Miles wrote:Approx. 5 laminations per mm of stack..... So, 500 laminations for a 100mm stack...
Still, if 500 could be done in a few hours, it beats the cost of a die; until the design is finalized.
I'll get some quotes for professionally cut/assembled stacks, once the core is finalised.
That's the idea. Eric handled all that on my last design. It was much more complicated to do an axial flux model, though.Thud wrote:Are we looking for a FEMM model to zero in on some of the stator variables? (tooth width, head area, maybe model some copper senario's?)
What similar sized motors are there? It would be good to make a list.Lebowski wrote:What's the point of making our own motor ? Is there some specific feature that is needed that is not available on commercial motors ?
There's still the option of a 20mm solid, keyed shaft, of course. BobC's collet type locking system seems to be the way to go, though....nieles wrote:the hollow shaft (20mm OD 14mm ID) will be about the same strength of a solid 18mm shaft.
but you lose the ability to use a keyway.
