markz
100 TW
I used to just wire the two wires together, now my voltage, half throttle ignition device was laying around and I figured I'd hack it up for the ignition as I only use thumb throttle which I bought from Greentime and I love it.
My last throttle had the thumb part of the throttle rotate on the inside. Meant that occasionally that part of my hand between my index finger and thumb would hold the throttle when I didnt need it. It wasnt this one but gosh it looks so similar.
https://www.aliexpress.com/store/product/Wuxing-Brand-FT-21X-simple-Thumb-Throttle-24V-36V-48V-60V-all-suitable-no-indicator-no/313864_32223223193.html?spm=2114.12010612.0.0.6abd67128Jpfd8
This is the thumb throttle I like
Wuxing Brand Thumb Throttle 130X Right/Left Handle
https://www.aliexpress.com/store/product/High-quality-36V-Thumb-Throttle-for-36V-E-bike-Conversion-Kit-with-battery-indicator-on-off/313864_583410607.html?spm=2114.12010612.0.0.6abd67128Jpfd8
I purchased the 108X throttle and its an odd one, but its good to have a spare throttle. Left and Right means that on one side the throttle is above the bar, and other side its below the bar.
https://www.aliexpress.com/store/product/New-Design-24V-36V-48V-60V-72V-84V-Universal-Wuxing-108X-e-bike-finger-throttle-both/313864_32262360597.html?spm=2114.12010612.0.0.6abd6712f9NjuV
That is how I leave my lock, makes just the right amount of noise, also got the bell that I use. You can see the throttle, there is just a slot where the moving parts stick out of, non of the outside housing plastic moves. The metal thing on the handle bar is for a seatpost mount for a trailer. I am using it for ignition mount and light mount. I am buying another one for my seatpost rear rack mount that needs beefing up.
