dzecs
100 µW
After doing a lot of reading here and elsewhere, I think I've settled on a moderate power, geared front hub motor for my cargo bike conversion. The three that I see mentioned the most are the BMC, the MAC and the Ezee. I have had a hard time finding any threads that compare the current versions of these motors directly. Any knowledge would be appreciated.
In case it helps, the project is for a front loading cargo bike (bakfiet/long john). Set up will be used exclusively in Pedelec mode, not even sure I'm going to install a throttle at all. Max speed need not be above 20 mph, motor is mostly for getting going and for hills (generally short moderate grade hills). The bike will have 300 lbs + in weight. Wheels are 20", with hydraulic discs. Middrive isn't an option with the frame. Prefer front hub for a number of reasons but one is that I just had a nuvinci rear hub wheel custom built for the project and I would like to keep it that way.
