Help finding a solution to Bafang gear stripping
Re: Help finding a solution to Bafang gear stripping
Postby voicecoils » Sun Nov 09, 2008 4:34 pm
Freddyflatfoot wrote:On the other issue of wiring, is it worth doing that, or going sensorless?
Can I upgrade my Ananda controller to sensorless?
The only point would be to way overpower motor, in which case the existing phase wires just don't have the copper for sustained high power draws.
Sensorless means no longer needing your hall sensors which is nice from a reliability point of view as they can fail (water, overheating, etc) and then the motor will no longer be operable. Sensorless also means you can't apply the throttle from a stop. The motor must be spinning first before it can be controlled.
I don't know about the Ananda controller, hopefully someone else will.
voicecoils
Postby docnjoj » Sun Nov 09, 2008 4:57 pm
Ditto on awating some gerared solution! I can go to my brushed systems which are fine, but not geared. I think the 16" wheel wil have immense power off the line, but it runs out of oomph way before the Bafang did! Meantime I will hold off with gears , maybe, since progress seems to be occurring. Thanks everyone!
The unbreakable MY1018 and 3 speed rear must go for grandkid Christmas presents, and its just plain too noisy for grownups!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby Knuckles » Sun Nov 09, 2008 7:16 pm
To summarize my findings ...
1) There is absolutely no increase in noise (72V) with the metal gear in the Bafang. My Bafang is still more quiet than my Direct Drive hub motors (but it will never be faster). My only issue is the single metal gear I have has no bearing. If I could get the metal gears with bearings (at under $15 each) I would be selling the Bafangs right now.
2) I tested the sensor-less module on the Bafang. It works fine AND from a dead stop. It also works WITH the hall sensors connected. The (Keywin) sensor-less module is designed to spin a BLDC (rotor) in only one direction. The only issue with the sensor-less module is the "jitter" at low rpm when BEMF from the phase wires is low. In a geared motor this effect should be reduced. Testing is (of course) needed to prove this is the case. Same applies to the PUMA and BMC geared motors with the sensor-less module Infineon mod.
3) The Bafang at 72V just barely does 30 MPH (26" wheel). 30 MPH is my benchmark for performance. The torque at start-up is phenomenal, however, and the motor stays cool.
4) I hate thin phase wires. Hate Hate Hate Them. If eliminating the hall sensors and beefing up the phase wire gauge works then it is a winner. The only issue would be starting from a dead stop while on a step uphill incline. This could still cause jitter even on a geared motor with the sensor-less module.
So who will be first to step up to the plate and provide metal gears with bearings for the Bafang? :shock:
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby John in CR » Sun Nov 09, 2008 8:58 pm
I have a bearing in the one you sent me. Cost me just over $5 plus the bearing. I can get them made for under $15, but I'm not sure of min order qty. What metal do we want to use? I think maybe we should "prove" them some more. I'll go ahead and install mine and then really test it.
I tried the sensorless on my Erato 2 speed and it kicks the shifter out of gear, because that "jitter" is back and forth movement of the motor. Since it is noisy, it can't be good for the motor, so I wouldn't intentionally switch to using it unless it's "pedal first". No load it works perfect, so maybe just some fine tuning is needed in the programming.
John
John in CR
Postby voicecoils » Sun Nov 09, 2008 9:24 pm
John in CR wrote:I have a bearing in the one you sent me. Cost me just over $5 plus the bearing. I can get them made for under $15, but I'm not sure of min order qty. What metal do we want to use? I think maybe we should "prove" them some more. I'll go ahead and install mine and then really test it.
How 'bout 304 grade stainless steel with the sealed bearing pressed in. A set of 3 gears bored out to the correct size for US$15 would make me very happy. I've got spare bearings of my own but it would be even better to have a ready to go, drop in solution. The bearings should not cost more then $0.50 each.
voicecoils
Postby John in CR » Sun Nov 09, 2008 9:36 pm
$5 was to install a bearing in the gear Knuckles sent me. I'm sure stainless would cost more than the "Tylon" quote I got, but I think I understood correctly that some type of metal could be cheaper. Sorry but after 11 years my spanish still sucks. The only way we're going to find something cheap is if we find a place that has some old stock that just happen to be exactly the size we need. One of those surplus outfits could prove to be a real bonanza.
John
John in CR
Postby docnjoj » Mon Nov 10, 2008 7:03 am
Hey folks! Lets not get carried away with "cheap". I have seen Puma steel gears go for up to $60 a set. Granted its a more expensive motor, but its our folks putting in the time and testing to make this work. They should make some to cover cost etc. if this solution proves successful. Just MHO!
otherDoc
docnjoj
Postby John in CR » Mon Nov 10, 2008 12:18 pm
docnjoj wrote:Hey folks! Lets not get carried away with "cheap". I have seen Puma steel gears go for up to $60 a set. Granted its a more expensive motor, but its our folks putting in the time and testing to make this work. They should make some to cover cost etc. if this solution proves successful. Just MHO!
otherDoc
Doc,
I couldn't agree more. I too need to resist the urge to look at this purely from a cost standpoint, and instead look at it in terms of value. Durability is "worth" a lot to me, and even if it takes $100 in mods plus a couple of hours of my time to turn this economical, lightweight, high torque motor into a solid performer that can deliver years of reliable service without worrying about nursing the throttle, then I'm definitely game. Metal gear(s) should start to make a sonic warning before they go, which I like much better. I just want something I can trust, because the idea of peanut butter gears on the other side of a mountain 20 miles from home simply isn't acceptable.
Are there other mods we should look at while we have it open? Yes the leads are a bit spindly, but at 72V+ I really don't want to run high amperage through it anyway. That's just asking for heat problems. I will examine the interior wire connections while I have it open, since one guy did have a loose phase connection. What about bearings...is that something we should look at too?
John
John in CR
Postby docnjoj » Mon Nov 10, 2008 3:22 pm
I too gave it a lookover, and compared to a P2A it is much cheaper construction! Not only rivits where screws and bolts are used, but generally designed not to be reused, except for the gears! It also has a much higher gear ratio (about 5:1) than the P2A (about 10:1) so its a little like apples and oranges. The reason I conpare the two is that they are almost the same size and use the same spoke length.P2A has helical gears of very hard plastic and one metal! I'll try to provide pictures tomorrow, but the point is that Bafang is made OK for the money! It just isnt "top of the line" quality, and is priced as such! Lets solve the gear thing and let Bafang upgrade the rest of it! These motors can last a long time! My P2A got 3000 miles over 4 years before it ate its gears!
otherDoc
docnjoj
Postby docnjoj » Mon Nov 10, 2008 3:30 pm
Actually, Brett White still has pictures of P2A internals on his website here: http://www.users.bigpond.com/solarbbq/P2-A.htm Check out the gear quality!
otherDoc
docnjoj
Postby voicecoils » Mon Nov 10, 2008 5:36 pm
docnjoj wrote:...It also has a much higher gear ratio (about 5:1) than the P2A (about 10:1) so its a little like apples and oranges....Lets solve the gear thing and let Bafang upgrade the rest of it!
Bafang is 4.3:1
Another thing to look at would be the freewheel assembly that the nylon gears mount to. It may have a limited life as well. Nogwin is nearing 2k miles however, so he's our best torture tester yet IMO. The freewheel assembly cannot be disassembled from what I could see, so a bit hard to check the construction quality.
voicecoils
nt
Postby John in CR » Mon Nov 10, 2008 8:11 pm
nt
John in CR
Postby TPA » Mon Nov 10, 2008 8:17 pm
Voicecoils says the bearing is the 608zz. I am considering making some gears out of 6061 aluminum. Can the bearing 608zz be confirmed with absolute certainty? And should they be shielded or sealed?
Can anyone say whether it would be a good idea to increase the o.d. of the gear slightly to cut out the slop?
My Ebike is built with a hub motor purchased from www.ebikes.ca
It has performed flawlessly since it was installed. I cannot
recommend the professional folks there enough.
TPA
Postby voicecoils » Mon Nov 10, 2008 10:55 pm
TPA wrote:Voicecoils says the bearing is the 608zz. I am considering making some gears out of 6061 aluminum. Can the bearing 608zz be confirmed with absolute certainty? And should they be shielded or sealed?
The bearings on the gears I've got are 608Z. The replacements I've got on hand are 608ZZ, I don't actually know what the difference is myself. Same size though.
Here's the gear again as a refresher:
I think it could be a good idea to increase the o.d. slightly to make up for poor manufacturing tolerances but you'd really need a bafang motor in hand to test with. A more snug fit could increase friction significantly.
voicecoils
Re: nt
Postby voicecoils » Mon Nov 10, 2008 10:58 pm
John in CR wrote:nt
I'll assume you found the freewheeling mechanism :D
voicecoils
Postby TPA » Mon Nov 10, 2008 11:04 pm
my intention is to supply someone with 3 drop in replacements to test for strength and wear. I'm not making any promises, because I'm in school until dec 18th, and time is a premium until then. I've ordered the tooling, but still need to get the aluminum and bearings (I'm assuming shielded is ok looks like whats in the picture). I will try to make many (60?) at one time, but can't promise when they will be ready.
TPA
Postby voicecoils » Tue Nov 11, 2008 5:42 am
TPA wrote:my intention is to supply someone with 3 drop in replacements to test for strength and wear. I'm not making any promises, because I'm in school until dec 18th, and time is a premium until then. I've ordered the tooling, but still need to get the aluminum and bearings (I'm assuming shielded is ok looks like whats in the picture). I will try to make many (60?) at one time, but can't promise when they will be ready.
Sounds great. I would be happy to be a guinea pig :D but wouldn't be able to do any testing till the first week of December. After that I'd be happy to give them a go at progressively higher current and voltage to see how they fare.
I've got 4 spare bearings too that could be pressed in locally if need be.
Cheers!
voicecoils
Postby Knuckles » Tue Nov 11, 2008 7:39 am
voicecoils wrote:Another thing to look at would be the freewheel assembly that the nylon gears mount to. It may have a limited life as well. Nogwin is nearing 2k miles however, so he's our best torture tester yet IMO. The freewheel assembly cannot be disassembled from what I could see, so a bit hard to check the construction quality.
The freewheel mechanism in the Bafang looks well machined and durable. I have no concern about its durability thus far.
TPA wrote:Voicecoils says the bearing is the 608zz. I am considering making some gears out of 6061 aluminum. Can the bearing 608zz be confirmed with absolute certainty? And should they be shielded or sealed? Can anyone say whether it would be a good idea to increase the o.d. of the gear slightly to cut out the slop?
I would stay with the 1.25 module 28-tooth standard for now. With metal it is good to have a little play for thermal expansion.
The existing nylon gear is exactly a 1.25 module 28-tooth gear.
Also any bearing would do fine. It just needs an 8mm bore. It doesn't have to be a 608. But a sealed bearing is always preferred.
Just hearing today that a Chinese gear manufacturer (same as makes the metal gear for the PUMA) will make orders of 500 metal gears for the Bafang.
However, I would encourage a smaller startup batch and more testing first.
Knuckles
Postby johnrobholmes » Tue Nov 11, 2008 7:42 am
Shielded bearings have lower rolling resistance as compared to sealed. 608z should be single shield, and 608zz should be double shield.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Knuckles » Tue Nov 11, 2008 7:58 am
John,
Are you planning to get a dozen or so metal "test" gears for the Bafang any time soon?
Knuckles
Postby johnrobholmes » Tue Nov 11, 2008 8:04 am
I have access to either 10ft of gears or none right now. I have not gotten the gearblanks cut yet.
I am working harder to get the motors built with consistent phase and hall wires so that we can predict how to hook em up. I already had a customer burn one up. Otherwise I have been very pleased with the construction. I may even see if I can get the inner workings of the motor separate for a divorced driveline system.
Volt up, gear down!
johnrobholmes
Postby docnjoj » Tue Nov 11, 2008 8:04 am
So when can I get my Bafang back on the road? I need 2 Nylon and 1 steel combo, at least at first! To whom do I send money to? And how much? Sorry to be so insistant, but I kinda like the motor!
otherDoc
docnjoj
Postby Knuckles » Tue Nov 11, 2008 8:08 am
John in CR may be the best bet for a batch gears with bearings. Three metal gears will also work btw.
Maybe I need to work out some "trade" with John (controllers for gears perhaps?).
Then I can distribute the gears out to folks.
Knuckles
Postby docnjoj » Tue Nov 11, 2008 8:10 am
Noise level with three metal gears will probably be too high for my sensitive ears!
otherDoc
docnjoj
Postby Knuckles » Tue Nov 11, 2008 8:12 am
I'll test all metal gears (3) for noise myself. John in CR could do the same.
Knuckles
PreviousNext
Who is online
Users browsing this forum: 100volts+, DrkAngel, E-Zero, ioputielmomo, major, motomech, neptronix and 19 guests
