Adding sensors to a Astro 3210 motor
Having problems getting the halls to work
Postby drewjet » Thu Feb 25, 2010 4:10 pm
Ok so I got my hall sensors from Mouser http://www.mouser.com/Search/ProductDet ... ey785-SS41 I hooked them up with the chamfer facing up neg at center, pos to the left and signal to the right. I can't get them to turn on. I tried 4v 6v 8v 12v. I have a hall from an old motor and it works just finejust like that. I tried 6 of them and none worked.
Am I doing something wrong, did I get the wrong ones. or did I get a bad batch?
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Re: Adding sensors to a Astro 3210 motor
Postby Burtie » Thu Feb 25, 2010 4:31 pm
Do you have a pullup resistor on the signal lead? Without this the signal will never go high.
Must limit the current to less than 20mA, so something like 1 or 2k would do.
Burtie
Postby drewjet » Thu Feb 25, 2010 8:50 pm
No I don't have a resisitor on the signal lead.
So just add a 1K resistor inline with the signal leg?
drewjet
Postby methods » Thu Feb 25, 2010 9:07 pm
No - there is no active output from this sensor
Think of the hall sensor as a BJT
The collector is the signal lead
The emitter is tied to ground
When the magnetic field is present it runs current into the base and connects the collector to the **** (edit emitter)
Long story -
You need to "pull up" the signal line
This means that you need to tie a 1K resistor between 5V and the signal line
This will output 5V - then when the sensor becomes active it will "pull down" the voltage to 0V
-methods
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
Postby methods » Thu Feb 25, 2010 9:09 pm
BTW: If at any time you accidentally tie +5V directly to the signal line it will destroy the sensor. As suggested above, the current must be limited to 20mA
5V / 1k = 5mA
That is why a 1K resistor was suggested. Enough current to bias the sensor and raise the noise floor but not so much that it overheats from too much current.
If you use higher voltage - like 10V - you must also use a higher resistance
10V / 2K = 5mA
Make sense?
-methods
methods
Postby drewjet » Fri Feb 26, 2010 10:59 am
Ah, that makes sense now thanks for the explanation.
Interesting that the hall I pulled out of my dishwasher motor did not need the resistor. It simply either turned power on or off.
Is the resistor is only needed when testing? When hooked to a speed control it is not needed, is that correct? Thanks for helping the electronically challenged.
Drew
drewjet
Postby gwhy! » Fri Feb 26, 2010 11:13 am
Hi DJ,
Most controllers have these pull up's built into the controller so you do not have to worry about them.
gwhy!
Postby Scorefield » Sat Mar 13, 2010 7:22 pm
Looking forward to see it running and hope everything will go well.
Anyone got a video soon please. :mrgreen:
coughInfineon.
Scorefield
Postby Burtie » Sun Mar 14, 2010 5:49 am
The sensored astro seems to work ok on the bench :D
I still have a few small tweaks to do to the sensor plate design, but it seems good so-far:
http://www.youtube.com/watch?v=AbCYDYIFW80
Burtie
Postby liveforphysics » Sun Mar 14, 2010 6:23 am
Burtie! You're awesome! Great work!
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby AussieJester » Sun Mar 14, 2010 7:55 pm
liveforphysics wrote:Burtie! You're awesome! Great work!
+1 you da man Burtie!
KiM
AussieJester
Postby Scorefield » Sun Mar 14, 2010 10:19 pm
Holy smoke, I just fell down off my chair :shock:
You are awesome..
Thanks a lot for the vid.*jumping up and down* :mrgreen:
Scorefield
Postby Burtie » Mon Mar 15, 2010 4:30 pm
Thanks for the encouragement guys! :mrgreen:
I tried the same trick with the motor wired delta and made the following observations:
1) The hall sensor group needed to be moved by about 12 (mechanical) degrees to minimise the no-load current in delta.
See angle between pen mark and securing tab. Without this adjustment, the motor ran slowly, was very noisy and took 6 amps unloaded.
2) There seemed to be no acceptable compromise between the delta and wye hall group positioning that would work well for both configurations.
In a position mid way between the two, the no load Y current was almost double at 1 amp.
( I guess sensorless controllers do have some good points :wink: )
3) I saw the same expected efficiency loss due to recirculating currents in delta as discussed here:
viewtopic.php?f=28&t=13760&start=45#p244398
The no-load current was 3.5 amps in delta, as opposed to 0.6 amp in wye, even after the timing had been adjusted.
Difference in hall group position d and y
D-Y Timing change.jpg (76.66 KiB) Viewed 434 times
Burtie
Postby kevo » Mon Mar 15, 2010 8:04 pm
Very awesome Burtie! Are kits for other Astro owners in the future?
Thanks for all,
Kevo
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby 12p3phPMDC » Mon Mar 15, 2010 11:22 pm
Great Reporting Burtie!
Sensorless controllers automatically discover the timing due to back emf.
Sensored controllers start better....
So, If we could only run sensorless in Delta and sensored in Y. :lol:
You can start with a lower Kv in Y, and switch to Delta when you want to switch.
It would be cool to have a controller with adjustable timing tables with a digital input
that will switch between tables or static advance or retard settings.
Ah....no free rides ever, especially when you are trying to get the most out of something.
It reminds me of the timing tables in an ICE engine controller. The two controllers
that I've setup both have timing tables that allow one to advance or retard the timing based
on speed. It would be very flexible even if all you needed was static advance/retard but
could optimize with a table vs speed. (edit: Tables are two-d with load/vacuum/or throttle position too).
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Postby Burtie » Tue Mar 16, 2010 3:44 am
Hmmm, -ebike controller with adjustable timing tables, sounds like a nice idea!
Anyone out there fancy a PIC / Infineon firmware project?? could integrate the D-Y switch in the FET output stage as well :mrgreen:
Hell, I might even have a crack at it one day, but it wont be quick!
As an interim solution I wondered about more slots in the plate for a second hall group to run delta. Could parallel the outputs of the two hall groups and just turn on power the group that was required :?:
Burtie.
Burtie
Postby Burtie » Tue Mar 16, 2010 5:56 am
kevo wrote:Very awesome Burtie! Are kits for other Astro owners in the future?
Thanks for all,
Kevo
Hi kevo,
Yes I will look into the cost of getting a number of these discs and plates made up soon, as a sort of kit :)
Burtie
Burtie
Postby Ypedal » Tue Mar 16, 2010 6:42 am
Put me down for one ! :wink:
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby johnrobholmes » Tue Mar 16, 2010 8:18 am
Same here, I want!
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Scorefield » Tue Mar 16, 2010 11:51 am
Ypedal wrote:Put me down for one ! :wink:
johnrobholmes wrote:Same here, I want!
Sign me up for one, please.
Scorefield
Postby matt_in_mtl » Tue Mar 16, 2010 2:30 pm
Burtie wrote:Hmmm, -ebike controller with adjustable timing tables, sounds like a nice idea!
You mean something like this?
http://scolton.blogspot.com/2010/01/3ph-duo-wrap-up-part-1-field-oriented.html
A very interesting read, he is going a couple steps further too though.
Very cool results Burtie, very cool!
-Matt
matt_in_mtl
1 W
1 W
Postby Burtie » Tue Mar 16, 2010 7:23 pm
Good find Matt,
We need that guy here with us on the sphere! :wink:
On the subject of cooling, -If you can't fix the cause, then just treat the symptoms:
How about these fins to dissipate the heat generated by those recirculating currents :P
They are the ones that Cyclone sell to keep their heat problems in check. Almost perfect fit on the astro.
Astro fins.jpg (101.84 KiB) Viewed 461 times
Burtie
Postby kevo » Tue Mar 16, 2010 7:48 pm
Burtie,
You are another hero in the Endless-Sphere among us lesser mortals!
Definitely sign me up for your Hall Sensor holder when they become available.
Regarding using Cyclone heat sinks for Astros, doesn't Cyclone only sell these with their Cyclone kits?
Is there an alternative way to just buy the heat sinks for us Astro folks?
-Kevo
kevo
Postby dbaker » Tue Mar 16, 2010 8:48 pm
Burtie,
Great work! I am waiting for a 3220 to arrive and am interested in a kit. I already got the Hall sensors.
Dave
dbaker
Postby Grinhill » Tue Mar 16, 2010 8:55 pm
kevo wrote:Is there an alternative way to just buy the heat sinks for us Astro folks?
-Kevo
Hey Kevo, Recumpence made some heatsinks for Astros a while back, send him a pm, he may still have some. 8)
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill III - "Supercommuter" featuring Recumpence RC drive
Grinhill
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: J-aprilia-N and 4 guests
