Adding sensors to a Astro 3210 motor
Re: Adding sensors to a Astro 3210 motor
Postby mwkeefer » Sun Jun 05, 2011 8:44 am
mdd,
That's cool - the 3220 and 3210 have the same case I belive (maybe longer) but same bolt pattern and shaft diameter?
Put me down for one please - I have a working and tuned solution but it looks like rat scat and I will be showing off the latest incarnations alot!
I'd buy a copy (without the additions) if you would make it available, PM me for contact info / payment, etc)
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby Burtie » Tue Mar 06, 2012 8:05 pm
Just linking this thread to an optical implementation.
While the external hall sensors with a separate magnetic rotor appear to work well, I could never get an internal hall sensor setup to work satisfactorily with an Astro motor.
After some experimentation fitting halls inside the Astro, I found problems caused by stator flux interfering with the sensors, causing bad commutation, even at very low power levels.
In an attempt to find a good internal solution, I tried this optical implementation instead:
viewtopic.php?f=2&t=28966&start=30#p434772
Burtie
Previous
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 7 guests
