Help finding a solution to Bafang gear stripping
Re: Help finding a solution to Bafang gear stripping
Postby Ben » Fri Nov 07, 2008 3:50 pm
set wrote:Why haven't these gears transfered onto the ebike scene?
With helical gears you get some axial thrust because the gears are cut at an angle.
They're also a lot harder to manufacture that straight cut gears and therefore more costly.
Having said that, some motors use them. The main one I can think of is the P2a motor, which has very high quality gears.
Helical should be stronger than straight cut because you get more than one tooth engaging at any given time. They're quieter too.
Ben
Postby voicecoils » Sat Nov 08, 2008 1:43 am
It might be a better mechanical approach for this application, I agree. Thanks for the suggestion.
As ben points out, harder to manufacture though. The motors are low cost production to the extreme IMO in mechanical design, materials, and assembly. With that in mind, it is not surprising that the manufacturer went for simple strong straight cut.
It's not something that could be retrofitted either. A new pinion and ring gear would be required and neither are removable unless I am mistaken.
voicecoils
Postby docnjoj » Sat Nov 08, 2008 12:57 pm
I was about to take a picture of my P2A motor that broke after about 3000 miles. Surprisingly, it was the steel gear that threw the bearing rather than one of the two nylon planetaries. Absolutely best motor I ever owned! Too bad Brett cant get them any more!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby docnjoj » Sat Nov 08, 2008 3:10 pm
Uh oh! Houston, we have a problem! On my maiden voyage of my new Ping 48 volt 20 ah battery, we have a Bafang p-nut butter crisis! 6 miles out I hit a bump and the motor just ground around and stopped turningm making really horrid sounds! So here is a first gear destruction of a Bafang on 48 volts! I will order a set from Knuckles, but it seems there really is a problem with gear longevity. Too bad, cause its otherwise a great motor!
docnjoj
Postby voicecoils » Sat Nov 08, 2008 4:50 pm
Sorry to hear docnjoj :(
Here's a list of Endless-Sphere members who've stripped their gears:
Voicecoil: 80V setup twice in a 26" front wheel
Docnjoj: 48V setup once in a 20" rear wheel
Knuckles: 72V setup at least twice in a 26" wheel
(once from accelerating 'shock' once from a friend applying the brake while accelerating)
dazzassj6: 60V setup once in a 26" rear wheel
others?
I'm further convinced that a more robust solution is truly needed.
voicecoils
Postby John in CR » Sat Nov 08, 2008 6:37 pm
The machine shop quoted me a price of about $12/ea to make better plastic gears including the bearing. He called the material what sounded to me like "tylon", and said it would perform far better than the nylon gears. He said he could do metal gears for a bit cheaper. I don't know about you guys, but over $40 with shipping for 3 little plastic gears plus the work involved, all to fix what is essentially a $50 motor, doesn't seem to make a lot of sense.
Maybe I'll be more amenable after I give mine some rough treatment and strip the gears, though I do already have a backup set, including 1 metal one with a bearing.
Let me know if you guys want to look further into the fabrication, and find out exactly the material he wants to use.
John
John in CR
Postby docnjoj » Sat Nov 08, 2008 6:50 pm
Hey John ! Thats dirt cheep! If they work out, maybe a group buy would be in order! SDP wants $30 for gears like them, and I believe it doesnt include bearings!
Anyway, the low retail on those motors is about $150-200!
otherDoc
docnjoj
Postby voicecoils » Sat Nov 08, 2008 7:27 pm
John in CR wrote:The machine shop quoted me a price of about $12/ea to make better plastic gears including the bearing. He called the material what sounded to me like "tylon", and said it would perform far better than the nylon gears. He said he could do metal gears for a bit cheaper. I don't know about you guys, but over $40 with shipping for 3 little plastic gears plus the work involved, all to fix what is essentially a $50 motor, doesn't seem to make a lot of sense.
$12/ea is reasonably cheap considering there is gear stock material, sealed bearing, and machining time involved. Maybe your guy was saying "torlon"? See HERE from this thread.
Yes, the motor is not an expensive motor, especially if bought in bulk but its value is in the use it can provide. If it can't work reliably for any distance or any serious power then the value is extremely low. If you plan to do a long distance trip, the low weight of the bafang would be great but who wants stripped gears on the road? My interest in replacement options, ranked, are:
* 3 composite gears impregnated with metal like the new BMC 'thunderbolt' is using
* 1 metal gear (if it can do the job alone) and 2 stock nylon gears
* 3 metal gears
* 3 better plastic gears
How did you get the bearing machined into the metal gear you've got? I don't think it's a matter of 'if you strip the gears' more a case of when.
voicecoils
Postby fechter » Sat Nov 08, 2008 8:31 pm
When the alternative is a $500 motor, then it makes much more sense. I'd say go for the metal gears.
fechter
Postby John in CR » Sat Nov 08, 2008 9:12 pm
fechter wrote:When the alternative is a $500 motor, then it makes much more sense. I'd say go for the metal gears.
I consider that a fleecing, not an alternative. I can probably find a decent used engine for a car that's good for a whole lot more miles for that price, or there are also a number of multi-kilowatt durable brand new electric motor choices in that price range.
At least it only takes one gear going with metal, so I'll take your advice.
John
John in CR
Postby Knuckles » Sun Nov 09, 2008 11:49 am
I am reluctant to order any more Bafang motors until a supply of metal gears is available.
I am still riding my "bearing-less" metal gear (same as I sent to John in CR).
But John’s approach to fabrication of an exact replica in metal is correct.
The Bafang is a great motor for it's weight but the plastic gears are clearly a weak link.
Gear failure can occur under normal riding conditions.
Two modifications to the Bafang motor ...
1) One or more metal gears
2) Thicker phase wires (no hall sensors) on a sensor-less mod Infineon.
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby Rassy » Sun Nov 09, 2008 12:24 pm
Hi Knuckles. Just a dumb question, but I didn't think you could use a sensorless controller on a free-wheeling motor. For the record, I have no understanding of how the motor/controller work together.
I am just in the process of testing a couple of Bafang's that I plan to play nice with at 48V, but am following closely what you and John in CR are doing with metal gears. Thanks.
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Postby docnjoj » Sun Nov 09, 2008 12:52 pm
Agreed! I don need no steenkin thicker wires! I just need gears that can stand up to 48 volts! Also think quiet. I hate to bring this up at this critical juncture, but the squishey nylon was really quiet. My P2A with 1 steel and 2 nylon was also very quiet. But it had helical gears! I hope we dont end up throwing the baby out with the bath water. Thanks Knuckles!
otherDoc
docnjoj
Postby Freddyflatfoot » Sun Nov 09, 2008 4:10 pm
I'll keep following this thread with interest!
At this point, I am still more than happy with my Bafang @ 36v. As it also an overvolted motor anyway, up from 24v, the performance is still respectable in hybrid mode (me!) I have done over 3500 k's on mine, and its still going strong.
However, I am concerned that there have been a few motors stripping their gears. :(
Knuckles, hang in there with theses motors! I would buy another, should I need to.
If I ever strip my gears,I would want to know that replacements, or a solution is available. If you guys come up with a suitable replacement gear, I think I would be tempted to 'upgrade', just to ensure the longevity of my existing motor.
On the other issue of wiring, is it worth doing that, or going sensorless?
Can I upgrade my Ananda controller to sensorless?
Rob
Current setup, 250 watt/24 volt chain drive setup on Jamis MTB, 24 volt, 10 AHr Yesa LiFePO4 pack. 15A controller. (increased to 20A, currently dismantled) (motor sold)
Home built recumbent trike, 350 watt, brushless, geared, hub motor, 36v/10AHr 'Duct Tape' LiFePo4
Freddyflatfoot
Postby voicecoils » Sun Nov 09, 2008 4:29 pm
Knuckles,
Can you take a youtube video of the bafang no load with the metal gear so we can here how it sounds? I've got videos of the bafang noload at 40v and 80v in a 26" wheel as well as just the motor itself as a baseline. (http://www.youtube.com/voicecoils)
I've removed the bafang wheel and other ebike bits from my bike for now and returned it to it's original pedal only state. I'll keep an eye on this tread for any progress towards a more robust solution.
voicecoils
Postby voicecoils » Sun Nov 09, 2008 4:34 pm
Freddyflatfoot wrote:On the other issue of wiring, is it worth doing that, or going sensorless?
The only point would be to way overpower motor, in which case the existing phase wires just don't have the copper for sustained high power draws.
Sensorless means no longer needing your hall sensors which is nice from a reliability point of view as they can fail (water, overheating, etc) and then the motor will no longer be operable. Sensorless also means you can't apply the throttle from a stop. The motor must be spinning first before it can be controlled.
I don't know about the Ananda controller, hopefully someone else will.
voicecoils
Postby docnjoj » Sun Nov 09, 2008 4:57 pm
Ditto on awating some gerared solution! I can go to my brushed systems which are fine, but not geared. I think the 16" wheel wil have immense power off the line, but it runs out of oomph way before the Bafang did! Meantime I will hold off with gears , maybe, since progress seems to be occurring. Thanks everyone!
The unbreakable MY1018 and 3 speed rear must go for grandkid Christmas presents, and its just plain too noisy for grownups!
otherDoc
docnjoj
Postby Knuckles » Sun Nov 09, 2008 7:16 pm
To summarize my findings ...
1) There is absolutely no increase in noise (72V) with the metal gear in the Bafang. My Bafang is still more quiet than my Direct Drive hub motors (but it will never be faster). My only issue is the single metal gear I have has no bearing. If I could get the metal gears with bearings (at under $15 each) I would be selling the Bafangs right now.
2) I tested the sensor-less module on the Bafang. It works fine AND from a dead stop. It also works WITH the hall sensors connected. The (Keywin) sensor-less module is designed to spin a BLDC (rotor) in only one direction. The only issue with the sensor-less module is the "jitter" at low rpm when BEMF from the phase wires is low. In a geared motor this effect should be reduced. Testing is (of course) needed to prove this is the case. Same applies to the PUMA and BMC geared motors with the sensor-less module Infineon mod.
3) The Bafang at 72V just barely does 30 MPH (26" wheel). 30 MPH is my benchmark for performance. The torque at start-up is phenomenal, however, and the motor stays cool.
4) I hate thin phase wires. Hate Hate Hate Them. If eliminating the hall sensors and beefing up the phase wire gauge works then it is a winner. The only issue would be starting from a dead stop while on a step uphill incline. This could still cause jitter even on a geared motor with the sensor-less module.
So who will be first to step up to the plate and provide metal gears with bearings for the Bafang? :shock:
Knuckles
Postby John in CR » Sun Nov 09, 2008 8:58 pm
I have a bearing in the one you sent me. Cost me just over $5 plus the bearing. I can get them made for under $15, but I'm not sure of min order qty. What metal do we want to use? I think maybe we should "prove" them some more. I'll go ahead and install mine and then really test it.
I tried the sensorless on my Erato 2 speed and it kicks the shifter out of gear, because that "jitter" is back and forth movement of the motor. Since it is noisy, it can't be good for the motor, so I wouldn't intentionally switch to using it unless it's "pedal first". No load it works perfect, so maybe just some fine tuning is needed in the programming.
John
John in CR
Postby voicecoils » Sun Nov 09, 2008 9:24 pm
John in CR wrote:I have a bearing in the one you sent me. Cost me just over $5 plus the bearing. I can get them made for under $15, but I'm not sure of min order qty. What metal do we want to use? I think maybe we should "prove" them some more. I'll go ahead and install mine and then really test it.
How 'bout 304 grade stainless steel with the sealed bearing pressed in. A set of 3 gears bored out to the correct size for US$15 would make me very happy. I've got spare bearings of my own but it would be even better to have a ready to go, drop in solution. The bearings should not cost more then $0.50 each.
voicecoils
Postby John in CR » Sun Nov 09, 2008 9:36 pm
$5 was to install a bearing in the gear Knuckles sent me. I'm sure stainless would cost more than the "Tylon" quote I got, but I think I understood correctly that some type of metal could be cheaper. Sorry but after 11 years my spanish still sucks. The only way we're going to find something cheap is if we find a place that has some old stock that just happen to be exactly the size we need. One of those surplus outfits could prove to be a real bonanza.
John
John in CR
Postby docnjoj » Mon Nov 10, 2008 7:03 am
Hey folks! Lets not get carried away with "cheap". I have seen Puma steel gears go for up to $60 a set. Granted its a more expensive motor, but its our folks putting in the time and testing to make this work. They should make some to cover cost etc. if this solution proves successful. Just MHO!
otherDoc
docnjoj
Postby John in CR » Mon Nov 10, 2008 12:18 pm
docnjoj wrote:Hey folks! Lets not get carried away with "cheap". I have seen Puma steel gears go for up to $60 a set. Granted its a more expensive motor, but its our folks putting in the time and testing to make this work. They should make some to cover cost etc. if this solution proves successful. Just MHO!
otherDoc
Doc,
I couldn't agree more. I too need to resist the urge to look at this purely from a cost standpoint, and instead look at it in terms of value. Durability is "worth" a lot to me, and even if it takes $100 in mods plus a couple of hours of my time to turn this economical, lightweight, high torque motor into a solid performer that can deliver years of reliable service without worrying about nursing the throttle, then I'm definitely game. Metal gear(s) should start to make a sonic warning before they go, which I like much better. I just want something I can trust, because the idea of peanut butter gears on the other side of a mountain 20 miles from home simply isn't acceptable.
Are there other mods we should look at while we have it open? Yes the leads are a bit spindly, but at 72V+ I really don't want to run high amperage through it anyway. That's just asking for heat problems. I will examine the interior wire connections while I have it open, since one guy did have a loose phase connection. What about bearings...is that something we should look at too?
John
John in CR
Postby docnjoj » Mon Nov 10, 2008 3:22 pm
I too gave it a lookover, and compared to a P2A it is much cheaper construction! Not only rivits where screws and bolts are used, but generally designed not to be reused, except for the gears! It also has a much higher gear ratio (about 5:1) than the P2A (about 10:1) so its a little like apples and oranges. The reason I conpare the two is that they are almost the same size and use the same spoke length.P2A has helical gears of very hard plastic and one metal! I'll try to provide pictures tomorrow, but the point is that Bafang is made OK for the money! It just isnt "top of the line" quality, and is priced as such! Lets solve the gear thing and let Bafang upgrade the rest of it! These motors can last a long time! My P2A got 3000 miles over 4 years before it ate its gears!
otherDoc
docnjoj
Postby docnjoj » Mon Nov 10, 2008 3:30 pm
Actually, Brett White still has pictures of P2A internals on his website here: http://www.users.bigpond.com/solarbbq/P2-A.htm Check out the gear quality!
otherDoc
docnjoj
PreviousNext
Who is online
Users browsing this forum: BananaFr0g, kudos and 17 guests
