mat h physics
Is there a, currently, off the shelf controller which uses dual power sources?
Here is purpose:
While some claim "homemade battery pack", here is how supercaps can be fabricated: [youtube]https://youtu.be/iD2rVGjG2HQ[/youtube]
[youtube]https://youtu.be/nRM0x-AqrTk[/youtube]
Ladder logic, antiquated?
So how practical would it be to have two controllers. One regen system on the front, as 75-100% of braking power is in the front, that charges a supercap bank. And a second system that would use both a battery AND the supercap bank in series, to power the rear.
Of course there should be switch/relay to use only the battery when the supercaps are discharged.
Is there a charger design that would work well to charge supercaps on the go? Most 110v outlets will be limited to 10-20amps. How practical would it be to plug into a "public" outlet to charge the supercap bank?
While some of these are just "what if", it takes a comprehension of WHY it won't work to advance the tech. If you want to belittle this mental exercise, as is so often the case in forums, fine just give an explanation as WHY it's not practical. The objective is to learn.
Here is purpose:
