Loose triangle battery bag solved
negativepitch
Post by negativepitch » May 21, 2017 1:12 am
My hope is that this post will help someone who is experiencing the same loose triangle battery bag issue I was. After taking my ebike to work for the first time, I found I was constantly reaching down and pushing the battery back into the center of the bike frame, as the battery had a tendency to slide out, and the bag wasn't tight enough to prevent this movement. When I got home, I played around with the setup, holding the bag tight in certain places and testing the movement of the battery. I found that if I held the bottom of the bag tight against the frame, the battery would be secured and would not be able to slide left or right.
It seemed that if I could somehow lace the bottom of the bag to the frame, like a shoe, it would do the trick. I went to Home Depot and purchased a brass grommet kit: http://www.homedepot.com/p/General-Tool ... /100200416
I installed 4 grommets to each side of the bag as shown:
After the grommets had been installed, I mounted the battery bag to the bike.I highly recommend mounting your bag without the battery inside as you can more easily tighten the velcro straps to the frame.
I then loosely laced the grommets with some parachord (thin rope) I had laying around, and inserted the battery into the bag. Then it was just a matter of tightening the laces through the grommets.
The result is that the battery is now MUCH more secure, and is held firmly in place. This also narrowed the width of the bag as it's pulled tight, leaving more room for my knees as I pedal.
I hope someone finds this technique as helpful as I did!
Sidotian
Re: Loose triangle battery bag solved
Post by Sidotian » Dec 27, 2017 1:25 am
Thanks for this post im currently running into the same problem however my bike frame has the rear cable for break/derailer running along the bottom tube. my battery is two 6s 16ah lipo bricks i do not want the battery resting on the bottom of the bag. Im sure i will think of something but im quite stumped at the moment
Johnez
100 µW
100 µW
Post by Johnez » Dec 27, 2017 4:16 am
Now that's some ingenuity right there.
I've seen someone fill the gap in their bag with a half inflated intertube, not as elegant, but kinda shows where these ebike companies can go if they want to improve their products for the masses.
By y the way, what' your bike?
Jon NCal
Post by Jon NCal » Dec 27, 2017 11:58 am
I also use those batteries and a luna zip tie frame bag. What I did was mount a piece of wood 1x2 furring strip about 8 inches long to the top of the downtube using the water bottle screws ( recess them). Then I put some 1/2" foam from an ensolite sleeping pad inside the bag to cushion. This block has the additional benefit of relieving the stress on the zipper.
tomjasz
1.21 GW
1.21 GW
Post by tomjasz » Dec 27, 2017 4:12 pm
Careful with the zipper, those low priced, cardboard stiffened bags fail. My battery damn near fell out.
motomech
1 GW
1 GW
Post by motomech » Dec 27, 2017 8:18 pm
I did exactly the same thing.
I secure my LiPoly bricks w/ double-sided "sticky" tape.
For these bags to last, it's important not to have the weight hanging from the top straps, otherwise the bag/strap seams will fail.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 8#p1237928
