Hydraulic brakes with bafang compatible cutoff
Are there cheaper hydraulic brakes that are compatible with Bafang / BBSHD drives ?
I saw https://california-ebike.com/shop/trp-zurich-high-performance-quad-piston-hydraulic-disc-brake/ Which is quite expensive.
The Magura MT5E and Shimano M355 are cheaper but both have a red colored 2 pin cutoff cable - but I am not sure if and how that works with the 3 pin yellow Bafang input.
Appreciate the help.
Early Christmas for you: red to yellow high converter
https://www.e-bike-technologies.de/index.php/en/adapter-and-y-adapter-en/adapter-higo-s3-b2-a
As I was told by Luna, you don't need any of that. Just backpeddle a smidge. Or, if you are panic stopping, no big, just brake harder.
I don't have the shift kill either, no big. I just slack peddling. It shifts very well. I
