DAMNIT... they don't fit!
nomad85   10 kW
Post by nomad85 » Nov 07 2008 2:49am
I bought some Maxxis hookworms for my mountain e-bike. got everything ready to install, and they don't freaking fit. It looks like they would just barely fit if I wasn't using a hub motor. Does anyone know of a cheap(new or used) bike that can accept the hookworms with a rear hub motor? Man I was so looking forward to using these things...
E-bike#2- Trek Xtracycle 45 mph top speed(@74v)
Trek 850/9C 9x7 rear motor / 74v 10Ah Lipo
Mileage since 10/20/08: 9500 miles as of 8/10
Link   100 MW
Re: DAMNIT... they don't fit!
Post by Link » Nov 07 2008 6:50am
So wait...how exactly does the hub play into the tire not fitting?
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Ypedal   100 GW
Post by Ypedal » Nov 07 2008 7:51am
Hookworm tires are hard to get on the rims.. but they should fit..
You are putting these on a rim right ? and not directly onto the hub !?
what size rim and tire ?
ES site status page:
TPA   10 kW
Post by TPA » Nov 07 2008 10:44am
I bet it's frame clearance problems.
My Ebike is built with a hub motor purchased from www.ebikes.ca
It has performed flawlessly since it was installed. I cannot
recommend the professional folks there enough.
nomad85   10 kW
Post by nomad85 » Nov 07 2008 12:11pm
Doh.. sorry yeah its frame clearance that's the problem. Seems like the hub motor wheel slightly changes the position or the tire as the normal wheel is perfectly centered, and I have more clearance than I need on one side and contact with the frame on the other. Any recommendations for a suitable (cheap, but nice) bike that can accept these tires? I'll just leave this bike as is since I have an extra e-bike kit to use, now I will have 3 e-bikes:)
Zoot Katz   1 MW
Post by Zoot Katz » Nov 07 2008 12:24pm
nomad85 wrote:Doh.. sorry yeah its frame clearance that's the problem. Seems like the hub motor wheel slightly changes the position or the tire as the normal wheel is perfectly centered, and I have more clearance than I need on one side and contact with the frame on the other.
Sounds like it could be remedied with a spoke wrench to pull the rim over or maybe fit a spacer on the axle.
Ypedal   100 GW
Post by Ypedal » Nov 07 2008 12:38pm
quote ZK " ...or maybe fit a spacer on the axle. "
If you hae enough threads on the axle, and the frame will flex enough to allow it.. this is the easier option.. ie: add a lock washer or spacer over the axle inside the frame..
TPA   10 kW
Post by TPA » Nov 07 2008 12:48pm
spacer....maybe, maybe not. Dishing more likely.
nomad85   10 kW
Post by nomad85 » Nov 07 2008 1:01pm
I don't know even if I did get it in, it would be awfully close, eventually it would likely rub if the wheel gets out of true. I think I would rather get another bike with wider clearance and either keep this bike as is or sell it.
set   10 W
Post by set » Nov 07 2008 2:10pm
same thing with me. bought some hookworms and it rubs in the frame and the kickstand. The looked baddass though when it was inflated on the rim. I still got mines collecting dust. The reason they dont fit is it is 2.5" I think for my bike, they max i can have is 2.0.
vanilla ice   100 MW
Post by vanilla ice » Nov 07 2008 2:24pm
I know this dont help with the 26 hookworm.. but If you have a non disc rear motor, run only a plug rear brake then you can probly go down in wheel diameter and run a fatty. I'm going to try to fit a 24x3.0 this way on frame designed for 590mm tires. If you're looking to go cheap this should work with any old used craigslist MTB frame.
nomad85   10 kW
Post by nomad85 » Nov 07 2008 3:08pm
set wrote:same thing with me. bought some hookworms and it rubs in the frame and the kickstand. The looked baddass though when it was inflated on the rim. I still got mines collecting dust. The reason they dont fit is it is 2.5" I think for my bike, they max i can have is 2.0.
They do look pretty sweet.. even after all the frustration, I can't help but admire them... Need to find a bike they will work with!
diver   1 kW
Post by diver » Nov 07 2008 6:51pm
the hook worms work super on my heavy trikes, i have had no tire or flat problems with the hook worms and i spin the crap out of them with the etek powered trike.. i know this dont help you out but i thought id throw in a plug for the worms
D-Man   1 MW
Post by D-Man » Nov 07 2008 10:52pm
The Hank slick tire might fit. Its smaller 26x2.2 and looks bad ass.
408 front hub
21000+ miles on many sla's.
5 tires worn out
tailwind   100 W
Post by tailwind » Nov 07 2008 10:54pm
Mine fits, but only just. You can see that the frame narrows at just the spot.
Clearance is 3-4 mm either side.
Bike Giant Alias
Rim Downhill rear 559x30mm
Tyre Maxxis Hookworm 26" x 2.5"
Greg
D-Man   1 MW
Post by D-Man » Nov 07 2008 10:59pm
I got about 6mm clearance on the Hanks and they are 3/4" shorter then a Hookworm.
408 front hub
5 tires worn out
Duracutter   1 µW
Post by Duracutter » Nov 08 2008 1:56am
nomad85 wrote:Doh.. sorry yeah its frame clearance that's the problem. Seems like the hub motor wheel slightly changes the position or the tire as the normal wheel is perfectly centered, and I have more clearance than I need on one side and contact with the frame on the other. Any recommendations for a suitable (cheap, but nice) bike that can accept these tires? I'll just leave this bike as is since I have an extra e-bike kit to use, now I will have 3 e-bikes:)
Heed Katz advice, use a spoke wrench, you can adjust a wheel and it's not hard, I saw my bike mechanic do it in a few minutes, I was amazed and while he did it, I saw the logic. The spokes on one side will pull the tire and vice versa...
Good luck.
nomad85   10 kW
Post by nomad85 » Nov 10 2008 9:29am
Yeah! I adjusted the spokes and the wheel just barely fits now:) I may take it to a bike shop to get it all trued up, I don't want to mess it up too much working on it myself.
Thanks for the advice :D
swbluto   100 GW
Post by swbluto » Nov 10 2008 8:44pm
I got lucky. My hookworms fit, but they're about 1/4" away from the frame.
Lor   1 µW
Post by Lor » Nov 13 2008 12:26am
All you really have to do is take the bike and wheel to any bike shop and ask them to change the dishing on the wheel. They will loosen all the spokes and re-center the wheel to the right spot in between the frame stays. It isn't that expensive and you really want the wheel in the right place.
If the wheel isn't in the center of the frame you will encounter a bunch of weird handling characteristics that aren't very nice, so the issue is actually wider than just getting the tire to fit. You actually had a problem before you put the larger tire on, and by increasing the tire size until one side rubbed - you just brought the problem to your attention. Also, bending the frame to account for a dishing problem will only weaken something that you really don't want any weaker. Don't bring just the wheel, bring the wheel and the frame so they can get it right.
Lor
