Help finding a solution to Bafang gear stripping
Re: Help finding a solution to Bafang gear stripping
Postby Knuckles » Wed Oct 22, 2008 4:30 pm
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby dnmun » Wed Oct 22, 2008 4:48 pm
before you grease it why not paint the faces with prussian blue and see where the wear faces are on the gears? excellent find!
dnmun
Postby snowranger » Wed Oct 22, 2008 4:55 pm
The 826.jpg shows the steel gear barely engaging the ring gear. Is it just the photo?
Electric: 400 watt BMC Hub Motor w/disc brake/Infineon 48V 30A controller/Dead 48V 20Ah Ping replaced with Headway 48V20ah
Bike : Generic mountain with xtracycle long tail
Accessories: homemade led lighting, 48V horn
Miles: 13,000 miles, 8,000 on the headway and counting.
http://www.ebikecommuter.com
snowranger
Postby Knuckles » Wed Oct 22, 2008 4:56 pm
Gravity. When I rotated the assembly the nylon did the same.
And of course no racer bearing on the "non-available" gear.
I got the last two in stock at the local "Gear Store" :shock:
WTF!
But the gear dude said he can get more as "special order"
He was blown away about e bikes ... never heard of them ... :lol:
But only torture testing will tell ... :?
Knuckles
Postby lawsonuw » Wed Oct 22, 2008 5:04 pm
Nice!
No bearing but it should work just fine for a while. Hadn't heard of KHK before, added them to my list of stock gear companies.
Marty
lawsonuw
Postby johnrobholmes » Wed Oct 22, 2008 5:05 pm
So the metal gear will be riding direct on the planet gear post?
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Knuckles » Wed Oct 22, 2008 5:09 pm
johnrobholmes wrote:So the metal gear will be riding direct on the planet gear post?
YUP!
Knuckles
Postby voicecoils » Wed Oct 22, 2008 5:10 pm
Knuckles wrote::D Metal gear installed and ready for testing. :D
http://71.18.69.167/endless-sphere/GEDC0828.JPG
Knuckles 8)
Well done! Can the metal gear spin freely on the post? Obviously a bearing would be better but... :wink: you might still be able to test it.
Can you pop the metal gear on top of the nylon one and comment on whether the tooth profile / pressure angles are identical? What are the specs from the shop?
voicecoils
Postby Knuckles » Wed Oct 22, 2008 5:12 pm
It's tight but spins free as birdie! But of course this is really just a test of M 1.25 28 teeth gears.
(Dead on Identical VC! Dead on!)
I showed the peanut butter to "Mr. Gear Dude" (Brian) and I know these guys can make anything.
Very cool shop. Making gears likes SOB's they were! :shock: NY cost I would think (of course) for custom gears.
This shop is located very close to me ... http://www.qtcgears.com/
The "discontinued" KHK gear is made in Japan btw.
Part Number KSSAY1.25-28
Makes me feel great hope for 'lil' Bafang.
72V 30A off road time!
:twisted:
Knuckles
Postby zibbby » Wed Oct 22, 2008 6:01 pm
What about if the gear is made of BRONZE?
The bronze is self lubricated and would work great with steel and my be little quiter then steel. It may also not need bearing.
zibbby
Postby Kurt » Wed Oct 22, 2008 6:45 pm
If you want it to last get some one to bore out the gears ID on a lathe so you can press in a bearing. It would be a 5 min job for anyone 1/2 decant. It will last for ever then.Running the motor under load with the gear naked on the post could chew up the post then even if you want to fit a bearing later it will be a bad fit on the chewed out post.
Kurt.
Kurt
Postby voicecoils » Wed Oct 22, 2008 7:08 pm
Kurt wrote:If you want it to last get some one to bore out the gears ID on a lathe so you can press in a bearing. It would be a 5 min job for anyone 1/2 decant. It will last for ever then.Running the motor under load with the gear naked on the post could chew up the post then even if you want to fit a bearing later it will be a bad fit on the chewed out post.
Kurt.
It's hard to argue with doing the right job the first time around. I totally agree.
Knuckles however has some stock to play with, as well as replacements. If he wants to try it out, I say go for it! It's not a good long term solution. I'm curious to hear how well the meshing with the ring gear goes.
I also would like to know what happens if metal bits grind off and fly into the motor :shock:
voicecoils
Postby Knuckles » Wed Oct 22, 2008 7:59 pm
F-N-A! 8)
Knuckles
Postby dazzassj6 » Wed Oct 22, 2008 7:59 pm
i cant wait until knuckle comes back with the test results lol will it work?!
if it does work, maybe knuckles can stock a few of these for all of us hehe.
maybe bafang would start supplying them too if this works.
i totally agree with kurt, im worried knuckles might wear the post out.
Project 1: 48v 500w Golden motor upgrade on Express Green E wheels upgraded to 48v 10ah Ping battery Flat speed: 44km/hr Pedal assist: 49.9km/hr Uphill speed: 40km/hr
Project 2: A female Kmart mountain bike 26" wheels mounted with a 500w cyclone with a 24v 20ah 13C Lifepo4. Flat speed 30km/hr pedal: 35km/h
viewtopic.php?f=6&t=6669
dazzassj6
Postby voicecoils » Wed Oct 22, 2008 8:38 pm
Knuckles wrote:F-N-A! 8)
spill it!
I need a "you so crazy factor" on a scale of 1 - 10
voicecoils
Postby John in CR » Wed Oct 22, 2008 9:42 pm
Knuckles,
Don't forget who asked first for metal gears back in July...That is once you have any to share.
John
John in CR
Postby fechter » Wed Oct 22, 2008 10:31 pm
spill it!
You get at least a 9 for scoring metal gears. Walk-in no less.
Let Mr. Gear Dude ride the F'N bike around (like with 72volts) and then talk special order. How many gears can you get in trade for a motor? Hey if it's a special order, then they make'em with the right size bore for the bearings.
fechter
Postby johnrobholmes » Thu Oct 23, 2008 9:57 am
Alright, I have three sources that can get gears for me, and one machine shop that will call me back about obtaining gear stock. Another machine shop can cut the gears in brass, but it may be expensive since they wouldn't start with gear stock.
So we have a choice of stainless, delrin, Steel 9 SMn 28K, and brass construction. The Delrin will be very affordable, next is stainless, and the brass may be most expensive.
I am leaning to using the delrin first to see if it works. I bet it would hold up much better than the stock nylon and still be very quiet. My next choice is the stainless, since it is decently soft.
Expected price points would be $20 each delrin with bearing, and $35 each stainless with bearing-but this is low quantity pricing. Brass I haven't gotten a quote yet. I will run my bike on 72v and ruin the gears to see where the limit is once I get replacements.
Volt up, gear down!
johnrobholmes
Postby Miles » Thu Oct 23, 2008 10:25 am
johnrobholmes wrote:I am leaning to using the delrin first to see if it works. I bet it would hold up much better than the stock nylon and still be very quiet.
It would wear better but there's not much difference between them strength wise - impact strength of Delrin is a bit better. I would go for metal, I think.
Miles
Postby Knuckles » Thu Oct 23, 2008 11:10 am
First test run of metal gear is success.
So it is now firmly established that the gear size is M1.25-28 w/ 8mm bore ...
The original nylon gear has a 10mm face.
My steel test gear has an 8mm face.
I replaced the existing washer with a thinner washer to make up the difference.
Just added a few drops of oil as lubricant.
Only a slight increase in noise level and a very solid feel.
Time will tell if the gear post wears out.
Of course a metal gear with bearing is the way to go.
(These test gears cost me $10 ea btw and can still be special ordered).
Knuckles
Postby Knuckles » Thu Oct 23, 2008 1:34 pm
dazzassj6 wrote:i cant wait until knuckle comes back with the test results lol will it work?!
So far the gear is working fine. Sounds good and feels great. But just one day of local riding.
This is more a "proof of concept" endeavor. But I do like the one steel gear combined with the two
original nylon.
I can either buy more of these 8mm face gears or I can go back to the gear dudes and ask for a version at 10mm with bearing.
But knowing Dr. Holmes I am sure he is already on it. :D (Go John Go!)
Of course it would be nice if CHINA (A hem) would just do this so that the Western World could buy it.
Knuckles
Postby lawsonuw » Thu Oct 23, 2008 3:29 pm
@johnrobholmes: I'm going to agree with Miles on this, and say skip delrin as it will perform about the same as the nylon gears. If you want to stay with plastic, Torlon or a graphite fiber filled Nylon/Delrin is my guess at the best bet. Of the metal choices brass will be most tolerant of running dry, though bronze would be better. Any of the steel options should work just fine though. My two cents says go with whatever metal gear is cheapest.
Marty
lawsonuw
Postby johnrobholmes » Thu Oct 23, 2008 6:19 pm
I have some 10mm face gearblanks with 4-6 week lead time available, and the rest would be custom machining (if we are just considering metal). $10 is cheaper than I have found for the blanks, but the ones I found were USA made. Add in machine time and bearing cost on top of blank cost.
Volt up, gear down!
johnrobholmes
Postby johnrobholmes » Thu Oct 23, 2008 6:40 pm
Blam Ba Lam! Just got an email from a company that will make 10ft of spur stock for me (200ish gears), but only in steel. 8-9 week lead time, and totally worth it. Gonna go for this one! I will probably have to get another company to part and bore each one.
Volt up, gear down!
johnrobholmes
Postby voicecoils » Thu Oct 23, 2008 7:23 pm
johnrobholmes wrote:Blam Ba Lam! Just got an email from a company that will make 10ft of spur stock for me (200ish gears), but only in steel. 8-9 week lead time, and totally worth it. Gonna go for this one! I will probably have to get another company to part and bore each one.
Cool, only downside is I want to be blasting around NOW :twisted:
Seriously though, the bearings are $0.50 each so that is just a small concern. To bore and press the bearings will certainly cost more, but hopefully less then the cost of the sliced up spur stock. :D
It's looking good 8)
voicecoils
PreviousNext
Who is online
Users browsing this forum: emcee, Rassy, Samd and 12 guests
