KMX Franken Trike 12-18kw Build
fechter
Re: KMX Franken Trike 12-18kw Build
Post by fechter » Dec 28, 2017 3:40 pm
The U joints made for car steering linkages look pretty robust but not too heavy.
From Jegs:
Jegs U joint.jpg (29.51 KiB) Viewed 317 times
All kinds of them:
https://www.google.com/search?q=steerin ... 36&bih=752
amberwolf
Post by amberwolf » Dec 29, 2017 2:38 am
FWIW, I have a car steering linkage U-joint (found on teh side of the road several years ago, waiting for the right project) that I'm considering using to transfer the pedal chain power from the main chain to the side chain on the wheel's derailer and sprockets for my brother's trike.
I thought I had a pic of it but can't find it--but it isn't small or light. :/
Kinda looks like this one
docnjoj
Post by docnjoj » Dec 29, 2017 10:07 am
Hey AW. You have an auto power transmission U-joint. Much too big and heavy. The one Fechter shows is for steering rods; much lighter and smaller. They make even smaller ones for lawn mowers and 4-wheelers.
Just sayin'.
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
ElectricGod
Post by ElectricGod » Dec 29, 2017 12:26 pm
From Jegs:
All kinds of them:
These things look like an option. I spent some time yesterday looking at various versions of this joint and they come in a variety of sizes and if it will drive like a real u-joint, might just be the right component.
ElectricGod...it's a joke...don't take things so seriously folks!
XB-502 Moped:
https://endless-sphere.com/forums/viewt ... 0#p1222730
Currie scooter:
https://endless-sphere.com/forums/viewt ... 7#p1227407
ElectricGod
Post by ElectricGod » Dec 29, 2017 12:27 pm
Just sayin'.
otherDoc
Too big, true, but it would never fail under load!
XB-502 Moped:
Currie scooter:
ScooterMan101
Post by ScooterMan101 » Dec 29, 2017 1:33 pm
With the kind of high power you are going to be running your Franken trike at ,
should you just forget about paying all that money for a KMX trike and just have someone fabricate you a frame that would have better handling ?
Meaning
Wider Stance and much longer Wheelbase .
ElectricGod
Post by ElectricGod » Dec 29, 2017 9:46 pm
Meaning
Nice...but I am on a budget...and that's the whole point of putting this together from readily available components. I want to drop maybe 5k into it...motor, batteries, various upgrades and components needed to be 3WD. A custom made frame is going to set me back a lot since I don't have a TIG welder to do it right.
I came across a Performer JC70 trike that's a year old for $850. The seller is about 50 miles from me. He had a wreck and bent some frame component a little. I don't know more than that about it. It is all aluminum and that would require some reinforcing for the wattage I want to put on the frame, but I expected to do that for any frame. It's a 100% complete trike. A quick google search doesn't reveal any front suspension options for it and it has a hard tail which is OK. Considering how the KMX suspension works, I bet I can adapt it to work on this trike too.
XB-502 Moped:
Currie scooter:
ElectricGod
Post by ElectricGod » Jan 04, 2018 4:34 pm
I think I found a KMX frame kit for $600 + shipping. This is truly the best option. It's all steel and I'll need the strength for all the power I intend to throw at it. Also, looking at the suspension kit, I believe I can adapt it to work for my purposes. A drop block that bolts to the suspension outer face will drop the axle to below the bottom of the frame. I will still need to get 2 custom drop blocks machined that can take a driven axle riding on inner and outer bearings. This will allow me to use some kind of CV joint to drive the axles directly without interfering with the frame. Smaller wheels will compensate for the raised front of the trike to get it back to riding level again. The factory wheels are 24" I think. 20" or 18" ought to get me back to level again.
XB-502 Moped:
Currie scooter:
fechter
Post by fechter » Jan 04, 2018 4:59 pm
You saw this one, right?
https://endless-sphere.com/forums/viewt ... =6&t=69621
The leaning feature seems like it would be very good at higher speeds.
ElectricGod
Post by ElectricGod » Jan 05, 2018 4:51 pm
Cool bike, but very complex and there's no way to make that thing 3WD. I think the leaning mechanism is totally human powered/controlled. You lean because you make the bike lean. In which case you could also lean the wrong direction by accident.
XB-502 Moped:
Currie scooter:
The Toecutter
Post by The Toecutter » Jan 12, 2018 10:02 pm
With 18 kW, I think 0-60 mph in 5 seconds is being a bit conservative.
The trike you mentioned with three 3220 motors was put together by recumpence on this board.
Also, you may want to check out Lightfoot Cycles' ATC quad, an all-wheel drive offroadable pedal quadricycle.
I have a KMX with front suspension that I put together from a frame kit. It is perhaps the cheapest option other than building your own(which can get more expensive if you don't have the tools). You can't go wrong with this choice. Mine has been taken to over 30 mph on strictly human power, and it is smoother than an infant's asscrack on rough pavement with the shocks set at 60 psi. It feels like being in a car.
I saw that video on youtube of your ass-hauling scooter that can be switched between wye and delta. I suspect that you will make for yourself a very nice jackassmobile for committing random acts of jackassery out of whatever trike you build. Sounds like fun. I will be eagerly keeping an eye on how this develops.
