by dnmun » Mon Jun 22, 2009 9:24 pm
i didn't really follow that. if you have 33V at the input to the voltage regulator, that is ok, but you need to keep track of how low the 12V rail goes when the battery voltage drops during discharge.
i estimated there is about 40mA current draw when it is running, and 27mA when idle.
so make sure the input to the 12V regulator doesn't drop below 9-10V or so, but 14V minimum is best. you can measure the output of the 12V regulator, it may be 15V in the golden motor controller, but look for that as the output and if it gets pulled up then you need to increase the input resistors. make sense?
