System (U, Motor, Controller) Efficiency
Re: System (U, Motor, Controller) Efficiency
Postby Bike_on » Sun May 01, 2011 9:56 pm
1. 20 whr/mi
2. 24-25mph
3. mixed grades, 1300 ft gain.
4. moderate-hard
5. Optibike 850
6. Motorized bottom bracket
7. Optibike proprietary
8. 36V, 20 ahr LiCo
Stats
Giant Lite Optibike Optibike Optibike
2007 2008 2009 2010
Total Bike Miles 3231.8 4016.0 3661.8 4975.2
Total Bike Hours 197.0 185.3 159.7 233.8
Total Average 16.4 21.7 22.9 21.3
Commute miles 2398.5 3087.7 3452.65 4510.0
Commute Hours 139.4 134.2 147.33 198.4
Commute Average 17.2 23.0 23.4 22.7
Total Commute Days 87.0 88.0 92.0 115.0
Estimated Working Days 235.0 230.0 230.0 230.0
% Commuted 37.0% 38.3% 40.0% 50.0%
% bike miles for Commute 74.2% 76.9% 94.3% 90.6%
Equivalent FULL Commutes of 42+ miles 45 59 75.75 100
Equivalent commute rides of 21+ miles 90 118 151.5 200
Actual commute rides of 21+ miles 48 98 130 172
Actual commute rides of 15+ miles 5 4 4 0
Actual commute rides of 10+ miles 42 24 33 55
Actual commute rides of 5+ miles 68 20 8 2
Number of weeks of 100+ miles 14 19 16 37
Number of weeks of 200+ miles 0 5 2 0
Savings: per round trip $22.3 $21.4 $21.3 $21.3
Total Savings $1,001 $1,261 $1,613 $2,130
Bike_on
Postby FFR Trikes » Sun Jul 17, 2011 8:37 pm
1. 20.6 wh/mi
2. 30.5 mph average speed on a 16 mile ride
3. rolling with some moderate hills in western North Carolina
4. Medium-heavy
5. KMX Tornado
6. Astro 3220
7. CC HV160
8. 44.4V 25 Ah LiPo
This was on my personal FFR Transition One.
Upgrades: Schlumpf HSD, 6T Astro 3220, prototype tailfairing
The tailfairing made a pretty significant difference. I do almost all of my riding at full throttle, which is 31-32 mph. Typically I see efficiencies around 25 wh/mile. The tailfairing dropped that number to 20 wh/mile on it's first run. We'll be doing more development with carbon tail fairings in the future.
-Tommy
Specializing in High Performance Ultra-Lightweight Pedal-Electric Vehicles, Recumbents, Parts and Accessories
http://www.rideFFR.com
FFR Trikes
Postby Skippic » Sun Jul 24, 2011 2:54 am
Very interesting stuff. Maybe we could do another thread setting as many parameters as we can, so as to restrict the number of variables.
For example:
Constant speed
No wind
No hills
No pedaling
1. Instant watts used at 10, 15, 20... [mph]
2. Bike Type (roadster, MTB, trike, others)
3. Motor Model
4. Controller Model
5. Battery (Voltage/Capacity)
I understand this is only for people with a CA or a watt meter, but it would provide a way to compare the efficiency of different setups.
Skippic
Postby veloman » Sat Aug 20, 2011 12:38 am
1. Efficiency: 10-13 wh/mile
2. Speed: 15-18mph depending on grade, usually at 17.5mph on the flats
3. Gradient: 0-12%, varies much, but if hilly I pedal a LOT more, so it evens out.
4. Pedaling effort: moderate on hills and starts, none on flats
5. Bike Type: Mongoose Sycamore rigid mtn bike
6. Motor: cellman's MXUS 250w geared hub
7. Controller: 13.6amp peak 36v
8. Battery: 36v 11ah lifepo4 pouch (don't know name)
I've had as low as 6 wh/mile when pedaling about 50% of the time and nearly flat conditions. I think that was my first ride on it and I babied it since it was wet out. 12 wh/miles seems to be the standard. I use to get 16wh/mile on a completely different setup, 450w unite driving the cranks with barely any pressure on the pedals, averaging 22mph.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby GaryJS » Wed Sep 21, 2011 10:21 am
Time for me to clock in with my values from my first clocked ride :)
1. Efficiency: 11.16 wh/mile
2. Speed: average 16.3mph
3. Gradient: -14 to +13%
4. Pedaling effort: low to moderate (mixed)
5. Bike Type: Raleigh Mountain bike
6. Motor: vpower 24v 250w motor (unsure who actually makes it or real rating? - see pics in build thread)
7. Controller: Vpower 24v 250w controller (unsure who actually makes it or real rating? - see pics in build thread)
8. Battery: 36v 12ah SLA
Build thread: http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=30405&p=439497#p439497
Route: http://maps.google.com/maps/ms?ie=UTF&msa=0&msid=211150202879810676935.0004ad6e4540615caefe0 (had to stop a couple of times for my lycra clad friend to catch up :)
GaryJS
Postby Hugues » Wed Sep 21, 2011 1:35 pm
my turn
1. Efficiency (Watts/mile) = 47 (that figure seems to be on the high side compared to other posts, :( )
2. Speed (mph ) = 16
3. Gradient (%) = 10
4. Pedaling effort light
5. Bike Type MTB
6. Motor Model Crystalyte HT (something)
7. Controller Model Infineon 40A
8. Battery 72 V 10 ah
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby Danos » Fri Sep 23, 2011 6:02 am
Numbers from my short (4.7km) commute to work. Short steep climb then descent with some flat. Mostly WOT with moderate pedaling.
1. Efficiency (Wh/km) = 18
2. Speed (kph) = max 52kph
3. Gradient (%) = up to 10%
5. Bike Type: MTB hardtail Trek 4100
6. Motor Model: Mac 500w rear
7. Controller Model: Infineon 30A
8. Battery: A123 16s4p 58V 9.2ah
Danos
Postby LI-ghtcycle » Mon Oct 10, 2011 2:20 pm
Just wanted to move some Efficiency info from my earlier build thread here:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=25082&hilit=mid+drive&start=45
And here is a basic thumbnail of the info:
Distance: 8 miles
Average slope: 3 - 12%
Watt Hours Per Mile: 10.75 (86 WH's for 8 Mi. )
Amped Bikes 9 x 7 DD rear hub motor used as mid-drive, using 1/8th bicycle chain from motor to NuVinci rear hub with a 3 to 1 single stage reduction (13T to 27T, using track a cog on hub motor and sprocket from Staton Inc.) with an effective gearing range for 7 to 30 MPH.
And now my latest build, I have done a longer trip to include the same hill with the exception of the few blocks of 10+ % grade hill (my gearing is too tall, have to wait to get proper gearing to get the full potential of this new motor) and using even less Wh/Mi.
Here are the stats:
Distance: 42 miles
Average slope 3 - 10%
Watt Hours Per Mile: 8.7
(This second test was on a day with virtually no wind, at at about 56F temperature)
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Postby cwah » Mon Oct 10, 2011 2:56 pm
I don't have a cycle analyst. But I manage to do that:
Max distance: 18 miles total distance on throttle only (mainly flat road)
Max speed: 23mph (but most of the time I'm between 15 and 23 mph)
Average: 14 mph.
Battery: 36V10A Li(NiCoMn)O2
Is it good efficiency?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby gartmu » Wed Nov 02, 2011 5:13 pm
1. Efficiency (13Wh/mile)
2. Speed (16mph )
3. Gradient (total climb: 582 meters vertical; total descend: 597 meters vertical)
4. Pedaling effort (none)
5. Bike Type (MTB)
6. Motor Model (Bafang BPM 48V500W Code12)
7. Controller Model (KU123 500W 12Mosfets 48V 28A)
8. Battery (Headway 48V 9AH)
My bike weights 25kg and I weight 83Kg. My height is 1,82 meters.
gartmu
Postby GaryJS » Tue Mar 27, 2012 9:59 am
Just a little update now that I'm running on Lipo:
1. Efficiency: 10.5 wh/mile
2. Speed: average 24mph
4. Pedaling effort: moderate - high (mixed)
7. Controller: Vpower 24v 250w controller (unsure who actually makes it or real rating? - see pics in build thread - clearly OK at 49V 20A)
8. Battery: 12s2p (49Vish)
Build thread: http://www.endless-sphere.com/forums/vi ... 97#p439497
GaryJS
Postby leffex » Mon Jun 25, 2012 2:18 pm
1. Efficiency: 23 wh/mile (estimate at 26km ride usage of 8ah, calculated uphill for 5km, 2km flat, downhill 3km, 2km flat, 1km uphill, x2)
3. Gradient: -10 + 10 I guess (22mph uphill, 26mph flat, 32mph downhill, )
4. Pedaling effort: moderate-high
5. Bike Type: Mountain bike 26", 1,5" tyres
6. Motor: tongde 5kg rear hub DD
7. Controller: sensorless 48v 25a
8. Battery: licomn 48v 10ah using 8ah
My old bike 300W. 2012-06- 2012-08
New bike Leaf 1000W, 54V,30A,10AH) commute 2012-11-
leffex
1 W
1 W
Postby SoSauty » Thu Jul 26, 2012 4:15 pm
Set up for Enduro time trial:
Baby BaFang8fun
20A Lyen mini-monster controller
18Ahr 12S/45V Lipo
.710W for 70mile or 10.25Watt/per/mile
average 17mph until the last 12miles
(dang my feet and nuts were numb)
Set up for Adams Kart racing June16th:
9 Continential 24" wheels
30A Lyen mini-monster controller
8Ahr 20S/74V Lipo
50 Watt/per/mile
17 to 33mph racing
(dang it felt fast)
http://www.ebikes.ca/index.shtml No.#1 Trusted E-bike online sales!
3 hardtail MTBs:
-48V Lith-ion 10.5amp hr-408 C-lyte
-BPM 8FUN[*STOLEN]
-run Century rides w/Q100 mini
3 folders:
-20" wife's BaFang,
-20" TurnigyMax50cc airline suitcase folder,
-24" Stewart/Hass 9C; 3.5K/40mph fun racer
SoSauty
Postby AFT » Thu May 23, 2013 1:29 am
Our best ever efficiency run was done on 14/1/13 with our all new EMAX upgrade kit.
Distance 18.4km, All test were done at 17 AMPs current limited and FUll throttle for consistency, and 3 tests done in each group to get an average.
Mid level peddling
Efficiency: 20.55 wh/mile ( 12.8 wh/km)
2. Speed: average 21mph (34.7km/hr), Max speed 57.8 kmh
3. Mostly flat but some sections Gradient: -10 + 10
4. Pedaling effort: mid level peddling
5. Bike Type: Mountain bike 26", 1,75" tyres
6. Motor: AFT custom EMAX mid drive 36v 960w, run at 33v a123
7.Total bike weight 37 kgs
8. Battery: a123 26650, 10 series 33volts
No peddling same track
Efficiency: 21.52 wh/mile ( 13.4 wh/km)
2. Speed: average 20.1mph (32.35km/hr), Max speed 50 kmh
4. Pedaling effort: GHOST peddling
22/8/12 Baseline stock setup without EMAX upgrades
Efficiency: 22.29 wh/mile ( 13.8 wh/km)
2. Speed: average 15.71mph (25.29kmh), Max speed 49.9 kmh
APPLIED FUTURE TECHNOLOGIES
Specialising in high performance and high efficiency custom electric mid drive conversions kits.
Website : Af-tech.com.au
Email : Aft_ebike@hotmail.com
Since 2009 we have reached 8000km of real world reliability and efficiency improvement testing on our mid drive kit and testing is an ongoing process ….
Our Ethos "Proven design through long term real world reliability testing"
AFT
Postby Tommy » Fri May 24, 2013 8:02 pm
1. Efficiency (Wh/km) = 48Wh/Mi
2. Speed (MPH) = 12 to 22
3. Gradient (%) = up to 8%
4. Pedaling effort: None (no working pedals)
5. Bike Type: DIY Delta Trike
6. Motor Model: Daul 24V (gearmotors from electric scooter)
7. Controller Model: SaberTooth 2X25
8. Battery: Dual SLA 24V 20A (parallel) (pulled from earthwise cordless lawnmowers)
Tommy
Tommy
Previous
Who is online
Users browsing this forum: bose, IHatePedalling, Kepler, rp3, Trailblazer, wesnewell and 11 guests
