You beat me to it!
I think this internal solution is potentialy much more practical / cheaper / verstile / easier to produce than the external setup I have been playing with.
Nice job
Burtie
Suzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
drewjet wrote:I have had some limited success with getting my 3220 to run on hall sensors. I made a fixture similar to Burtie's but I have it on the inside and am using the magnetic field coming out the side of the rotor. The video attached explains it.
http://www.youtube.com/watch?v=WqO2NkT_4o0
dbaker wrote:Drewjet,
Any recent developments with the Hall sensors inside your 3220? I got my 3220 and will be opening it up today. Looks like I should set the sensors up vertically spaced 30 degrees and try to null unloaded current. Did you get yours working well?
Dave
Burtie wrote:Inspired by drewjets video, I tried fitting sensors inside the astro too.
It turned out to be a pretty fiddly job to get the timing right, but it works well on the bench now
I had a couple of attempts at fixing halls to a circular piece of strip board that was machined to fit inside the end cap.
The second attempt worked better.
I needed to get the sensors further away from the stator fields.
Hall positioning was complicated by having to avoid a large lump of snot stuck to the end of the rotor, -presumably for balancing.
To sum up:
wye current was 0.6 A, delta current was 4 A (was 0.6A and 3.5A with external hall setup and also with sensorless controller), so efficiency looks pretty similar so far. With This method it took about 1 hour to make the parts and the rest of the day trying to get the timing right! -sort of the opposite way round to the external method.
I can fit both internal and external sensors to the same motor, so should be easy to do a proper comparison of performance when it is fitted to a bike.
Burtie.
Users browsing this forum: poirot89 and 8 guests
