better picture
ian.mich wrote:This has me stumped. then again, im no EE
HypnoToad wrote:ian.mich wrote:This has me stumped. then again, im no EE
Me neither, but I'm trying to do something similar to you, I'm trying to change the HVC on an eZee controller, as it's made for 36v and I'm using a 48v battery.
Here's what I've done so far, I think I'm almost there: First I found the main microcontroller chip, it's a PIC16F73 in my case.
Then lookup the datasheet and find the pinout, here's mine:
Pins 2,3,4 and 5 are of interest here, they are analogue ins.
What I did next was to vary my battery voltage in even steps, and measure the voltage on these pins. If you are lucky, 1 pin will vary evenly with input voltage. Here are my readings, and pin2 on the PIC16F73 was my pin that changed in proportion to battery voltage:
Battery voltage / Pin 2:
40.4v (10s) / 3.657v
32.36v (8s) / 2.923v
24.31v (6s) / 2.196v
16.23v (4s) / 1.468v
8.07v (2s) / 0.731v
Now I already know that the LVC on my controller is 28v and the HVC is 44v, and this equates to the voltage on pin2 being above 2.5v and below 4v.
What I'm doing now is trying to trace back the resistors which are in series with pin2, and I'm going to try and change the resistance so that an input battery voltage of 36v produces 2.5v on pin2 for the LVC and a battery voltage of 53v produces a voltage of pin2.
This should work in theory, but I've never done it before, so don't take my word as gospel.
Try and find the analogue in first and take it from there, let me know how you get on as this isn't easy for me either.
PS:
Resistance reduces in parallel, and increases in series.
EG 2 x 1000ohm resistors in parallel give a overall resistance of 500Ohms, but if you put them in series you'll get 2000 Ohms. Good luck.
ian.mich wrote:HypnoToad wrote:ian.mich wrote:i believe it would be (1/1000)+(1/1000)=rt, so .002 ohms.
Thank you for the insight, i think i know what i'm doing with my first day of finished exams
i'll start looking for that pin. So you think that pin 1 on your processor is the LVC? did you just put both +ve and -ve of the voltmeter on the pins?
ian.mich wrote:Darn, forgot about 1/rt. It's an x8m06, can't find a datasheet anywhere, ill keep looking
HypnoToad wrote:ian.mich wrote:Darn, forgot about 1/rt. It's an x8m06, can't find a datasheet anywhere, ill keep looking
Google x8m06, alldatasheet seems to have some info.
Good to hear you found the magic pin, swapping/adding resistors should do the trick
ian.mich wrote:He sent me the layout of the board
http://www.pdfhost.net/index.php?Action ... 7eb0ed3a6b
The resistor I believed to be the LVC modifier is in fact the correct one. It is RJ15K near the VCC, confirmed by leo
HypnoToad wrote:ian.mich wrote:He sent me the layout of the board
Now you know hitch resistor you need to experiment with, google up 'pencil mod' and this will give a quick and dirty way of reducing resisance on a SMD resistor
However, I'm not sure how durable running a pencil mod beyond testing would be; it's probably better to break out the soldering iron once you have your esistance values
Users browsing this forum: jkbrigman and 3 guests
