eCue
Currently sourcing and building a ebike , at first was going to use the RM Element f/s bike but the more I read the more I want to make street ebike and leave the mnt bike as is for trail riding.
So I changed plans am now building up a mid 90's Qunitanna Roo panracer mnt bike frame have had for years most the parts are in a box it was missing a wheel set and the derailleurs / shifters.
Right now have a 26" front wheel / geared motor coming on the slow boat from China and since Im still needing the rear wheel went online when came across the Nexus internally geared hubs that cost about a $100 on eBay.
Ended up buying the nexus 4-spd version after reading it was durable and had high gears. I ride in 46 - 12T 90% of the time as it is without adding a motor.
This is the one I picked up it weighs 1370 gr / 3lbs without the roller brake on ( which it didn't come with and I don't want )
When i did the math using the weight weenies site I will be breaking even with the many removed parts and the added heavier hub and single grip shifter.
The Cranks have a 53T chain ring in them now it will stay and I'll remove the two other chain rings.
It works out to 3lbs of weight off in XT gear parts and 3lbs of weight on from a Hub and single gear changer.
The hubs on order now , the cool part is that 3lb hub will balance out the feel from the 5lb 250/350w geared from hub motor making for a well balanced / handling ride.
