Adding sensors to a Astro 3210 motor
Re: Adding sensors to a Astro 3210 motor
Postby methods » Sat Jan 23, 2010 2:05 pm
Unfortunately the change in forum settings means that you now have to click each picture - but here they are for reference:
Cyclone hall setup
-methods
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
Postby gwhy! » Sat Jan 23, 2010 2:16 pm
Burtie wrote:
gwhy! wrote:There is no reason that this method could not be used for out runners also but mounted to the front of the motor but will also need a different number of mags in the rotor.
I think positioning the sensors in a small arc around the edge of the can (as you have already done) would be an easier solution for the HXT style outrunners.
Given that these outrunners are usually 14 pole motors? the sensor spacing could be as little as 120/7 = 17.14 degrees.
I think i will start a new thread to discuss adding sensors to these motors :)
Burtie
Yes it would be tight i didn't think of that, The arc method was pretty easy and do work well.
gwhy!
Postby Miles » Sat Jan 23, 2010 3:16 pm
GGoodrum wrote:There's about 1/2" of space at the end of the inside of the rear of the motor. I think your nifty little widget will fit inside there.
Just measured mine:
The core starts 15mm in from the inside face of the end-cap.
The internal dia. of the core is 45mm.
The outside dia. of the bearing housing is 25.4mm and it protrudes 7mm from the inside face of the end-cap.
The rotor endcap is 3.5mm thick with an integral spacer 15.7mm dia. protruding 5mm from it (to the bearing).
Anyone want to see photos of the rotor?
Miles
Postby Burtie » Sat Jan 23, 2010 4:21 pm
Yes please Miles!
Pictures are good :D
Burtie
Postby Miles » Sat Jan 23, 2010 4:22 pm
Ok. Here's the rotor:
Miles
Postby Miles » Sat Jan 23, 2010 4:48 pm
Here's the stator:
Miles
Postby bigmoose » Sat Jan 23, 2010 5:04 pm
Miles are the magnet poles made up of 10 thin magnets? What does the goo look/feel like between poles? Are the magnets captured under the aluminum end caps? If you have a macro lens, a couple more close ups of the rotor structure appreciated!
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby Miles » Sat Jan 23, 2010 5:31 pm
bigmoose,
That's about as close as I can get with my big camera. If I can get my old Coolpix 990 working, I'll take some close-ups :)
It looks to me like thin magnets on edge, bonded into slots in steel. I'll see if I can get a better shot and post the full-sized image.
Miles
Postby Miles » Sat Jan 23, 2010 5:41 pm
Here's the full-sized version of the above rotor pic.
Miles
Postby bigmoose » Sat Jan 23, 2010 5:50 pm
Thanks Miles! From the large photo, it almost looks like a pole composed of magnets; followed by an iron pole; then another magnet composed pole. Does it look like that in person?
bigmoose
Postby Miles » Sat Jan 23, 2010 6:02 pm
That's what it seems to me. There is a steel bar with slots cut in it. The magnets are bonded edgewise into the slots and are set below peripheral surface of the iron. So, the wide poles are iron and the narrow ones are the magnets. Does that make sense?
Miles
Postby Miles » Sat Jan 23, 2010 6:14 pm
Here's the full-sized version of the stator pic:
Miles
Postby fechter » Sat Jan 23, 2010 6:53 pm
Cool. I've thought about doing it that way before. That should really keep the magnets from flying out.
I wasn't sure if you built the poles like that if they would be limited by saturation. I wonder what kind of steel it is?
Is the goo stuff hard like epoxy?
fechter
Postby Miles » Sat Jan 23, 2010 7:02 pm
fechter wrote: I wonder what kind of steel it is?
The steel's quite hard, that's all I can say :)
The goo is hard, too......
Miles
Postby bigmoose » Sat Jan 23, 2010 7:06 pm
One last question, I promise! :wink: How many magnet poles, and how many iron poles, & total poles, just to be sure they add up? :mrgreen:
bigmoose
Postby Miles » Sat Jan 23, 2010 7:07 pm
bigmoose wrote:One last question, I promise! :wink: How many magnet poles, and how many iron poles, & total poles, just to be sure they add up? :mrgreen:
8 of each - 16 in total :mrgreen:
Miles
Postby Miles » Sun Jan 24, 2010 8:49 am
Well... Looking at this rotor in the light of day.... I'm not sure my initial interpretation was correct....
The surface on each of the wider pole pieces differs and the way the surface is pitted at the corners looks more like a sintered/cast product....
Miles
Postby Miles » Sun Jan 24, 2010 9:14 am
Here's another pic:
Miles
Postby Burtie » Sun Jan 24, 2010 9:16 am
Thanks for the pictures Miles, always nice to know what the inside of stuff looks like! I am sure they will give all our motor designers here some food for thought.
etard wrote:
Maybe you could connect a blue LED that turns on each revolution too!! :lol:
I am sure that most people here have a good idea about what hall sensors do.
But just for fun :roll: , here is a very short clip I made showing the operation of a latching type of hall sensor.
[ Edit: hall sensor is Honeywell SS411A ]
http://www.youtube.com/watch?v=qr2QtTzuiaw
Sorry etard, ---I didnt have a blue one :| .
Burtie.
Burtie
Postby Ypedal » Mon Jan 25, 2010 11:26 am
How high RPM can you keep up with using halls ? ( this may be a very dumb question, i apologize in advance if it is.. ) hub motors < 1000 rpm, RC motor 8000+ :o
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby gwhy! » Mon Jan 25, 2010 11:52 am
Ypedal wrote:How high RPM can you keep up with using halls ? ( this may be a very dumb question, i apologize in advance if it is.. ) hub motors < 1000 rpm, RC motor 8000+ :o
My setup runs nice at 10k so I don't think there will be a problem with switching speed..
gwhy!
Postby TylerDurden » Mon Jan 25, 2010 12:03 pm
With that space, would Luke's optical system be as good or better? (Gary mentioned this idea)
http://endless-sphere.com/forums/viewtopic.php?f=28&t=14477&start=0
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby MitchJi » Mon Feb 01, 2010 11:32 am
Hi Y,
Different question but somewhat related. Justin said that the controller that he took on his cross Canada trip (that works in either sensored or sensorless modes) would not work in sensorless mode on most RC motors due to speed.
Best Wishes!
Mitch
MitchJi
Postby johnrobholmes » Mon Feb 01, 2010 5:40 pm
We run three slot motors past 50k with sensored RC car setups, and I have spun 12 slot sensored motors past 12k. I don't think the hall effect sensor will be the limiting factor on commutation speed, moreso the controller's max commutation rate.
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Burtie » Mon Feb 22, 2010 3:03 pm
I now have some pictures of the sensor unit fitted to a double shaft 3220 motor :)
3220 sensor front on.jpg (106.88 KiB) Viewed 958 times
3220 sensor side on.jpg (101.51 KiB) Viewed 1093 times
I will wire it all up and test the motor in both Delta and Wye configurations and post the results when I get time :| .
Still looking at embedding some similar implementation inside the end-cap, not there yet tho.
Burtie.
Burtie
Next
Return to Motor Technology
Who is online
Users browsing this forum: pendragon8000 and 2 guests
