smithinparis said:With winter fast approaching, I was hoping people could share their experiences with ebike winter riding, and how they went about preparing their setups. With respect to winter bike riding, there are some really great sites like icebiking.org that offer really detailed discriptions of things that need to be taken into account. But what about the electric setup?
Is there a good way to seal off a Crystalyte (406 in my case) rear hub?
Any advice on lubricants?
Protection of the connectors from salt and and crud?
Battery protection ... how cold has somebody run their batteries (and with what chemistry)? Is the self heating from the battery good enough to keep it warm in -20C?
smithinparis said:Swade,
Thanks for that. So a 10% increase or so, great info.
I don't have the studded tires yet, but I'm looking into them. Maybe you haven't had any problems yet, but I've heard that studded tires can lose their studs if ridden on bare ashfault for too long. Have you noticed anything like that (I'm thinking a much heavier bike might be worst that way).
Doh! I've always been curious as to how far you can push the pressure beyond the rated value!I think the failure was my fault, I was running them at 95psi -- probably should have only put about 65psi in them, the max they are rated for.
nutsandvolts said:swbluto said:I wouldn't think that a lot of RAM would be used up to begin with, but I suppose they're probably not using ASM. I vote Flash or some sort of non-volatile memory is being run out.
When he was here, Justin told me he has literally ran out of code space, there is no more room, it's a tiny microcontroller, and I he is using assember. The whole thing fits in 4KB or something like that. He showed me what the code looks like, and also I saw how the flashing works ...
Duracutter said:smithinparis said:With winter fast approaching, I was hoping people could share their experiences with ebike winter riding, and how they went about preparing their setups. With respect to winter bike riding, there are some really great sites like icebiking.org that offer really detailed discriptions of things that need to be taken into account. But what about the electric setup?
Keep the batteries and controller in a panier bag. Duct tape the connections to the hub motor. Install metal or carbide studded tires.
Otherwise, don't leave the bike out at night or in the day for that matter.
nutsandvolts said:Waterproof controller? They have holes where the wires go in, with just rubber grommets, I don't think they are waterproof. I have my controller inside a nylon travel bag, along with ALL connections, I'm at the point now where no amount of wet is affecting my bike...
I plan to ride in the rain and wet weather, how do I waterproof the hub motor?
...We would suggest it is better to leave the motor alone, but ensure that it has a chance to thoroughly dry out between wet weather trips so that corrosion cannot build up and accumulate.
You should also always store your Crystalyte motor indoors if you are in a wet climate. Crystalyte motors that are stored outdoors over a winter here can get so rusted that they will completely seize up with corrosion.
If water can't drain out that's a problem ... what worries me is the salt that they will start to put on roads soon ...
nutsandvolts said:The Stig said:Can A waterproof controller really not stay outside in the winter? More importantly will my new 500w stay be alright outside in the snow and rain? I hope it's just the wires going into the motor that I have to waterproof. I would put the controller in my battery box if there was any single quick connect plug for all the wires that go from the bike to the controller.
Waterproof controller? They have holes where the wires go in, with just rubber grommets, I don't think they are waterproof. I have my controller inside a nylon travel bag, along with ALL connections, I'm at the point now where no amount of wet is affecting my bike. Regarding the "sealing of wires going into hub motor" ... ebike.ca recommends
There are many suggestions on the web that you should thoroughly seal where the wire enters the axle slot using silicone or something similar in an attempt to keep water out of the Crystalyte wheels. But after having serviced numerous water-damaged hub motors that had been supposedly 'waterproofed', there is no evidence that this helps at all, and it may even make matters worse by keeping water trapped inside the hub. We would suggest it is better to leave the motor alone, but ensure that it has a chance to thoroughly dry out between wet weather trips so that corrosion cannot build up and accumulate.
