Help finding a solution to Bafang gear stripping
Re: Help finding a solution to Bafang gear stripping
Postby dazzassj6 » Wed Dec 24, 2008 12:06 am
yeh voicecoils, i still havnt figured out which model no my rear bafang motor belongs to... All i have is that serial number like mark aswell. =(
Project 1: 48v 500w Golden motor upgrade on Express Green E wheels upgraded to 48v 10ah Ping battery Flat speed: 44km/hr Pedal assist: 49.9km/hr Uphill speed: 40km/hr
Project 2: A female Kmart mountain bike 26" wheels mounted with a 500w cyclone with a 24v 20ah 13C Lifepo4. Flat speed 30km/hr pedal: 35km/h
viewtopic.php?f=6&t=6669
dazzassj6
Postby Knuckles » Wed Dec 24, 2008 1:03 am
Nogwin wrote:I'm going to order a set of metal gears too today, but the post above regarding a gear not fitting is worrying. I have the same black motor from Knuckles, so if anyone has the gear part number then ordering - that would be great.
My motor has just under 2000 miles now, and still running well. I'm still at 66v.
Nog
gogo wrote:I have run my 36V black/silver bafang on 56V up a hill and from a standing start with about 300 lbs of load without incident, but I parked it as soon as the nylon gear stripping issue surfaced. Its interesting to hear that mer is using a silver bafang and not had problems.
If anyone is sourcing gears, may I piggy-back? I just need one gear. Or, I may just order a silver motor and some gears from keywin (if he has metal gears left).
The black Bafang and the similar silver Bafang will both take this gear.
Just open up the motor and check. It is easy to open the motor.
Just order from Keywin ecrazyman@gmail.com and he will deliver.
-K
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby docnjoj » Wed Dec 24, 2008 9:37 am
Yes to the above! I should have my Bafang 1 steel/2 nylon back on the road by the weekend, as soon as all this Bah Humbug &%#@#^^^& is done!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby Russell » Wed Dec 24, 2008 3:02 pm
A noobie question for ya; what's the procedure to open a Bafang motor? What side do I open? Do I need any special tools?
When I first received the motor I took the screws out of one side, I don't recall which side, but could not get the cover off. I didn't try too hard since I didn't know what to expect and I didn't want to damage the case. I am curious to peek inside though and may want to upgrade to one steel gear in the future.
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Postby docnjoj » Thu Dec 25, 2008 10:50 am
It should come off easily, as there is only 1 removable side! Make sure all the nuts are off the axle on that side. You can leave the freewheel on! Remove the screws (carefully) an get flat paint knives under. You may not need em! Just wiggle and it should come off!
otherDoc
docnjoj
Postby Russell » Thu Dec 25, 2008 5:06 pm
docnjoj wrote:It should come off easily, as there is only 1 removable side! Make sure all the nuts are off the axle on that side. You can leave the freewheel on! Remove the screws (carefully) an get flat paint knives under. You may not need em! Just wiggle and it should come off!
otherDoc
But WHICH SIDE comes off? I have the nicely polished silver front motor and BOTH sides appear the same with 6 screws and what looks like a seam between the cover and housing. When I had the screws out the first time (I think on the cable side) I couldn't even get an xacto blade in the seam so I don't think I'll be able to wedge a paint knife in there. What's the trick?
Russell
Postby John in CR » Thu Dec 25, 2008 9:03 pm
Russell wrote:.... What's the trick?
Tap tap tap.
John in CR
Postby fechter » Thu Dec 25, 2008 10:16 pm
See this thread: http://endless-sphere.com/forums/viewtopic.php?f=16&t=3720
Not a Bafang, but the same method works to get the cover off. You want to take off the side opposite where the wires go in.
fechter
Postby docnjoj » Fri Dec 26, 2008 9:27 am
The rear Bafang only has 1 removable side! Getting the mushed gears out took a lot of time, until I found that the posts that hold them are removable. :oops: Just tap with a drift after removing those lovely little snaprings that dont even fit metric tools! On should be easier! Its 70 +degrees here and rather nice for Christmas!
otherDoc
docnjoj
Postby Russell » Fri Dec 26, 2008 11:32 am
fechter wrote:See this thread: http://endless-sphere.com/forums/viewtopic.php?f=16&t=3720
Thanks.
Russell
Postby Knuckles » Tue Dec 30, 2008 7:55 pm
Post some pics and let's take a look-see.
-K
Knuckles
Postby ktronik » Sun Jan 04, 2009 5:49 am
Some feedback....
I have been riding my front bafang motor in a 16" wheel on my bob trailer since AUG 08 with no problems.
http://endless-sphere.com/forums/viewtopic.php?f=4&t=5710
Its a sliver / black model: 129SWX36, 26" version, 24v, 220w (BF802D10084). Run on 48v / 18A
Before I found out about the gear stripping problem, I tried to 'kill it' on the biggest hills I could find, to see if it would be a reliable motor for riding to work & back...my home made throttle gives it 'FULL stick' from a standing start....
Must be the fact that its in a 16" wheel that has saved me from issues.
voicecoils: you look to have the same motor as I, it that the case?? Can I use the same metal gears as you used?? I am kinda just up the road from you, living in Newcastle. I read that you have sourced the metal gears, is that right??
Thanks
Ktronik
ktronik
Postby voicecoils » Tue Jan 06, 2009 9:59 pm
ktronik wrote:Some feedback....
Thanks
Ktronik
Ktronik,
Yes. I have two sets and only need one. One was for Mark_A_W but it turned out his Bafang has different nylon gears. Send me a PM
I haven't road tested the metal years yet. But it will happen soon hopefully, I've just been busy.
voicecoils
Postby spike » Sun Jan 11, 2009 2:03 am
Another peanut butter Bafang. I've been running the motor at 48V but treating it carefully because of the gear stripping problem. Today I forgot to change down at the lights and tried to pull away using the motor more than I usually would. It got a few yards before the coffee grinder noise started and I knew instantly what had happened. Just thought I'd add another one to the list for any newbies considering buying a Bafang.
spike
Postby spike » Sun Jan 11, 2009 10:28 am
Kraeuterbutter wrote:what controller-limit (amps) do you use ?
I was using the e-crazyman 48v 30A controller http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300248682281. The batts are good up to 60A but the controller won't let them go there (I think).
spike
Postby recumbent » Sun Jan 11, 2009 4:28 pm
These motors clearely cannot handle E-bike loads and should be classified for toy use only :)
After reading about many "Bafang"gear hub failures, and owning a quality geared hub motor for 5 years without any failures what-so-ever, the term "you get what you pay for" holds very true with respect to geared hub motors.
Ebike in use:
LWB Recumbent bike, Sram i-9 internal gears.
Power supply: 58V, 16 amp/hr, lipo batteries.
max speed: 50 km/h (30 mph),
max range: 40 km's, incl stop&go few times, minimal pedaling.
recumbent
Postby Kraeuterbutter » Mon Jan 12, 2009 4:40 am
@recumbent:
i would not aggree with that at all
its totaly unfair
the Bafangs are rated for
24V and/or 36V ====> spike powered it with 48V
5,5A to 12,5A (depending on motor-model) ====> spike was using a 30A limit-controller
150Watt, 180Watt, 200Watt, 250Watt
(depending on modell) ========> spike was using up to (45V * 30A) = 1300Watt
iam using a 24V Bafang, rated for 180Watt and 12A
i use it with an 14A controller and 36V Battery, seeing this way up to ~500Watt
so iam too going over the rated limit.. sofar - 1200km up and down many hills and going offroad - it works very well and fine
i think, when you use it in the way it was designed for/made for, you will not face any problems
Kraeuterbutter
Postby voicecoils » Mon Jan 12, 2009 6:55 am
first few km of testing with 'heavy metal bafang'
no failures, will continue to test and then do a visual inspection and re-grease perhaps at the 50km mark or so.
Details and a photo here:
viewtopic.php?f=6&t=4925&p=124098#p124098
Still some life in the inexpensive bafang yet I hope :D 8)
Would like to have a go on the nice German Heinzmann at some point. They only do brushed 36v hubmotors through, right?
voicecoils
Postby Kraeuterbutter » Mon Jan 12, 2009 7:57 am
a nice clean setup you have there..
for the Heinzmann: they have geared and gearless, brushed and brushless motors
for my use: (and i "only" power the bike twice as much as is allowed here in europe)
the Heinzmann would be
1.) too expensive
2.) too heavy (for 200W average and 500W peak i see with my 14A controller)
3.) too noisy
4.) too big from optical standpoint
of course, when you plan to power your bike up to 1000Watt and even more, than you need a motor which is bullet proof
when you build a bike within the laws (at least within the european laws) or break the (european laws) only by factor 2 ;)
then the bafang is the better solution, because
1.) cheaper
2.) smaller
3.) lighter
4.) more quiet
Kraeuterbutter
Postby spike » Mon Jan 12, 2009 8:07 am
Re Recumbents/Kraeuterbutters comments. Keywin told me before I bought the motor that it was only rated at 250W. However, the motor was cheap and I was happy to over volt it and take the risk. I guess if I'd stuck to the rated volts/amps it would still be going, but 250W in a hub isn't enough useful assistance (for me anyway). I'm not knocking the Bafangs, Keywin, or Knuckles. Just letting people know what happened. The metal gears should fix it, but then there's the noise issue :)
spike
Postby Kraeuterbutter » Mon Jan 12, 2009 8:25 am
i know..
thats not true..
for the purpose they are made, they work preety well...
( mine, with power at 600Watt: http://www.youtube.com/watch?v=3TQZqctp-gY running twice as fast as it is allowed in europe and the EU, and even more than twice as fast than it is allowed in austria)
as long as you stay at the legal speeds you will not see problems
its like overclocking a 3 GHZ Pentium to 6-9GHZ and when it fails to say: "Pentiums are toys, not useable as desktop-PCs" ;)
i only wanted to state, that there is no problem with the bafangs in the way they are made for and sold for
so: lets say: "the bafang is not the best motor for overvolting and using controllers with lot of amps"
and not say: the bafang cannnot handle e-bike loads, is a toy... --> thats wrong
Kraeuterbutter
Postby mer » Mon Jan 12, 2009 1:01 pm
Just an update ...
my Bafang ( which has 8FUN engraved onto it , 250w 36v model ) still works great at 48V with the 30A ecrazyman controller with lifepo4 batteries . I suspest I have done more than 300 kms ( probably more ) and I still accelerate from the steepest hills ( from a dead stop ) and I have tried ( and still trying ) almost everything to get them into peanut butter state but I didn't have any *luck* lol . I hardly pedal .
Lots of fun :twisted:
mer
Postby recumbent » Mon Jan 12, 2009 4:21 pm
I think i hit on a sensitive issue :? , but when you work in industry for many years as i have, electric motors are seen as reliable and maintenance free. One of you fellows said he rode his Bafag for 300km, that's only two weeks operation.
I never meant to put down your precious little motors, I just have different expectations, and reliability is an absolute, or it's not worth buying.
My bike has to carry a 190lb man, 20lbs of batteries for range, and 45lbs of bike bits and cargo, then ride for two hours without issue, every day, and that's exactly what these gearless hubs do.
The bigger geared hubs have an excellent torque curve and i'm tempted to buy one, once they prove reliable which i think they already have with seasonal greasings.
Wish you luck with the steel gears though, and no hard feelings. We all learn from your tests.
Ebike in use:
recumbent
Postby Kraeuterbutter » Mon Jan 12, 2009 5:42 pm
Hi recumbent,
i hope you don´t think iam a little child who is angry because you slam about my bafang, and now iam froward
for overvolting and over-ampering setups there are for sure more robust motors and of course: on a gearless motor there are less parts that can go wrong
i only wanted to state, that a bafang - used in the way it was designed for - is not useless for e-bikes..
here in Autria is a importeur who sells the geared bafangs to single persons and to companies, and he said in the forums,
that he had no bafang with failed gears sofar, and he has sold over 1500 units..
he works close with the manufactor, he visits them regulary in there factory
BUT: here in europe the motors are used with 24Volt and for power with 36Volt
there are only few people who are "nuts", and power them with even 48Volt and 15A controller...
well.. this gear-stripping-problem is a US-problem, you see only in US-Forums...
(72V tunings (more than 50Volt is not allowed in europe because the law says, that it starts to become life-dangerous over 50V), or controllers with 30A)
so: 72V, 30A ==> there are no such bikes here
(hell, the most sold bike here are the Swiss Flyers (Panasonic drive) with 250Watt)
oh: he also said, that the gears should hold longer than the free-wheel-unit, the free-wheel unit fails first...
it should be replaced after 30.000km
so, my 1200km are maybe not significant,
but at least: in the German Pedelec-forum are some using the bafang, with some tousands of km and i have not read of one gear-failure sofar ;)
Kraeuterbutter
PreviousNext
Who is online
Users browsing this forum: _Chris_, billEbob, Bing [Bot], sbike, triggeraa and 14 guests
