Trek Retrofit
e-beach
Any Los Angeles area beach I am at. Or Santa Monic
So for those who don't know, my frame cracked after more then 11,000 miles use.
So I got a Trek and decided to retrofit my old motor and battery to the new bike frame since they still have life left in them.
The last time I build a battery box I spent a lot of time working out the most efficient space saving way to mount my cells.
This time I am just going to build something and if it take two or three modifications, the time commitment will be the same.
This time I decided to build a battery containment box.
I already see room for improvement, like making holes to access the battery lugs.
However this design will allow me to move the cells around without problem. And, yes I know, Headways were made to lock together. I don't want to have to pull the whole battery apart as it is functioning fine at the moment. And what I am building will be stronger and more secure then the interlocking Headway holders.
More later.
11,000 miles? That's awesome. Looking forward to seeing your newer Trek come together.
My current ebike is a trek 80C sport. Can't find any info online about it but it's very similar to the 800. Great bike but man...no suspension is a killer. Wish I had at least a suspension fork and jiggly seat post...ouch... The thing isn't really fun to ride over 30mph due to the bumps. Works best around 20 or so. I've got a 1000w motor on it and I regularly pull around 1400w max with my setup. Battery gets warm and that's basically the limit of the controller and battery.
My first e-bike was a trek 800 with lead batteries (SLA's)....No suspension...... :shock:
Every pothole felt like a bomb going off under me. :evil:
Some of the big people around here say they prefer no suspension only using their tires for cushioning but I won't ever do that again!
:D
A little woodwork and glue....
Now it begins to look like something.
I was wondering if this would be a problem. The inefficiency of the new battery configuration leaves me with little room to use wood as the main frame box. I do have some aluminum plates that were going to go for another project, and I have more scrap wood then aluminum, but it looks like I will have to use the aluminum for this frame box.
Life is like that some times.
:D
So the triangle frame is ruffed in. Unfortunately I haven't done any welding for over 40 years when I worked at my grandfathers iron works shop before he died, so this one will be a screw and glue job.
A first look at what I have done. It is begging to look like an e-bike.
So I strapped the battery into the frame for a test drive. The steering is a bit stiff, so I will loosening that up a bit. And, the rear tire felt a bit loose because I still have a knobby wheel on the back rim. I will change that tomorrow. For the most part things are looking good.
So how to proceed with the aluminum frame. Well, curiosity got me and I went to the "Great Google in the Sky" and it showed me videos of how easy it was to braze aluminum. 8)
I went to the hardware store and $5.50 later I had my three skinny aluminum rods that melt at 700 degrees Fahrenheit.
I wire wheeled the plates clean where I was going to braze them, I grabbed the old Map gas gun and did some testing.....
I would call that failure..... :oops: I am not going to risk my whole frame on this stuff.
So "what kind of aluminum am I using?" you might ask. Well obviously the kind that wilts before the skinny aluminum rods melt. :roll: OK, the truth be told, I got these aluminum plates a long time ago and don't really remember what they were.
What I do know is that I should have used that money to buy a six-pack of beer. :evil:
Ok, plan B. I am good with wood anyway so why not dig into the ole wood pile and make something useful from some old 3/4 x 3.25 inch oak flooring. Milling some sort of useful shape will do.
Something like this.
I am beginning to see a woodie in my future..... 8)
So after 4 hours of milling more then enough oak rails and 4 more hours of discerning angles, cutting and gluing I have gotten this far..... :oops:
It doesn't look like much yet, but the aluminum frame and wooden milled parts are beginning to come together.
I am using a polyurethane construction adhesive to glue it all together and I am always amazed just how the darn stuff migrates! No matter how clean I try to be be clean, the stuff always seems to get on my fingers and into everything else... :?
But once it drys it is really strong.
As slippery as the wet glue are my plans. It looks like I will need to have one side with the wood frame permanently glued to the aluminum panels. And the other side (wood frame and wood panel) will need to be removable. This so I can get my big Headway battery pack into the frame while also allowing me to remmove the whole triangle frame if required.
I have yet to make the wood panels, but they are coming tomorrow or the next day.
Onward!
Beginning to become something.....but I think a stouter and more stylistic configuration is in order.
Looks like a slow but deliberate few days of glue-ups are in order. Going for style and strength and low weight.
I am beginning to think a blue woody is emerging, like a 1950's car?
:D
That's kinda how my SB Cruiser ended up (though an earlier era, maybe 1920's?) when I redid the deck and made the seatbox with metal frame and wood panels, a year ago. :) Just red, instead of blue.
I probably should've gone slower when I built mine, but didnt' have the time (needed to use it sooner rather than later)--it'd be nicer and stronger; as it is, a year later I've still not gone back and finished it up, though I might get the chance to do some of that this week.
Hopefully yours turns out better than mine. :)
I use those black thick rubber gloves when working with paints and glues and greases and stuff, and I *still* end up with it all over my hands, sometimes because the gloves rip and I don't notice, but sometimes I can't figure out how it got in there. :(
amberwolf said:
........ but sometimes I can't figure out how it got in there. :(
:lol: That's my story as well....How did it get there????
:D
Ok, I got sidetracked. My bike is up and running so I took a break and started working on the classical guitar that has been sitting in my closet for 10 years. It didn't have any frets or nut or bridge, but it still had the fret material that I bought for it 10 years ago. I will have to get a nut and bridge bone from somewhere. It will be interesting to hear how it plays.
On the other hand, with the guitar underway, I turned my attention back to my bike. Tomorrow or the next day I will finalize the look of the panels to give it a "Woody" look.
:D
Trek looks good! I personally would never use wood on my bike but that's personal preference.
Nice to see a suspension fork on it too! I've got a hard front and tail trek 800 sport from 2002 I believe... I just got a suspension seatpost and I'm planning on a suspension fork despite all I can read on people saying a suspension fork on a non-suspension fork bike is a bad idea...
I think, if you can find a good suspension fork for your trek 800 you should go for it. I found the stock fork on my my old Trek 800 had a rake that made the bike unstable. It went straight well, but didn't corner well. I wiped out on it multiple times before I went to my Liahona. That included a fractured rib. Anything to make that frame better I say!
:D
Very familiar looking bike you got there. This is mine with a rear Yescom kit and a EM3EV triangle bag that houses (2) 6S 16AH lipos and the controller. It's been solid so far with just over 100 miles on it.trek4500_ebike.jpg
Nice work.
I find the easiest way to make battery boxes is a combination of wood and aluminum panel. I was making external boxes though, so for me it was a simple wood box, made from a strong poplar wood half inch thick. then the aluminum plate sides just screw on. other materials work for sides too, like coroplast, high quality lexan, or just Masonite.
That method suits my carpentry back ground, put it together with wood screws.
One thing I see in that picture though, an alloy fork with no torque arms.. That will last about half a mile.
@ Dogman, Thanks! ....Ummm, which picture?
:D
These frames definitely have a lot of triangle space for batteries etc, and, they have a nice flat area in the rear for most any kind of torque arm.
The downside is that they come with cheap front forks.
I do, running a front hub motor, appreciate the extra welded plate on the downtube.
My big concern right now is I haven't taken my bike to work yet and I'm wondering about security.... I'd have to most likely lock it up on the dc metro bike lock and that's not the safest. I've got a coil lock and boron carbide key lock but I'm not sure...I might try to ride it inside then down the elevator to the buildings parking lot since theres a lot of places behind cars that I can chain the bike up to but not sure if they will not like that since it's paid parking...I have yet to see an ebike locked up so I'd imagine u might lose it or have stuff taken from it during the day....Hopefully not tho. I would bring the battery into work with me since it's removable...
Some parking garages have bike racks. The one I used to use had the racks right by the guard/pay shack, which was nice.
Yea this one is underground in a building so probably not. They do have these handrails welded into the concrete about 6 ft behind parked cars with an overhang that is only about 5ft high so no cars can park that far back...thats my idea to lock it up there...
I also just realized I never ever use the left handlebar twist gear mechanism...or the front derailleur....so I'm gonna take that off when I get a chance. Lol
The rails sound good. Especially if you can lock near a surveillance camera or guard shack. BTW, why don't you just ride into the garage via the car ramp rather than using the elevator etc.?
Ha. Maybe I'll have to ask the guards if it's OK...
Or just act, "as if" and see if anybody chooses to stop you. :^)
If it is your company's garage, I think it is more likely they won't have a problem with a bike.
Meanwhile back at the ranch.... :lol:
The glue-ups have been coming along albeit slowly.
Although it has afforded me the time to finish the frets, nut and bridge on the guitar and though it has it's flaws, it sounds good for a Korean made Yamaha clone. Probably it is old enough that they still used good wood when it was made.
Do you think anybody will get the reference?
Once I get the dark and natural staining and finishing on the box it will at least be easier to see.
:D
