to it than that. Here is a pic of the charging station.
(190.29 KiB) Downloaded 3 times
As you can see, the Kill-O-Watt measures from the wall to the charger and the WU measures from the charger to the battery. Hope this helps.
Trek 3700 MTB
Cold-E-Commuter
PreviousNext
Who is online
Users browsing this forum: ecowheelz, Eskimo and 10 guests
cron
