Schwinn stingray hub to controller wiring
whatparthurts
Re: Schwinn stingray hub to controller wiring
Post by whatparthurts » Oct 31, 2017 9:52 pm
I cracked it open and found a big blue green yellow and a small blue green yellow black red and the yellow wire is broken
amberwolf
Post by amberwolf » Nov 01, 2017 1:42 am
Ah, then it was probably a repair job (incomplete?) by a previous owner giving the new wire colors outside the hub.
If I understand correctly, the yellow phase wire does not have any wire that goes outside the hub now?
Only the blue and green do?
Do all five of the smaller hall wires (power red, ground black, and yellow green blue halls) go all the way from inside to outside the motor?
If any of the wires don't go all the way from inside to outside, you'll need to replace the wire that's broken, and possibly other wires.
How long are the phase (and hall) wires on your controller? If they are long enough, you may be able to cut a couple of feet off and use it to replace that inside the motor. (probably they are not nearly that long though). If they're not long enough for this, you may have other sources of wire you can reuse, or you can order wire by the foot from various places (I think http://ebikes.ca carries some).
It can be important that the phase wires be at least as large a gauge outside the motor as they are inside, and preferably all three the same gauge of wire.
whatparthurts
Post by whatparthurts » Nov 01, 2017 9:55 am
Back to the drawing board. Thank you for the tip. I got out a soldering iron and replaced the 3 big wires with 3 equal sized wires and re connected the broken wire inside. I think everything inside is ok now. I never would have solved the issue by just looking at the external wires. Like I said, I don't even know what I don't know.
I started with a Schwinn Manta ray 2005, added an electric chopper motorized wheel I bought online. The battery arrived and I am waiting for the controller from China. Then comes wiring and attaching things to the bike.
I will need to figure out a new brake system. The Manta ray only used coaster brakes on the back wheel.
Lots of fun, So far. so good
Parts on order:
s-l1600 (3).jpg (30.74 KiB) Viewed 202 times
s-l1600 (2).jpg (43.21 KiB) Viewed 202 times
s-l1600 (4).jpg (34.68 KiB) Viewed 202 times
fechter
Post by fechter » Nov 01, 2017 11:22 am
What probably happened is at some point the axle nuts got loose and spun, ripping out all the wires. You should be able to match the wires inside the motor to your controller much easier now, but don't expect that matching green-green, yellow-yellow, etc. will work, though I would try that first. You may need to swap around colors to get the right direction and phase matching. There are some topics here on finding the right hall/phase mapping. Seems every company does it differently.
I like the throttle with the voltmeter and key. Where did you find that?
whatparthurts
Post by whatparthurts » Nov 01, 2017 12:27 pm
ebay different colors are available too
https://www.ebay.com/itm/E-Bike-electri ... 2749.l2649
fechter
Post by fechter » Nov 01, 2017 3:39 pm
whatparthurts wrote:ebay different colors are available too
OK, thanks. I found they had one that can go up to 80v:
https://www.ebay.com/itm/eBike-Electric ... 33d59c86e7
whatparthurts
Post by whatparthurts » Nov 12, 2017 3:00 am
I bought the OCC ananda motor by itself, I ordered the rest of the stuff to make an electric bike on ebay. It is on its way from China.
I have to build a wiring loom for this bike and I have a few questions. Somethings I just don't know and I would like to do right.
1st of all:, the throttle has 5 wires, I think 3 for throttle and 2 for a key switch. Where do the key switch wires hook in at?
From the throttle manufacturer:
Three wires (Red=5V from controller, Black=ground, Green=5v signal back to controller) provide standard throttle function.(does not need the yellow wire hooked up as you may have had to before)
Two additional wires (Yellow and Blue) are a switched 24v and provide the level for the LEDs.Which would hook up to your on/off switch or Power Locks..
The LED meter has a yellow switch wire. Should it be connected to the key switch on the throttle? and where would the other wire on the key switch tie in?
And 2nd, The electric schwinn occ bike this wheel came from had a tube fuse. Where do I install the fuse?
3rdly, What is EABS stand for and what does it do?
I cut the wiring diagram in half so it can be readable in a small frame.
The first half drawing has been edited at the LCD meter connections. Thank you d8veh, I see the error, hopefully this works better
d8veh
Post by d8veh » Nov 12, 2017 5:07 am
That's standard ebike wiring that you find on many Chinese ebikes; however, something doesn't look right to me. It may be a translation issue. I'm pretty sure that the notations on the LED panel is wrong. Every one that I've ever dealt with has been:
Red = battery voltage
Black = ground
Green = signal wire for PAS and 6km/h modes
Other colour often blue, but can be anything = switched battery voltage to power the controller.
If you could edit that picture with a warning about that, it might save people from wiping out their controlers when they get it wrong.
whatparthurts
Post by whatparthurts » Nov 12, 2017 9:02 pm
I found this information online. Looks useful. It is the wire connections for a throttle with key switch
whatparthurts
Post by whatparthurts » Nov 23, 2017 2:43 pm
Turns out d8veh was right about the mis labeled connector, I edited in the change as suggested. I also ditched the relay. I looked over the wiring diagram and cut in the key switch at the power up switch.
333 (1).jpg (73.96 KiB) Viewed 100 times
whatparthurts
Post by whatparthurts » Dec 01, 2017 9:39 pm
Bike runs good now, I can't help it, I have to try this battery, Just waiting for more ordered parts. I guess I caught the ebike bug. Like I saw on one post here, Don't stop fixing it until it's broke...LOL
whatparthurts
Post by whatparthurts » Dec 09, 2017 11:45 pm
That's standard ebike wiring that you find on many Chinese ebikes; however, "something doesn't look right" to me. It may be a translation issue. I'm pretty sure that the notations on the LED panel is wrong. Every one that I've ever dealt with has been:
Black = ground
"something doesn't look right" I contacted the e bay controller seller and showed them your recommended changes, If you look at the item now, the wiring is correct. d8veh saves the e bike world from mis information
(157.58 KiB) Not downloaded yet
