Bigbikebob
I am thinking to build a new bike and decided to dive deeper this time regarding the motor and Wattage
I have read a few posts about volts/Amps and in my understanding volts are the pressure in the pipe and amps are the amount of "water" that are going via the exit surface aria of the pipe at any moment. I also read the more volts mean more speed and more amps mean more torque.
So if my statement is correct I have a few questions.
What is the physics beyond the association of volts with rpm and amps with torque ?
Can I say that volts determine the top speed of the motor and amps the how fast I will get from zero to top speed?
If I want to go faster on a a steep hill ( assuming I am no near my top speed on flat surface) I will need to add more amps (beside trying a smaller wheel)?
How do you know how much voltage and amps a motor can take and how do you find the sweet spot?
Thanks
Thanks
