Plugging in Mean Well power supplies and it trips the house!
camerons98   100 mW
Post by camerons98 » Sep 12 2015 7:16am
I just purchased some Mean Well power supplies from ebay to charge my new 72v 14aH pack for my latest build but I've hooked 3 up in series to get 72v and whenever I plug it into the mains it trips the whole house instantly.
I was under the impression that I could plug these directly into my battery and charge it?
Atteched is a picture of how i've got it wired up, any help would be greatly appreciated as I need to charge my pack ASAP!
Thanks, Cameron.
wesnewell   100 GW
Re: Plugging in Mean Well power supplies and it trips the ho
Post by wesnewell » Sep 12 2015 7:43am
It seems you isolated the cases but then tied them together again with the earth ground. Try removing the earth ground between them.
camerons98   100 mW
Post by camerons98 » Sep 12 2015 8:02am
Removed the earth and they're powering up perfectly, thanks!!
Final question.. do I just adjust the voltage pots so that its outputting 74v which is the nominal of my battery and then plug the battery in and it will charge by itself?
Thanks!
teslanv   100 MW
Post by teslanv » Sep 12 2015 9:07am
camerons98 wrote:Removed the earth and they're powering up perfectly, thanks!!
Thanks!
Set the voltage for the fully charged voltage. If your battery is a 20S LiCo or LiPo variety, that would be 4.2V per cell or 84V total.
You can charge at a lower voltage (say 82V) if you want to limit to ~90% max SOC. That will extend the lifespan of the battery, but reduce the capacity (range) by 10%
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
MadRhino   100 GW
Post by MadRhino » Sep 12 2015 9:09am
Look on the face plate, it is printed the place where is the POT to adjust voltage up or down. Use a small screwdriver, you can adjust one only for this should give you enough range to match your battery.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
camerons98   100 mW
Post by camerons98 » Sep 12 2015 9:41am
Thanks for all your help guys its working perfectly! fully charged in just an hour and a half!
dnmun   100 GW
Post by dnmun » Sep 12 2015 10:42am
was this circuit breaker a GFCI type breaker? you may have a high voltage short to the case that blew the breaker. otherwise removing the ground would have no effect.
camerons98   100 mW
Post by camerons98 » Sep 13 2015 6:03am
how do I check what type of breaker it is? all the chargers are working fine now so surely everything is okay?
