New Luna geared Mac motor
Wolfeman
Post by Wolfeman » Dec 22, 2017 10:38 am
This looks like a pretty good setup for a small powerful hub motor. Paired with a high capacity 52V pack, this would be fantastic for folks that don't want the issues of a mid-drive setup. Price seems decent too.
https://lunacycle.com/mac-motor-asi-hig ... e-hub-kit/
Trek 4300 w/ H3580 Crystalyte at 2300W
https://endless-sphere.com/forums/viewt ... =3&t=82738
Triketech
Re: New Luna geared Mac motor
Post by Triketech » Dec 22, 2017 4:17 pm
I've got a pair of MAC's with Phaserunners. Exceptional set up on a trike.
12T with 10 speed freewheel weighs in at 12.3 lbs.
10T with 10 speed cassette weighs in at 10.1 lbs.
We still pedal so we have zero interest in less than 10 speeds.
MAC 10T on HPV Scorpion FS26
Also have an ASI BAC 800 I've played with just enough to understand the software. I'm not a novice at programming controllers but I did buy some engineering time from ASI. I like the Phaserunner better for it's compact size & plug & play into the CA3, despite being triple the factory price of an ASI BAC 800.
Glad to see Luna step up.
motomech
Post by motomech » Dec 22, 2017 4:53 pm
Nice and simple, but............
I.M.O., too powerful for a frt. mount.
Too limited whl. size and motor speed options.
And where are the left-hand throttles?
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, 2.4 Holly Rollers run ghetto tubeless. 25 mph. Mean Well HLG-320H-48A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 12S LiPoly elifebike 9-FET 17A controller. 20 MPH.
https://endless-sphere.com/forums/viewt ... 8#p1237928
melodious
Post by melodious » Dec 22, 2017 5:03 pm
Wires coming out of the hollow axle is an old design & prone to getting destroyed in a sliding type crash. :roll:
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
Triketech
Post by Triketech » Dec 22, 2017 7:34 pm
Would you be interested in some bare MAC 10T Cassette motors?
docw009
Post by docw009 » Dec 23, 2017 2:23 am
Does the controller take a PAS sensor?
Triketech
Post by Triketech » Dec 23, 2017 10:54 am
It is "Thun friendly" but not in an ideal way. It has 4 analogue inputs that can be configured, two are used for the Thun. They were just adding the bluetooth option when I bought mine from ASI.
The software is not for novices. It is very easy to input conflicting values in different variable settings, that's why I bought some engineering time as its not clearly explained in the 65 page manual. Now I have it down pretty well. And that from someone with experience designing BLDC controllers that drive motors with cogless motion for accurate positioning in camera gimbals.
ScooterMan101
Post by ScooterMan101 » Dec 23, 2017 1:18 pm
Nice , Having the previous generation of Mac Motor to this one, ( Rear 6 T ) I can say allot of people will be happy with this kit since it will have even better performance .
I run mine on 12s most of the time, but have taken it out for a few rides with my
14 s pack.
And Luna is saying that it will run on a 16s battery pack with the ASI-BAC 800 Controller ?
I have been wanting to test a 16s pack on the Mac 6T .
Wonder if they had any changes made to the motor and if so what was changed in order for them to say it can run on 1700 watts ? ( I typically see up to 1200 watts when going up a steep hill or hill over 7% slope )
Or
Can a regular Mac run on that wattage, the 1700 watts only possible because of the ASI controller ?
Can someone confirm that the ASI-BAC 800 controller has the wires/connector to plug directly into a C.A. wires/plug ( Either the C.A. V2 or V3 ) ??
30 amp continuous is nice, I have mine programed through the C.A. V2 to only use 26 amps from the pack.
Luna does not list a 27.5 inch rim build option ... but I would think that should come along when enough people ask for it.
Also
I do not see a 16s battery pack and charger listed , but they do say it can run on 60 volts . ?
Wolfeman
Post by Wolfeman » Dec 23, 2017 2:45 pm
To me it seems like a pretty ideal combo for a general purpose bike. Small profile, powerful for it's size and affordable. Pair it with a high capacity 52V pack (24+ aH) and it'd be fantastic. I'd only put it on a rear wheel though. Wish this'd available when I was shopping for my first kit.
tomjasz
1.21 GW
1.21 GW
Post by tomjasz » Dec 24, 2017 3:46 am
Grin
UBracket
Availability: In stock
Regular Price: US$9.00
Quick Overview
U bracket with 10 wide mm notch for protecting motor wiring harness against impact.
tomjasz
1.21 GW
1.21 GW
Post by tomjasz » Dec 24, 2017 3:51 am
Makes. Better sense to deal with MAC or EM3ev and self source the controller. Better warranty service.
Triketech
Post by Triketech » Dec 24, 2017 12:35 pm
I ran my 12T at 40 amps 52V (16S LiFePO4) with peaks of 2200 watts for the first 100 miles with the 12 FET Infineon. No problem for the windings, but the gears/clutch won't last long. No problems, but I scaled back to 30A. Not sure about the 6T. Higher resistance (12T vs 6T) changes the thermal losses at different BEMF levels (speed), but I won't elaborate. Just saying the two will have different characteristics.
My BAC 800 does not connect to the CA via the 6 pin connector. I could figure out a way of doing that with adding an internal shunt, but the Phaserunner does that for me. I run the Phaserunner at 30 amps.
With the MAC 10T I pull about 12 amps climbing a 10% grade at 12 MPH on a trike. There is a video on the link below of some hill climbing with the MAC.
http://www.triketech.com/Drivetrain/Pow ... AC-V2.html
ScooterMan101
Post by ScooterMan101 » Dec 24, 2017 1:06 pm
Only 12 amp pull from the battery at 12 mph going up a 10 % grade on your trike impressive.
I do not look much at my C.A. when going up that steep of a hill , but last time I did I thought I saw a 22-25 amp pull at around the same speed, 12-14 mph, on my 6T rear Mac motor. That is quite a difference, know why that would be ?
markz
Post by markz » Dec 24, 2017 2:42 pm
6T 22A vs 10T 12A and same speeds
Would have to look at wheel size on both wheels.
ScooterMan101
Post by ScooterMan101 » Dec 24, 2017 3:31 pm
27.5 x 54cm ( about 2 inch ) wheel / tire on rear Mac 6T
I will have to so some testing this week or next up a few hills.
Triketech
Post by Triketech » Dec 25, 2017 10:43 am
First Merry Christmas.
Volts x Amps = Watts
Speed x Torque = Power
Volts to the motor is determined by speed not the battery voltage. The motor is a generator as it turns generating voltage potential. The faster it turns the higher the voltage; that factor is known as a Voltage Constant. Calculating power is done by the motor voltage x amps, not the battery voltage x amps.
When you feed amps in (or take them back for regen) it occurs at whatever the voltage level is determined by the speed.
The 12T has about twice the Voltage Constant of the 6T. Less amps, more volts. 12T reaches battery voltage level level twice as fast as the 6T, but consumes half the amps for the same number of watts.
Power is measured in watts.
Both the 6T and 12T will take the same wattage (mostly).
